Page 375 of 382 FirstFirst ... 125 275 325 350 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 LastLast
Results 7,481 to 7,500 of 7630
Thread: Bush Lapa mods
  1. #7481
    PE & North Africa
    Thanked: 527
    Default Re: Bush Lapa mods
    Quote Originally Posted by 4x4Superman View Post
    Thanx Grumblers and Musashi for the reply.
    Nope i dont store anything else in the compartment, only the 2 X gas cylinders are in there.
    Grumbles, i have noticed before that there are damp and moist in the compartment, but recently it became more and even the cylinders have some rust on it. The regulators is also packed with white powder (beginning phase of rust maybe). I also close the cylinders after a camp trip, but never unscrew the regulators. You think this might have something to do with it? Maybe a leak valve on the bottle that creates the moist?
    Stefan I don't know, but I also open my gas stove after disconnecting like Hilux01 said. I don't think this is your issue.
    It is really strange. Have you taken out the bottles and a good look inside the box to possibly see a crack somewhere on the "roof" of the box? Only other place that moisture could possibly get in somehow would be the door seal (unlikely) and the two grommets where the gas pipes come through the back of the box.
    Hope you find the cause.
    Grumbles
    2021 Hilux Raider 2.8 GD-6 4x4 D/C Auto "Luxy"
    2018 Baobab 4 - B1543 "Nala"
    Bacon fact #16 - Bacon is healthier than Crystal Meth!
  2. #7482
    Aug 2015
    Roodekrans
    Thanked: 146
    Hi Grumbles and Musashi. Thanx again for the reply.
    I did check the lids and also the opening where the hoses comes into the compartment. No leaking or nothing. Also, the last 2 camps we had, there was no rain. I really dont know where the corrosion, damp and moist can come from. The only thing i can think about is a leaking cylinder maybe? Dont have a clue. Will take the bottles out the wekeend and send them in to check and service. Will also check the hoses and regulators, and clean and dry inside. Will then keep an eye on it.
    Stefan
    2020 Land Cruiser 79 D/C
    2019 BMW X1 M-Sport 2.0D (Swambo platkar)
    2020 Ford Figo Titanium (daily platkar)
    2018 Toyota Hilux V6 auto 4X4 double cab - sold
    2019 Bush Lapa Ratel 4 - sold
    2018 Toyota Etios Sprint - sold
    2017 Ford Ranger 3.2 auto 4X4 double cab - sold
    2016 Volvo V40 D4 Geartronic - sold
    2008 Gypsey Gold Caravan - sold
  3. The Following User Says Thank You to 4x4Superman For This Useful Post:
  4. #7483
    Nov 2017
    Alberton / Marloth Park
    Thanked: 44
    Had a problem to maneuver my Boskriek under the carport due to a steep incline, so I decided to fit a removable winch. It makes pulling it into position a breeze and I can park it single-handed. The winch was purchased from Adendorff.
ID:	608176   Click image for larger version.
    Ben
    2020 Amarok V6 Highline Plus
    2021 Bush Lapa Boskriek #2377
  5. The Following 6 Users Say Thank You to Windsock For This Useful Post:
  6. #7484
    Jun 2019
    Sheffield Beach
    Quote Originally Posted by Hubu View Post
    Hi
    I need some advice from the members that camp on the coast regularly.
    We went to Buffelsbaai for 3 weeks in December. did a big wash and clean the day after we came back and noticed some rust and corrosion. This was the first time the Baobab went to the coast. Was not used last year with the pandemic. Parking at home is under a well enclosed carport.
    Is this normal when camping at the coast.
    Regards Hugo
    Hi Hugo
    I live on the KZN North Coast and we give our outside parts that will rust a coating of Q20. Easy to apply and leaves a clear oily coating. It's a bit late now but in future perhaps give the exposed metal parts a coating before going to the coast.
    Regards, Matt
  7. The Following User Says Thank You to MattR For This Useful Post:
  8. #7485
    Jun 2019
    Sheffield Beach
    Evening all, I'd like some input and sorry if this has been discussed elsewhere. I have searched and can't find any discussion.
    When we use the gas cooker, the heat radiates down and heats up the drawer below. Has anyone found a solution to this? I'm thinking of some kind of insulating material to put under the gas cooker but don't know what.
    Regards, Matt
  9. #7486
    Jan 2020
    Kidd's Beach
    Thanked: 103
    Morning. Not a modification but a problem and probably not the correct thread to ask info about but I hope somebody can give me some advice.
    I have a bosluis 2 mounted permanently on a modified LC 105. My problem is that the 2 batteries in the vehicle which were new had to be replaced after a year. I did not start the vehicle for 2 months over Christmas I admit but both batteries had no charge. They were so drained that they would not hold a charge and needed replacement .
    Here is my question. If I left the bosluis with 220 current on over this period would it not have also kept the vehicle batteries charged.
    Not being good with electronics I need to get to grips with this. I have asked a bush lapa agent for a wiring diagram. Just wondering if anybody else has experienced similar issues. If so what did they do.
  10. #7487
    Plett/Paulshof
    Thanked: 1944
    No. Not if there is no connection between the Bosluis and vehicle. Does the bosluis have its own battery/batteries?
    Bruce Hunter
    "your signature should not be used to judge you or your opinions"
  11. #7488
    Jan 2020
    Kidd's Beach
    Thanked: 103
    Yes it has its own batteries plus solar power.
  12. #7489
    Plett/Paulshof
    Thanked: 1944
    Quote Originally Posted by Khakibush View Post
    I would use a separate charger for the vehicle batteries. Keep the vehicle and bosluis batteries separate.
