Caracal Eco Route
Results 1 to 15 of 15
    Gordon`s Bay
    Thanked: 9
    Default Caracal Eco Route
    Hi all.
    I`ll be doing the Caracal eco route starting 3 September 2012--Is there any info or hazzards to look out for, and what is the difficulty level?
    I have a Ssangyong Kyron 2ltr diesel 4x4 t-tronic (moet nie lag nie !!!)
    Where to stay ,and do I need to take extra diesel?
    Mark
    Malmesbury
    Go to search, there is a lot of info, I plan to do it oktober. jy sal dit lag lag doen met daai ryding
    Rykdom - wat jy in jou hart het
    Thanked: 15
    West Coast?
    Thanked: 15
    If you are referring to the West Coast Caracal route then I do have some info for you.
    Upington
    Thanked: 60
    I recently went through there towing a off-road caravan without any problems whatsoever.
    Try and stay as close to the coast as possible by taking every turnoff towards the sea you get. That way, you will at least encounter some sand. Otherwise you can stick to the dirt road, which you will be able to drive in a Avis Golf. Mind you, a Avis Golf can go anywhere.
    Mitsubishi Triton 3.2 Di-D 4x4 Auto with a Bush Lapa Miskruier (#30) following closely behind.
    In the process of going there and doing that.
    Gordon`s Bay
    Thanked: 9
    Yep, the route is on the West Coast --by the way I think a Kia Picanto from Europe Car is the best 4x4 !!!
    Thanked: 15
    AMAROK
    BLINKGAT ALU CANOPY
    BLINKGAT DRAWER SYSTEMS AND FRIDGE SLIDE
    DOUBLE BATTERY SYSTEM
    BLNKGAT OFFROAD TRAILER WITH RTT
    Thanked: 15
    If you want to overnight in Kleinzee you will require a permit. To simply drive through you and your passengers only need your ID's.
    We traveled from North to South and all of the roads to the beach in the Kleinzee area is locked with no access signs. If you want to travel close to the beach here you'll have to book with Diamond Tours and it's a guided 3 or 4 day tour.
    The real adventure starts just south of Hondeklipbaai when you enter the coastal section of the national park.
    Koingnaas 30'11'44.24 S ; 17'17'29.12 E
    Hondeklipbaai 30'19'06.46 S ; 17'17'07.75 E
    Jahleel skeepswrak 2003
    30'18'44.95 S ; 17'16'21.75 E
    Hondeklipbaai Ligtoring 30'18'31.65 S ; 17'16'11.84 E
    Hondeklipbaai Karavaan en Kamp 30'18'54.46 S ; 17'16'35.25 E
    "Die Hondeklip" 30'19'41.45 S ; 17'16'37.55 E
    Viewpoint 30'19'58.03 S ; 17'16'26.24 E
    Spoegrivier
    30'26'43.86 S ; 17'25'43.87 E
    Boggerall By Kamp
    30'31'32.70 S ; 17'23'44.92 E
    Platbaai 30'35'55.99 S ; 17'26'35.47 E
    Skuinsduin Kamp (geen fasiliteite) 30'37'13.36 S ; 17'26'06.85 E
    Koringkorrel Kamp (toilette beskikbaar) 30'39'20.29 S ; 17'27'47.40 E
    Skuinsklip Kamp 30'39'50.58 S ; 17'28'02.02 E
    TJ Kamp 30'40'25.40 S ; 17'28'19.39 E
    Varswater Kamp 30'41'11.77 S ; 17'28'44.93 E
    Kwaaskamp (toilette beskikbaar) 30'41'46.80 S ; 17'29'13.07 E
    De Beers Kamp 30'45'38.21 S ; 17'31'54.48 E
    Groenrivier Oorgang
    30'49'39.95 S ; 17'34'40.35 E
    Parkbewaarder se woning (hout beskikbaar) 30'51'04.83 S ; 17'34'32.94 E
    Groenrivier Ligtoring 30'51'36.72 S ; 17'34'40.41 E
    Namaqua skeepswrak 30'55'01.72 S ; 17'36'12.15 E
    Rob kolonie 31'01'33.37 S ; 17'41'14.87 E
    Geelklipbaai 31'03'56.15 S ; 17'42'13.96 E
    Blougatbaai
    31'04'20.71 S ; 17'42'47.52 E
    Skurfbaai 31'05'11.80 S ; 17'43'20.75 E
    De Beers Kamp (geen fasiliteite) 31'05'50.71 S ; 17'43'42.01 E
    Brakrivier Oorgang 31'05'48.41 S ; 17'43'54.75 E
    Soutrivier Oorgang 31'14'32.64 S ; 17'51'03.50 E
    Blinkwaterbaai 31'17'28.46 S ; 17'52'49.32 E
    Brandsebaai Kamp 31'18'09.38 S ; 17'52'57.79 E
    Floors se Gat 31'18'39.15 S ; 17'52'48.58 E
    Geustyn se Gat 31'18'56.30 S ; 17'52'47.50 E
    Stompneus 31'21'48.89 S ; 17'54'45.73 E
    Dr Andrew Wright Gedenkteken 31'24'18.14 S ; 17'56'56.19 E
    Diamond Diggers Kamp 31'26'09.53 S ; 17'58'57.95 E
    Sandbaai 31'29'33.99 S ; 18'01'57.35 E
    Geelwal
    31'31'48.55 S ; 18'04'19.09 E
    Cliff Point 31'35'53.71 S ; 18'06'57.86 E
    Rob Eiland
    31'38'37.66 S ; 18'08'52.32 E
    AMAROK
    BLINKGAT ALU CANOPY
    Thanked: 15
    And as you'll note on the other thread I got somewhat stuck.
