Page 377 of 382 FirstFirst ... 127 277 327 352 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 LastLast
Results 7,521 to 7,540 of 7630
Thread: Bush Lapa mods
  1. #7521
    Loevenstein, Bellville
    Thanked: 536
    Default Re: Bush Lapa mods
    Quote Originally Posted by harrygaz View Post
    Two bikes on the front will add at least 30kg.
    Not quite, unless the bikes are very heavy. Only about 70% of weight added to the nose box goes to the tow ball with 30% to the axle/ wheels.
    That said, if one is already at 80kg (and I find the tow ball quite heavy already), the extra 21kg will just push it over the limit.
    Niel
    2012 BMW F800GS
  2. #7522
    Thanked: 3444
    Quote Originally Posted by fatbike View Post
    I will never put a bicycle on my car or bakkie roofAttachment 612188
    Thank you! Now I don't have to take bikes on camping holiday ever again!
    "If you spend most of your time in the fiction section, your life will be based on fiction"
    Luka Geertsema
  3. #7523
    Krugersdorp
    Thanked: 220
    Quote Originally Posted by Musashi View Post
    Where did you find this graph? Got one for Ratel4?
    Riaan
    2019 Toyota Land Cruiser 200 GX-R
    2019 Toyota Hilux Extracab 2.8GD6 4x4
    2018 Bush Lapa Ratel 4 (B1244)
  4. #7524
    Lynnwood, Pretoria
    Thanked: 143
    Two eMB's 25kg each....
    Groete
    Harry
    BL Vlooi # 195 aka Jakkalas
    Lexus LS 470
    BMW 1150 GS Adv
  5. #7525
    Thanked: 536
    Quote Originally Posted by Monkey-D View Post
    I did it myself. If I can find a side profile photo of a Ratel, I can quickly draw one up.
    Niel
    2012 BMW F800GS
  6. #7526
    Thanked: 536
    Niel
    2012 BMW F800GS
  7. #7527
    Oct 2006
    Wil hoor of iemand al hulle nose box met iets soos durabak geverf het en hoe dit met klipperige grond paaie cope?
    Is die military edition se nose box anodized of is dit n tipe stone chip verf?
  8. #7528
    Krugersdorp
    Thanked: 220
    Would loading height, chassis forward/backward tilt and axle height not play a role? I'm sure it will, but not sure how much
    Riaan
  9. #7529
    Thanked: 536
    It sure does!
    Niel
    2012 BMW F800GS
  10. #7530
    Apr 2012
    Thanked: 18
    Quote Originally Posted by Abrie7 View Post
    How did you guys secure your fridges to the fridge drawer? I got the NL 90 which fits nicely on the drawer and have slots through both handles. My question is where did you secure the tie-down to the drawer? I was thinking of riveting iron rings to the four corners of the drawer - just on the outside.
    The fridge do seem to move around a bit.
    Any help will be welcome.
    Abrie
    Abrie
    I have a 90l NL on the slide not strapped down. Never had a problem with it moving even on Botswana gravel or Kgalakgadi corrugations. Just load enough Windhoeks in the bottom mandjies for low centre of gravity 😀😃
    _______________________
    Heinz Reinstorf
    Mitsubishi Pajero 3.2 Did GLS
    VW Tiguan Tdi
    Bushlapa Miskruier No. 68
  11. The Following User Says Thank You to Ballbearing Dyster For This Useful Post:
  12. #7531
    Oct 2012
    otjiwarongo
    Thanked: 279
    hi Fellow BL owners
    have any of u guys made use of these guys services and products? any feedback will be appreciated
    http://www.alloutdoors.co.za/
    2017 VW Amarok 3.0 TDi V6 4Motion D/Cab
    2020 VW T Cross Highline R Line
    2019 Bushlapa Miskruier 1616
  13. #7532
    Aug 2017
    Bellville
    Thanked: 172
    Good qualty products and service. You can use them anyday!
    Quote Originally Posted by hein100 View Post
    hi Fellow BL owners
  14. #7533
    Oct 2012
    otjiwarongo
    Thanked: 279
    Quote Originally Posted by SP1971 View Post
    thanks yes Bush Lapa referred me to them.
  15. #7534
    Plett/Paulshof
    Thanked: 1944
    Romeo is a top guy with awesome quality products.