    Bruce Hunter
  13. The Following User Says Thank You to BruceHun For This Useful Post:
  14. #7490
    Plett/Paulshof
    Thanked: 1944
    Quote Originally Posted by MattR View Post
    Regards, Matt
    I noticed this as well but I did not think it is a big issue.I do put tinfoil shiny side up under the gas cooker to make it easier for cleaning. This does help.
    Bruce Hunter
  15. The Following User Says Thank You to BruceHun For This Useful Post:
  16. #7491
    Feb 2019
    Gariepdam
    Thanked: 43
    Greetings all
    This is how I installed my filter system in my Ratel.
    I installed a new hose from the front to the back cold water tap,the entire water system goes through the filter.
    The filters are also easy to take out and service outside and if anything goes wrong the inlet and the outlet gets connected and the filters are bypassed.
    Lekker kamp die naweek manne,dit is nou as ons nie gehok word nie.
  17. The Following 5 Users Say Thank You to Pentafam For This Useful Post:
  18. #7492
    PE & North Africa
    Thanked: 527
    Quote Originally Posted by Pentafam View Post
    Greetings all
    Nice Pentafarm! Wat kos daai filter?
  19. #7493
    Feb 2019
    Gariepdam
    Thanked: 43
    Quote Originally Posted by Grumbles View Post
    Hi Grumbles
    Dit was R1600 afgelewer,moet sÍ ek is noggal verbaas,genoeg lewering deur filter om nog lekker te stort.
  20. The Following User Says Thank You to Pentafam For This Useful Post:
  21. #7494
    Apr 2008
    Secunda
    Thanked: 360
    Pentafam
    Baie smart, jy sal meer details moet deel oor filter sisteem en waar jy gekoop het ens ens.
    2013 Toyota Hilux 3.0D4-D 4x4
    Bush Lapa 810 Miskruier
  22. #7495
    Feb 2019
    Gariepdam
    Thanked: 43
    Quote Originally Posted by Hilux01 View Post
    Pentafam
    Dankie Hilux
    Ek het by Little Luxury bestel,dit is die "4 stage cross country".
    Ek het n 3mm vlekvrye staal plaat vasgebout teen voorkant van ratel en toe twee "studs" vasgesweis op plaat,nou kan filter met twee "wingnuts" vasmaak.
    Ek het vloei getoets soos volg:
    Koue kraan en warm kraan is vloei 5lt/min.
    Warm kraan met stort kop aan,geyser kraan heel oop,dan sit pompie aan en af,druk is net daai bietjie te hoog saam met stortkop.
    Vloei is nogsteeds konstant en geyser bly aan,vloei net bietjie minder,dalk gebruik my gesin n bietjie minder water met stort.
    Hoop dit is n bietjie meer inligting.
  23. The Following User Says Thank You to Pentafam For This Useful Post:
  24. #7496
    Oct 2012
    otjiwarongo
    Thanked: 279
    Hi. BL is going in for a sercvice not at BL office in paarl but an agent in windhoek. What is stuff they must look at other than brakes coupler and wheel bearings?
    My wing i saw tear loose at the back just above the back door when open completely which is a concern as we havent camped in strong winds at all. My tap where u let water out of your tank broke off between our camp spot and home yesterday.
    The fridge also have an issue somtimes takes hours and hours to get to the set temp and the fridge have lots of id faults light flashing so ill have that checked as well.
    Anything else
    2017 VW Amarok 3.0 TDi V6 4Motion D/Cab
    2020 VW T Cross Highline R Line
    2019 Bushlapa Miskruier 1616
  25. #7497
    Sep 2008
    Port Alfred
    Thanked: 84
    Quote Originally Posted by hein100 View Post
    Anything else
    Check the mounting bolts for the leaf springs. Mine failed twice. Later BL models might have had bigger bolts fitted.
    Triton 3.2 A/T D/Cab 4x4 (EGR blanked, Remapped, 63mm zorst)
    BL Vlooi 295
    Platkar - Rav4
    Previously: Isuzu "LUV", Disco D1 TDi, KZ-TE
    A bad day in the bush is better than a good day at the office
  26. #7498
    Oct 2012
    otjiwarongo
    Thanked: 279
    Quote Originally Posted by dust-devil View Post
    I have a 2019 model but thx yes wil ask to check
  27. #7499
    Oct 2012
    otjiwarongo
    Thanked: 279
    Anything else
    Net nog n vraag? As n mens by huis kom.na n trip en plug hom in by krag dan charge hy batt of veronderstel om.weer vol te charge? Die sisteem is mos veronderstel om.die batt te onderhou en vol te laai?
  28. #7500
    Loevenstein, Bellville
    Thanked: 536
    Jip. Die charger laai die battery tot op 100% en hou dit daar. Dit is natuurlik as die charger nie by die DB afgesit is nie.
    Niel
    2012 BMW F800GS
  29. The Following User Says Thank You to Musashi For This Useful Post:
  1. 3 Bush Lapa Miskruiers in one spot!
    By Kooskop in forum Trailers, Caravans, Towing etc
    Last Post: 2021/02/26, 04:24 PM
  2. Project Venter Bush Baby: first impressions
    By coala in forum Trailers, Caravans, Towing etc
    Last Post: 2014/10/28, 06:57 AM
  3. Bush Lapa Miskruier featured in.....
    Last Post: 2011/10/03, 03:18 PM
  4. Kyknet Buitelug Expo - Bush Lapa range
    Last Post: 2011/09/29, 08:20 PM
  5. Performance mods on TD's
    By 280iNyati in forum Vehicle & Technical Chat - General
    Last Post: 2006/09/12, 10:39 AM
