Need a gas fridge
Results 1 to 6 of 6
    trichalo Guest
    Default Need a gas fridge
    After reading the whole thread on the camping fridge I know what I need to buy for use in the Pajero but I still have a bush house (With limited solar power). So what I need is a biggish combo gas/12v/220v but mainly running from the gas like the geyser/ stove
    I will get myself a 40L 12v for the trips but where do I get a fridge for the house. These are quite pricey R5000+ for a 300L and I am looking for something around 120L odd ?
    Any ideas ?
    Jan 2007
    Tamboerskloof, Cape Town
    Thanked: 135
    I can't remember when last I saw one of those big chest freezers in a shop, although one often sees them in farmhouses - you could even consider a paraffin one, I suppose - so I'd say someplace like a co-op should be able to at least tell you where you could get them, if you don't get help from a farmer here first, that is!
    Feb 2007
    Randpark Ridge Jhb.
    Many mordern caravans are equiped with these 3-way fridge/freezers, ranging from 80-190 lit. I often see them advertised in the smalls of the Caravan and Outdoor Life mag. Owners often replace them with bigger 220v only fridges. You can olso try the caravan dealers.
    Nigel
    Thanked: 1925
    I have a freezer like that.
    Will post some pictures shortly
    +27 zero eight 2 four 95 9252
    Nov 2006
    Thanked: 403
    If you bump into a paraffin model, dont look away.
    Its normally the big solid types. Its easy to convert to gas and works well.
    Try Kaysies - saw an advert last night with some gas fridges on.
    By charlatan in forum Jeep
  2. Cold Factor Gas Fridge
    By bushhappyfred in forum Camping, Fridges, Accessories
    Last Post: 2015/03/03, 01:23 AM
  3. Zero Fridge Gas Usage
    By GMTM in forum Camping, Fridges, Accessories
    Last Post: 2011/04/15, 07:12 PM
  4. Fridge on GAS, not working properly.
    By Hyades in forum Camping, Fridges, Accessories
    Last Post: 2011/01/31, 11:17 AM
  5. Fridge Freezer gas
    By DiD32 in forum Camping, Fridges, Accessories
    Last Post: 2009/03/10, 07:00 AM
