Results 1 to 20 of 22
    Thanked: 56
    Default WJ Blend Doors/Heater Codes
    Hello,
    So last night I randomly stumbled across a YouTube video describing a no heat situation with the internal heater. I have a similar problem in that my heater only seems to heat on high and even then not very well.
    The video seems to suggests that this is a common problem with the Jeep GC as the plastic hinges on the blend doors break. The video also shows a trick whereby you hold in the A/C and recirculation buttons and using the LEFT temperature control knob you can access some type of code...
    Does anybody know what the numbers represent/have a definition? Mine cycle from 53 through 56 - at first I thought it was the heat output in Fahrenheit however I am not so sure as the video suggest that they are error codes
    David
    OW have you had a look at this site ? Tell you all you need to know about the problem.
    2004 Jeep Grand Cherokee Laredo (WG) 4.7L V8 - Oh the joy
    <a href="http://www.fuelly.com/driver/mfour/grand-cherokee" target="_blank"><img src="https://badges.fuelly.com/images/smallsig-metric/118642.png" width="135" height="50" alt="Fuelly" title="Share and compare MPG at Fuelly" border="0" style="border:solid #ccc 1px;padding:4px;background:#fff;"/></a>
    Thanked: 56
    Thanks mfour!
    It was their video I was watching last night.... the website has far more information - error codes below.
    Have you fixed your blend doors?
    Input faults
    01 = IR thermister circuit open
    02 = IR thermister circuit shorted
    03 = Fan pot shorted
    04 = Fan pot open
    05 = Mode pot shorted
    06 = Mode pot open
    07 = IR sensor delta too large
    08 = Reserved
    09 = Reserved
    10 = One of four motor drivers has drive "A" shorted to ground
    11 = Engine air intake temperature bus message missing
    12 = Country code bus message missing
    System faults
    13 = Mode motor not responding
    14 = AI (Recirc) motor not responding
    15 = Left temperature door not responding
    16 = Right temperature door not responding
    17 = Mode door travel range too small
    18 = Mode door travel range too large
    19 = AI (Recirc) door travel too small
    20 = AI (Recirc) door travel too large
    21 = Left temperature door travel too small
    22 = Left temperature door travel too large (Result is no heat - Our kit repairs this)
    23 = Right temperature door travel too small
    24 = Right temperature door travel too large (Result is no heat - Our kit repairs this)
    25 = Calibration check sum error
    26 = Engine coolant temp bus message missing
    27 = Vehicle speed bus message missing
    28 = Engine RPM bus message missing
    29 = OAT bus message missing
    30 = Display intensity bus message missing
    31 = VIN number bus message missing
    32 = Raw OAT buss message missing
    Input faults
    33 = IR thermister circuit was open
    34 = IR thermister circuit was shorted
    35 = Fan pot was shorted
    36 = Fan pot was open
    37 = Mode pot was shorted
    38 = Mode pot was open
    39 = IR sensor delta was too large
    40 = Reserved
    41 = Reserved
    42 = One of four motor drivers had drive 9A9 shorted to ground
    43 = Engine air intake temperature bus message missing
    44 = Country code buss message missing
    System faults
    45 = Mode motor was not responding
    46 = AI (Recirc) motor was not responding
    47 = Left temperature door was not responding
    48 = Right temperature door was not responding
    49 = Mode door travel range too small
    50 = Mode door travel range too large
    51 = AI (Recirc) door travel range too small
    52 = AI (Recirc) door travel range too large
    53 = Left temperature door travel too small
    54 = Left temperature door travel too large (Result is no heat - Our kit repairs this)
    55 = Right temperature door travel too small
    56 = Right temperature door travel too large (Result is no heat - Our kit repairs this)
    57 = Calibration check sum error
    58 = Engine coolant temp bus message missing
    59 = Vehicle speed bus message missing
    60 = Engine RPM bus message missing
    61 = OAT bus message missing
    62 = Display intensity bus message missing
    63 = VIN number bus message missing
    64 = Raw OAT bus message was missing
    65 = Reserved
    66 = Reserved
    67 = Reserved
    Sourced from http://www.jgcparts.com/faultcodes.html I will be buying this kit shortly....
    David
    No prob OW. Nope I got clever and got a Laredo, which does not suffer the same problem as it only has one blend door, not two
    CY ek sÍ!
    OW, David, I have that problem too and it's freaking cold in Cape Town this year!!!! If you plan to attempt this operation let me know what the solution / outcome is please!!!
    It's a J e e p thing...........you would'nt understand!!
    Ek ry met stok-ou Jeeps, want dan dink almal ek's al lankal ryk!!
    Gee vir my 'n Coke......skoon Coke......met 'n dubbel Brannas in asseblief!!
    Dec 2010
    Pta, Silverton
    Thanked: 75
    Yip, laredo is the way to go... Haha.
    Durbanville, Cape Town
    Thanked: 29
    I too am watching this thread closely ... I have a No heat but also no aircon (that's cause there is no gas in it Allan ... tut tut)
    Apr 2012
    Goodwood
    Brilliant found OceanWanderer
    KTM 950 Adventure
    Opel Zafira 1.9 CDTi Panoramic
    Sold: 2004 GC CRD Overland
    Thanked: 56
    Hello All,
    Quick update for everybody, I sent an email to the States this morning asking for a total price on:
    Jeep Badges: $9.95 (two Jeep badges)
    Blender Flaps: $150
    Door panel clips: $9.95
    If I get no response or one that I don like (in terms of postage cost) I am going to get a premium subscription on myus.com and take it from there....
    I will let you know when I get a response.
    David
    Apr 2012
    Goodwood
    $89 for a Full 2" lift kit. Not bad at all.
    KTM 950 Adventure
    Mar 2012
    Ballito
    Thanked: 994
    Quote Originally Posted by Fillistyn View Post
    From where?
    Apr 2012
    Goodwood
    Quote Originally Posted by cainslie View Post
    From where?
    KTM 950 Adventure
    Thanked: 29
    Thanked: 29
    Apr 2012
    Goodwood
    Ebay
    Aluminium Blend doors for sale.
    http://www.ebay.co.uk/itm/JEEP-WG-WJ...item5d34bb18c3
    KTM 950 Adventure
    CY ek sÍ!
    I'm in for a set. Who can bring them in for us?
    Thanked: 29
    I ordered door panels clips from jgcparts.com today. Paid for them. They are already shipped and on their way. I am sure one of use can order 5 or 10 sets of the door blenders and bring them in with one shipment. JGCPARTS offer free shipping world wide.
    i want to see what happens with the small parts before moving onto the larger parts ... value I mean
    Thanked: 56
    Allan,
    Please keep me updated on what happens, I have had zero feedback from the email address.
    David
    Thanked: 29
    Will do.
    I got a reply to say my goods have been shipped. Shipped the same day I paid for them. I'm impressed so far.
    Thanked: 56
    Allan
    Have your door clips arrived?
    David
  1. buying a WJ - Fault codes & pre-purchase check
    By Megagustodon in forum Jeep
    Last Post: 2010/07/26, 08:48 AM
  2. Jeep 2.7 Laredo fault codes
    By MRoss in forum Jeep
    Last Post: 2010/06/24, 03:50 PM
  3. OBDII Trouble codes
    By Morton Berg in forum Vehicle & Technical Chat - General
    Last Post: 2010/03/26, 06:40 PM
  4. How to read error codes
    By offroadrover in forum Land Rover
    Last Post: 2010/03/26, 06:12 PM
  5. Computer Fault Codes
    By Jeepster in forum Jeep
    Last Post: 2007/06/06, 02:38 PM
