Results 1 to 7 of 7
    Thanked: 250
    Default Where to find 10W30 oil?
    Where can I find 10W30 oil for my TJ?
    I have looked everywhere and cannot seem to find it.
    2013 Tata Xenon 3.0 Dicor D/C
    2006 Honda Civic EXi FN2
    Sep 2010
    Brymore, Port Elizabeth
    Thanked: 33
    From the response it seems like 10W30 is not available.
    Pieter
    2018 Fortuner 2.8 4x4
    Cape Town/Where ever oil is found
    Thanked: 22
    Why do you want an oil with a viscosity that iws approaching hydraulic oil Look in your
    BP had something that is called TRACTRAN you use that in tractor transmissions that share The same oil as the hydraulics
    I would suggest you look in your manual under specs and see that this oil is for cold climates a 20W50 or the like is to be used in South Africa
    Land Rover 300 Tdi Sadly sold
    Bush lapa Vlooi B263 This is the best investment I ever made,next to SWAMBO asking to marry me
    76 Series LAND CRUISER 4.2 Donkey It' now history
    The black TOUAREG V6 is history Will get one again one that works
    Now TYDSAAM is a PAJERO DiD GLS The Bush Lapa is NO HURRY
    And SWAMBO a TOYOTA YARIS
    The CORSA bakkie for the little tasks
    Wellington
    Thanked: 19
    Why not use a 5W30 or better, a 15W40.
    Problem with a 5W30 is it will be a synthetic, your application might not like that.
    What about a straight SAE30
    2002 Colt, 2.8 tdi Rodeo, 4x4, ARB Bull Bar, Excalliber Running Boards, Monroe Gas Magnum Shocks, Cooper AT3's, Excel 53l long range tank, National Luna Dual Battery System, Campmaster 80l Fridge/Freezer Combo, FrontRunner Fridge slide and Bin Slide, Alpha Gte Canopy with FrontRunner Roof Rack and Homemade Awning...Pulling a Caravan sometimes
    Jun 2012
    Melbourne
    Thanked: 155
    Its called Castrol TFF, standard factory oil fill for alll the Hilux and Fortuners.
    kyalami
    Thanked: 7
    Try Land Rover - 5w30 is what I need for my l322 and the only place I have found it is at the dealer. I think 10w40 is what they use in the discos. Maybe they will have what you need. Synthetic only though.
    Sent from my iPhone using Forum Runner
    Hunters Close, Port Elizabeth
    Thanked: 77
    before you switch oil to find an easy to find alternative, check the manufacture, if the manufacture specifies a certain oil like 10W30 then the agents should stock it as not doing so could void the warrenty.
    in the states cheverolet uses 10w30 or maybe even 5w30 in it's pickups, while under warrenty you have to use that oil grade or it will void the warrenty.
    so i say checkdealer and see what they use and require, if vehicle is under warrenty.
    Luke aka Jedi
    1954 Landy Rover Series 1 86"- Rambling Rose
    Best company slogan: Cherrybomb performance exhaust, Disturbing the peace since 1968
  1. Disco3 TDV6 Engine Failures
    By hgbosch in forum Land Rover
    Last Post: 2013/11/06, 11:11 AM
  2. DIY Servicing, oil filter incident.
    By Farmer Doug in forum Mitsubishi
    Last Post: 2009/11/23, 02:02 PM
  3. KB200 / KB260 oil filter
    By RussellF in forum Isuzu
    Last Post: 2009/05/12, 10:30 AM
  4. Differential Oil Specification
    By Herlu in forum Mitsubishi
    Last Post: 2009/05/07, 09:22 PM
  5. Buying oil
    By OFFROAD ADDICT in forum General 4x4 Discussion
    Last Post: 2008/07/04, 10:25 AM