    Bruce Hunter
    "your signature should not be used to judge you or your opinions"
  16. The Following User Says Thank You to BruceHun For This Useful Post:
  17. #7535
    Thanked: 133
    Hi All
    I am eagerly awaiting my Baobab due early July. Please could I get advise re the rims and tyres. 15 inch rims with 245 tyres or 16 inch rims with 265 tyres
    Tow vehicle Disco 4.
    Would 16 inch rims and 265 tyres offer much better floatation in sand.
    What are the most essential items on the extras list
    Regards Gavin
    2015 Discovery 4 30 SDV6 SE
    2007 Defender 90 Puma 2.4
    Bush Lapa Baobab 2470
    Previous
    Metalian Off Road Trailer
    2010 Discovery 4 30 TDV6 SE
    Discovery 3 V6 S
    Discovery 2 TD5
    Defender 90 TDI
    Defender 110 V8 Hard Top
    Jurgens Xplorer
  18. #7536
    Nov 2012
    Namibe
    Thanked: 67
    Quote Originally Posted by Wedwo View Post
    Hi All
    Regards Gavin
    Not sure what wheels and tyres your Disco is using, but if at all possible, matching your caravan wheels and tyres to your Disco as well as the axle width to your vehicle will help down the road. Flotation will be based more upon airing down than upon the standard inflated tyre. For some reason my original Miskruier came with 2 x 16 wheels and 1 x 15 with tyres that were appropriately sized. I used them without issue. Just aired them down the same and they did fantastic. Later I swapped the axle for one a heavier one to match my 200 and went to 17 wheels and matching KO2s. Does better in sand tracking my vehicle now.
    David Killough
    2016 Landcruiser 200 GX-R
    1995 Landcruiser (UK Spec) SOLD
    Bushlapa Miskruier 321
    www.killoughfamily.com
  19. #7537
    Thanked: 133
    Quote Originally Posted by Climbingnut View Post
    Climbingnut
    Hi My vehicle has 19 inch rims, which I dont think are suitable for a Bush Lapa
    Regards Gavin
    Previous
    Discovery 3 V6 S
    Discovery 2 TD5
    Defender 90 TDI
    Jurgens Xplorer
  20. #7538
    Thanked: 536
    Hi All
    Regards Gavin
    I don't think the difference would actually be that significant. Personally I would go for 15" rims as tyres are generally more available and I suspect a bit cheaper as well.
    Extras is very personal and I'm actually not even up to speed on what they are these days. As an example, a lot of people swear by a geyser but we do not see the need. On the other hand we got the bicycle rack mount and never used it. Maybe send a list of extras you're considering then we can comment on that based on our experience.
    Niel
    2012 BMW F800GS
  21. The Following User Says Thank You to Musashi For This Useful Post:
  22. #7539
    Thanked: 2914
    Keep the rims standard. Optional extras are very much dependant on how you intend using the caravan with all the core stuff are included as standard. I'm not sure of the latest extras list, but think if, how and when you'd use each item on the list. If you can't find a realistic reason, leave it.
    Disclaimer - All my posts on this forum is without prejudice, is based on my fair assumptions or perceptions, might not be factually correct, is in no way intended to cause harm to anyone and is acted upon at your own discretion.
  23. The Following 3 Users Say Thank You to George For This Useful Post:
  24. #7540
    Canada
    Thanked: 15
    Quote Originally Posted by Luka View Post
    A good habit I got into is when I put the rack on the top of the Cruiser I would take the garage door control out of the vehicle and leave it at home. That way if I came home, got out of the car, opened the garage door and still drove in with the rack, I deserved what I got.
    Jason Porter
    1989 HJ61 'The Cruiser'
    Bush Lapa Boskriek #98 'The Snoozer'
    'Life is great when you are in 98!'
  25. The Following 2 Users Say Thank You to racingjason For This Useful Post:
  1. 3 Bush Lapa Miskruiers in one spot!
    By Kooskop in forum Trailers, Caravans, Towing etc
    Last Post: 2021/02/26, 04:24 PM
  2. Project Venter Bush Baby: first impressions
    By coala in forum Trailers, Caravans, Towing etc
    Last Post: 2014/10/28, 06:57 AM
  3. Bush Lapa Miskruier featured in.....
    Last Post: 2011/10/03, 03:18 PM
  4. Kyknet Buitelug Expo - Bush Lapa range
    Last Post: 2011/09/29, 08:20 PM
  5. Performance mods on TD's
    By 280iNyati in forum Vehicle & Technical Chat - General
    Last Post: 2006/09/12, 10:39 AM
