Won't start after lying down!!!
Results 1 to 20 of 25
    Thanked: 974
    Angry Won't start after lying down!!!
    HAIR RAISING!!!
    OK. Front left tyre burst while on a sand road. I ended up in a ditch on the left hand side of the road. So close to laying on its side it was scary. Only thing stopping me from lying on my side was the side of the ditch.
    When I stopped the motor was still running fine. Defender coming past helped me out after a major battle. Back on the flat road – changed the burst wheel and ready to go.
    NO! Now she won’t start. It was lying on its right hand side.
    · Did the diesel pump suck air?
    · Has oil got where it does not belong?
    · Has diesel got where it does not belong?
    · Where should I start looking or do I leave it to the indies to look at?
    Your advice will as usual be appreciated.
    Discovery 3 TDV6 2007.
    Stay Safe
    Disco-Deon
    This morning I woke up,
    Making today a great day.
    Nerdy, 2011 Honda Jazz, 1500 Exc
    Springs
    Thanked: 275
    all models of Defender and Disco 1 & 2 have a "rollover" switch situated against the firewall. pretty sure the D3 has the same sort of safety device.
    that switch is there specifically for cutting fuel supply in the event of a rollover.
    push down firmly on the top of the switch (it looks like a mushroom) and then try to start.
    Lonehill (JHB)
    Thanked: 18
    Yes its called an Inertia switch, if I am not mistaken it should be mounted on the firewall on your right hand side with the bonnet open, that's where it is located on the D2.
    Thanked: 38
    I am glad you are ok.
    I know about the switch but dont know where it is on the D3.
    I call it the omdopknop.
    Discovery 3 V8 SE
    Self designed Rock and Tree Sliders.
    Next: Project Bashplate
    1981 Series 3 S R6 88" Allmost Perfectly Restored
    sunninghill
    Check your user manual for the running out of fuel, restart procedure as a first step ?
    Vtown
    Thanked: 83
    Glad you're safe and hope its nufink serious.
    But,you're a photographer-NO PICS
    A legend in his own mind
    Thanked: 393
    If the motor was still running, then surely the inertia switch would not have cut out?
    2004 Defender 110 Td5
    Apr 2011
    Thanked: 51
    Ditto. My Alfa did the same. Its switch was under the passenger seat. The engine also idled fine until I turned it off and wanted to start again... weird.
    2007 KB300 DC 4x2
    If you lose one sense, your other senses are enhanced. That’s why people with no sense of humor have such a strong sense of self-importance.
    Thanked: 974
    Red face
    Got up this morning and saw some more damage than previously seen, so got hold of the insurance to take it away for repairs, panel shop can get it running again and then it’ll go to The Induna to check it over.
    Visible damage is not worth pics and no camera with me yesterday to get photos unfortunately.
    Just glad I was alone and only slightly hurt.
    Stay Safe
    Disco-Deon
    Springs
    Thanked: 275
    Quote Originally Posted by DeonvanderMerwe View Post
    hope you did not spill your beer
    Thanked: 974
    Only spillled the last few drops of coffee
    Stay Safe
    Disco-Deon
    Springs
    Thanked: 275
    you have us curious
    try the mushroom button (if you can find it)
    according to the documentation i consulted, it should be on the firewall in front of the passenger side in the engine bay.
    Thanked: 38
    Quote Originally Posted by Landyluvver View Post
    you have us curious
    I will check tomorrow where the omdopknop is.
    Discovery 3 V8 SE
    Springs
    Thanked: 275
    Quote Originally Posted by Silver Shadow View Post
    would be great to know as general info
    had a customer a while back that had his car cut out regularly while driving a moerofabad road in Botswana
    being a Td5 he had all these visions running through his head and eventually figured out that the switch was defective and gippoed it to get back.
    the Td6 often gets a bad rap but there are a couple of basics to look out for. once aware of these "weaknesses", fault finding becomes a lot easier.
    Thanked: 38
    I checked this morning quickly, I dont see anything. I also checked inside the battery box. I will get a flashlight and investigate some more later.
    Discovery 3 V8 SE
    Thanked: 974
    Didn't find the button before getting her delivered to Panel Beayers, good luck to them now
    Stay Safe
    Disco-Deon
    Jun 2013
    Winburg
    our TD 5 disco would not start after I changed the oil and the filters. One thing that puzzled me was that I did not hear the fuel pump. It is usually quite audible after a fuel filter change. I read these posts, found the rollover switch and pressed it - the familiar fuel pump sound came on and it started. This is something really worthwhile knowing about thanks to your posts. I wonder if the rollover switch is not the solution to many of the LR will not start questions! Checked in our defender - sure enough, there is the is the rollover switch. A rather belated thanks for your posts.
    The Windy City
    Thanked: 2967
    Quote Originally Posted by Disco-Deon View Post
    HAIR RAISING!!!
    I thought for a moment oh no Deon has chucked the Disco into a ditch then I saw the date of the original post
    Thanked: 2099
    Lol me too! Was thinking how the heck did he lose one of those new tekkies
    Tzaneen
    Thanked: 224
    Fortunately I saw the date
    Would still like to know if the D3 has such a switch and where it is located?My RRC had one under the passenger seat.
    Regards,
    Frans
    2012 RR TDV8 4.4
    2006 TDV6 SE A/T(Sold)
    2008 FL2 TD4 SE A/T
    1968 Renault 8 Gordini
  1. 2.4D wont start
    By JurgenSteyn in forum Toyota
    Last Post: 2012/05/01, 12:42 PM
  2. Discovery 2: engine will not start.
    By Mountain Goat in forum Land Rover
    Last Post: 2012/04/19, 08:34 AM
  3. Toyota Hilux doesn't start
    By gerardvdm in forum Toyota
    Last Post: 2010/04/13, 08:03 PM
  4. Pajero wont start
    By LandJero in forum Mitsubishi
    Last Post: 2010/04/12, 08:10 PM
  5. Freelander Hard start
    By jacovos in forum Land Rover
    Last Post: 2010/04/06, 04:06 PM
