Page 381 of 382 FirstFirst ... 131 281 331 356 371 372 373 374 375 376 377 378 379 380 381 382 LastLast
Results 7,601 to 7,620 of 7624
Thread: Bush Lapa mods
  1. #7601
    Apr 2008
    Secunda
    Thanked: 359
    Default Re: Bush Lapa mods
    I have experienced the same and as mentioned above blocks work to stop the rolling of the wheels
    However, I use my stabilizer in conjunction with the jockey wheel - the jack takes a lot of weight of the wheel and thus amounts to the same end goal of saving the jockey wheel
    Works well for me and provides stability for the from when kids are on the bed
    2013 Toyota Hilux 3.0D4-D 4x4
    Bush Lapa 810 Miskruier
  2. #7602
    Thanked: 2908
    Here enters the benefit of the Al-ko jacks. In this pic the jockey is simply touching the ground, but has no pressure on.
    The BL stabilizer on the A-frame - the intent is not to replace the jockey, but simply to add support in conjunction with the jockey wheel. The stabilizer alone will create a pivot point.
    Disclaimer - All my posts on this forum is without prejudice, is based on my fair assumptions or perceptions, might not be factually correct, is in no way intended to cause harm to anyone and is acted upon at your own discretion.
  3. The Following 3 Users Say Thank You to George For This Useful Post:
  4. #7603
    May 2016
    Mossel Bay
    Thanked: 29
    Ek het nie daai Alko jacks op my 2014 Miskruier gehad nie ma het dit gesien op ander Bushlapa's.
    Met nuwe Kewer het ek dit laat opsit en dit werk briljant, maak die wa baie meer stabiel binne, nie meer daar "gewieg" nie.
    Martin vir my opgesit en dit was ook nie so baie nie, was onder die R2800 as ek kan onthou met instalasie.
    2017 TOYOTA FORTUNER 2.8 4X4
    2014 BUSHLAPA 350 MISKRUIER
  5. #7604
    Thanked: 2908
    Direk by Al-ko is hulle so R800 per kant. So uur se werk om dit te installeer.
  6. #7605
    Dec 2006
    Thanked: 185
    Het jy dalk fotos van die 'mounting points' asseblief.
  7. #7606
    Thanked: 64
    Quote Originally Posted by TimTDP View Post
    I am looking for a solution for my Boskriek shower. Shower water creates a lot of mud. Also want to be able to dump water away from BL.
    Would like a mod to keep shower area mud free, and easy water disposal
    Thanks in advance
    Hi Swambo makes these to order out of canvass, they roll up flat with a size of 1200mm long, 130mm wide and 30mm thick
    Please contact Tracy on 0832680042 for furtjher details
    also see https://www.gumtree.co.za/a-camping-...00910393168509
Name:	quickpitch basin 2.jpg
ID:	629925   Click image for larger version.
ID:	629926   Click image for larger version.
    Putta
    Landcruiser 105
    BL Miskruier B850
  8. The Following 5 Users Say Thank You to putta For This Useful Post:
  9. #7607
    Thanked: 2908
    Quote Originally Posted by Sebastiaan View Post
    Op die T waar die chassis sterk is. Daar is 2 grootte jacks beskilbaar. Vir die Goggas, kry die korter een sodat hy vertikaal kan opvou langs die chassis.
ID:	629936   Click image for larger version.
ID:	629937   Click image for larger version.
ID:	629938   Click image for larger version.
  10. The Following 2 Users Say Thank You to George For This Useful Post:
  11. #7608
    Apr 2008
    Secunda
    Thanked: 359
    Busy installing a Victron BMV-712 battery monitor in my Miskruier B810. Looking at a few options of where to install (fasten) the shunt that needs to connect between the battery negative and the load an charger negatives. With everything else close by and already in the battery box I m think of somewhere under the side bed close to current battery installation. Where is the shunt on the newer models or any other similar mod done? Suggestions?
  12. #7609
    PE & North Africa
    Thanked: 524
    Quote Originally Posted by Hilux01 View Post
    Hallo Henk,
    Hier het BL myne gesit, op die voorkant van mudguard onder die bed.
    2021 Hilux Raider 2.8 GD-6 4x4 D/C Auto "Luxy"
    2018 Baobab 4 - B1543 "Nala"
    Bacon fact #16 - Bacon is healthier than Crystal Meth!
  13. #7610
    Apr 2008
    Secunda
    Thanked: 359
    Right so the shunt of the Victron BMV-712 is fitted and connected. Rivotted it on the lip of the lid below the side bed next to the batteries. Sorted the app and now playing with solar etc details and history. Fantastic product. Ill get a 52mm steel hole saw and fit the monitor to the DB board, replacing the Hella plug this week sonewhere.
