Page 378 of 382 FirstFirst ... 128 278 328 353 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 LastLast
Results 7,541 to 7,560 of 7624
Thread: Bush Lapa mods
  1. #7541
    Apr 2008
    Secunda
    Thanked: 359
    Default Re: Bush Lapa mods
    Probably not considered a BL mod but started off with us considering a BL shower add to our Miskruier B810 and ended up with this.
    A QuickPitch Ensuite shower cubicle in a Alu-box. Tested over the eastern weekend and worked like a charm. Now we have a more mobile option and the quality is great.
    Fitted it with a pair of FrontRunner quick release awning brackets. 1min on and off when we leave or return after a trip.
ID:	613217   Click image for larger version.
ID:	613218   Click image for larger version.
ID:	613219   Click image for larger version.
ID:	613220   Click image for larger version.
    2013 Toyota Hilux 3.0D4-D 4x4
    Bush Lapa 810 Miskruier
  2. The Following 4 Users Say Thank You to Hilux01 For This Useful Post:
  3. #7542
    Canada
    Thanked: 15
    Quote Originally Posted by Abrie7 View Post
    How did you guys secure your fridges to the fridge drawer? I got the NL 90 which fits nicely on the drawer and have slots through both handles. My question is where did you secure the tie-down to the drawer? I was thinking of riveting iron rings to the four corners of the drawer - just on the outside.
    The fridge do seem to move around a bit.
    Any help will be welcome.
    Abrie
    On the bottom of our NL72 are two rails that the fridge sits on. We drilled four holes in the bottom of the rail and installed (M4/M5?) riv-nuts/nustserts and then used four low profile button head bolts through the slide base from the bottom. The bolts need to be quite low profile to clear the door seal but it eliminates the straps and keeps it firmly in place. If possible place the fridge upright on a table to drill the holes etc. so you don't have to turn it over. If you do turn it over, leave it upright and off for a day or so for the freon can settle back into place.
    Jason Porter
    1989 HJ61 'The Cruiser'
    Bush Lapa Boskriek #98 'The Snoozer'
    'Life is great when you are in 98!'
  4. #7543
    Plett/Paulshof
    Thanked: 1936
    Quote Originally Posted by racingjason View Post
    Do they still use Freon?
    Bruce Hunter
    "your signature should not be used to judge you or your opinions"
  5. #7544
    Canada
    Thanked: 15
    Sorry, I was using Freon as a generic term, I think ours runs on 134a. Either way we tipped it up on end when we were drilling the holes and it went a bit wonky until the refrigerant settled down.
    Cheers,
    Jason Porter
  6. The Following User Says Thank You to racingjason For This Useful Post:
  7. #7545
    Thanked: 74
    I find that the mattress on the side bed of our Boskriek moves downward (away from the window) during the night. I seem to remember that someone with the same problem used Velcro to fix this? Does anyone have more details?
    LC 105 EFI
    BL 1003 Boskriek
  8. #7546
    Plett/Paulshof
    Thanked: 1936
    Quote Originally Posted by Gustav Preller View Post
    And during the day??
    Bruce Hunter
  9. #7547
    Thanked: 7166
    I just simply put one of those non-slip mats used in car boots under the bottom half of the bed. Solved the issue.
    Christa
  10. #7548
    Thanked: 74
    Quote Originally Posted by lekhubu943 View Post
    Thanks, Christa, I will give that a try
    LC 105 EFI
    BL 1003 Boskriek
  11. #7549
    Nov 2017
    Alberton / Marloth Park
    Thanked: 44
    I cut a piece of insertion rubber and placed it over the lid of the storage compartment under the mattress - no more sliding mattress.
    Ben
    2020 Amarok V6 Highline Plus
    2021 Bush Lapa Boskriek #2377
  12. #7550
    Thanked: 2908
    At your age, shouldn't you be less active in the bed at night? Asking for a friend.
    Remember to lock the fold out beds locks so that the mattress can move up a bit higher.
    Disclaimer - All my posts on this forum is without prejudice, is based on my fair assumptions or perceptions, might not be factually correct, is in no way intended to cause harm to anyone and is acted upon at your own discretion.
  13. #7551
    Patensie
    Thanked: 29
    Draai net jou matras om. Daar is n dik en n dun kant. Dit is so gemaak om gelyk te slaap
  14. The Following User Says Thank You to Krummelpap For This Useful Post:
  15. #7552
    Thanked: 74
    Smile Re: Bush Lapa mods
    No comment, I am only 64!
    What are the fold out bed locks?
    LC 105 EFI
    BL 1003 Boskriek
  16. #7553
    Thanked: 74
    Quote Originally Posted by Windsock View Post
    Thanks, Ben, I got myself the non-slip mat and will try that first.
    LC 105 EFI
    BL 1003 Boskriek
  17. #7554
    Thanked: 74
    Quote Originally Posted by Krummelpap View Post
    Dankie, daardie een het ek uitgefigure.
    LC 105 EFI
    BL 1003 Boskriek
  18. #7555
    Aug 2017
    Bellville
    Thanked: 172
    Watse kant is bo en onder asb? Nie seker dik bo of onder nie?
  19. #7556
    Dec 2006
    Thanked: 185
    Die dikker deel van die matras l op die kas waarin die battery gestoor word (die voete kant), die dunner deel op die paneel wat na buite oopmaak (dit is op ons model - 2012 BL 34. Weet nie of dit verander het sedert BL weggedoen het met die hout vul stuk op die paneel wat na buite oopmaak nie)
  20. The Following User Says Thank You to Sebastiaan For This Useful Post:
  21. #7557
    Thanked: 74
    Quote Originally Posted by Sebastiaan View Post
    Doodreg
    LC 105 EFI
    BL 1003 Boskriek
  22. The Following User Says Thank You to Gustav Preller For This Useful Post:
  23. #7558
    Thanked: 2908
    Die bed se buite slotte. Druk hul albei in asof die hatch gesluit is.
  24. #7559
    Thanked: 74
    Nooit daaraan gedink nie, dankie George
    LC 105 EFI
    BL 1003 Boskriek
  25. #7560
    Rooihuiskraal
    Thanked: 38
    Quote Originally Posted by ohalloran View Post
    Hi
    A few Mods done to my BL.
    This helps when closing the front bed, allows for the polls to lay flat and not stick out.
    Dave
    Hi Dave,
    This mod is exactly what I was after. Our BL Kewer 2381 suffers from the same dreaded grub screw problem. Please could you advise as to where you sourced the pins.
    Thanks in advance
    Simon
    Paj Sport 2012
    3.2 DiD
    OME Suspension
    Long Range Tank
    F/R Roof Rack,
    Original OBD and Double Din Pioneer
    C-Tek Dual Bat & Solar System,
    Escape Gear
    Stofpad Bash Plates
  1. 3 Bush Lapa Miskruiers in one spot!
    By Kooskop in forum Trailers, Caravans, Towing etc
    Last Post: 2021/02/26, 04:24 PM
  2. Project Venter Bush Baby: first impressions
    By coala in forum Trailers, Caravans, Towing etc
    Last Post: 2014/10/28, 06:57 AM
  3. Bush Lapa Miskruier featured in.....
    Last Post: 2011/10/03, 03:18 PM
  4. Kyknet Buitelug Expo - Bush Lapa range
    Last Post: 2011/09/29, 08:20 PM
  5. Performance mods on TD's
    By 280iNyati in forum Vehicle & Technical Chat - General
    Last Post: 2006/09/12, 10:39 AM