    Secunda
    Thanked: 23
    If you want to do the tour you must get a proper 4X4 and the most important thing is: let SWAMBO do the driving!
    Thanked: 15
    One thing is for sure, if you want to do this route you do not want to tow a heavy trailer with no back-up to get you out should you get stuck.
    You have top be totally self-sufficient insofar as food, water, wood, etc...
    AMAROK
    BLINKGAT ALU CANOPY
    Gordon`s Bay
    Thanked: 9
    Quote Originally Posted by Nico H View Post
    Hi Nico.
    Jy weet mos wat ek gaan doen, sal by die werk vir jou die fotos wys!!
    Cheers en sien jou in 3 weke
    Mark
    Gordon`s Bay
    Thanked: 9
    Het die Caracal Roete gedoen en wat `n belewenis!!!.
    Tussen Garies en Kamieskroon was daar duisende harige wurms wat op die pad was.
    Kamieskroon Karavaan park aangekom, Tent opgeslaan en die wereld bekyk.--Moet ook bylas dat die karavaanpark se ablusie blokke die skoonste is wat ek nog gesien het.
    Lang my het `n ou in sy rooftop tent geslaap toe toe wind opkom en die arme tent laat toevou het!!!
    Die blomme was in volle blom so ver as wat jy kon sien.
    Het op pad na Koingnaas vasgesit vir omtrent een uur (Die middelman was bietjie te hoog vir die Kyron). Nadat ons uitgehelp is het ons na Hondeklipbaai gegaan en al lang die kus af tot op Groenrivier mond sonder enige probleme. Die verkillende kamplekke is baie netjies en is reg op die strand.
    Sal weer die volle roete doen volgende jaar met die blomme.
    Pasop net vir die baie skilpaaie in die pad (Weet ook nie hoekom hulle na die anderkant van die pad wil gaan as daar `n voertuig aankom nie, het omtrent 15 verder in die veld ingedra sodat hulle nie naby die pad kan wees nie)
    Nou het die gogga gebyt en is soek na die volgende roete om te ry (wil net die Kyron so 2" lig vir die ho middelmannetjies.)
    Jun 2015
    C.T.
    Thanked: 47
    Hi. We are also planning to do this trip BUT want to start in Lamberts Bay and head all the way up the coast to Groenriver !!
    Has any one done this ?? Is there any Obstacle's ( closed farms, mines, locked gates ect )
    We will be towing a caravan !!
    Cape Viking
    VW Amarok
    Africa Twin Adventure Sport DCT
    Thanked: 35
    We did the Caracal Eco Route in September 2014. Awesome, except for missing the first turn-off. This only happened because we could not agree on whether to turn left on go straight.
    PS - We had an off road caravan on tow. No problems
  1. Gert Du Toit se baai - West Coast Eco Route
    By Jaco Kruger in forum 4x4 Trails / Routes / Clubs
    Last Post: 2017/10/17, 10:19 PM
  2. Old Welgedacht Eco route now open again
    By bushcamp in forum 4x4 Trails / Routes / Clubs
    Last Post: 2012/08/23, 02:32 PM
  3. Namakwa Eco Route in Softie
    By KurtG in forum 4x4 Trails / Routes / Clubs
    Last Post: 2011/10/31, 05:08 PM
  4. Time required for Caracal and Westcoast Eco routes?
    By cornevandyk in forum 4x4 Trails / Routes / Clubs
    Last Post: 2011/05/10, 08:22 AM
  5. Namakwa Eco route update?
    By saskia in forum Northern Cape
    Last Post: 2011/04/03, 07:56 AM