ID:	630423   Click image for larger version.
ID:	630424   Click image for larger version.
  14. #7611
    Loevenstein, Bellville
    Thanked: 530
    Looks like a very cool gadget and I love things like this but sheez it's expensive.
    Niel
    2012 BMW F800GS
  15. #7612
    Apr 2008
    Secunda
    Thanked: 359
    Ok so monitor fitted to DB. Never want to drill a 52mm hole in my BL again 🥶😀
  16. The Following 2 Users Say Thank You to Hilux01 For This Useful Post:
  17. #7613
    Mar 2011
    Springbok
    Thanked: 34
    Very nice, although, to avoid the stress and work just replace your batteries with a BT lithium. 1) You can track the SOC on your cellphone 2) Your BL will be around 30 kg lighter and 3) you free up space in the load bin
  18. The Following User Says Thank You to HarleyD For This Useful Post:
  19. #7614
    Thanked: 134
    Hierdie is nie eintlik 'n mod nie maar 'n verandering. Ek wil die 15" 6 gat staal rims op my Boskriek vervang met 16" 6 gat staal rims. Nou is ek op soek na 3 tweedehandse staal rims. Iemand hier wat miskien so iets het?
    Groete,
    Ben
    RY WAAR JY MAG MET PASSIE
    2009 Toyota Hilux 3.0 D4D DC 4X4
  20. #7615
    May 2008
    Germiston
    Quote Originally Posted by Smiles View Post
    A while back I decided to fit 2 drawers in the kitchen. So to the drawing board, laser cut, paint, assemble and install...
    Installed it today.
    Used Stainless steel.
    Pleased with the result.
    Attachment 581504Attachment 581505Attachment 581506Attachment 581503Attachment 581508
  21. The Following 2 Users Say Thank You to Jaycee For This Useful Post:
  22. #7616
    May 2008
    Germiston
    Hi Hennie, jou modifikasies lyk baie profesioneel. Ek hou van jou idees.
  23. #7617
    Plett/Paulshof
    Thanked: 1936
    Brilliant work....maybe start selling these upgrades.
    Bruce Hunter
    "your signature should not be used to judge you or your opinions"
  24. #7618
    Rondebosch
    Thanked: 15
    I am wanting to fit reflective fly sheets to my Baobab 4.
    BL Paarl quoted me around R6k for reflective front and side sheets, which seems a bit expensive?
    Are ther any other options? What about a reflective paint one can put on yourself?
    Would be interested to hear anyone's experience - thanks.
  25. #7619
    PE & North Africa
    Thanked: 524
    I am in same boat, did not know thats the price
    I think I am going to see my local canvas company, they have made some impressive things in the past.
    A while back I was there and they had just replaced ALL the canvas on an older Bushlapa on the entire wing.
    My plan is to retain the front bed normal cover and make something the same shape, but instead of being permanently attached against the Baobab above the bed, just 3 hooks. The rest of the eyelets will hook into the rods as normal. Will only be used when its really hot.
    Grumbles
  26. #7620
    Nov 2012
    Namibe
    Thanked: 66
    Grumbles
    I did this exact same thing to my Miskruier a while back when the reflective rain fly was aluminium covered. It was a bit of a schlep to hook and unhook. I found that I always wanted to use it, and meanwhile the regular rain fly underneath still had to be setup so that everything fit right. In the end, I had the newer reflective canvas rain fly fitted during servicing at Gauteng a few years back. If I had to do it again, I’d use @SneakyPete and his shop to do all reflective canvas, including bushwing. The reflective canvas makes a massive difference in the heat, and doesn’t really change things in the cool.
    David Killough
    2016 Landcruiser 200 GX-R
    1995 Landcruiser (UK Spec) SOLD
    Bushlapa Miskruier 321
    www.killoughfamily.com
  27. The Following 2 Users Say Thank You to Climbingnut For This Useful Post:
  1. 3 Bush Lapa Miskruiers in one spot!
    By Kooskop in forum Trailers, Caravans, Towing etc
    Last Post: 2021/02/26, 04:24 PM
  2. Project Venter Bush Baby: first impressions
    By coala in forum Trailers, Caravans, Towing etc
    Last Post: 2014/10/28, 06:57 AM
  3. Bush Lapa Miskruier featured in.....
    Last Post: 2011/10/03, 03:18 PM
  4. Kyknet Buitelug Expo - Bush Lapa range
    Last Post: 2011/09/29, 08:20 PM
  5. Performance mods on TD's
    By 280iNyati in forum Vehicle & Technical Chat - General
    Last Post: 2006/09/12, 10:39 AM
