Page 372 of 385 FirstFirst ... 122 272 322 347 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 ... LastLast
Results 7,421 to 7,440 of 7682
Thread: Bush Lapa mods
  1. #7421
    Jul 2017
    Dundee
    Thanked: 64
    Default Re: Bush Lapa mods
    Quote Originally Posted by Smiles View Post
    Okay, after a stressful time, the end product came out as planned.
    I wanted my dish washing area easy to open and close in my efforts of becoming a lazy pitching camper...
    I made a cassette unit that fits into the back and that is covered with a compartment with a door. This created a double sealing are and there will not be dust or water getting in.
    The cassette has a main drawer that pulls out and then the two sides pull out. First time I'm using "push to open" slides and they work great. Don't need latches, the drawer stays in place.
    Inside the top cover I have space to store all out dishwashing soap, sponges and cloths.
    I had to lift the basin and reroute the pipes, but its almost at a better height now than before.
    All stainless steel.
    I'm glad its over now
    Patent pending...
    Attachment 592332Attachment 592333Attachment 592334Attachment 592335Attachment 592336Attachment 592337Attachment 592338Attachment 592339Attachment 592340
    Hennie
    I must tell everyone that your workmanship is of top Quality. The draws you did for me, are fantastic. Thanks once again.
    I will be fitting them this week end. Can't wait for the next project that you are embarking on.
    Dave
    Dave
    BL1942 - The Bug
  2. The Following 3 Users Say Thank You to ohalloran For This Useful Post:
  3. #7422
    Jhb
    Thanked: 63
    Has anyone got a mod / idea on how to stop the spring rods on the pop our beds from popping out?
    We went camping this past week at the coast and had some very strong winds. The awning would vibrate and "lift up", and the spring polls would eventually pop out of the eyelet on the awning
    Bruce
    2010 Toyota Hilux 4x4 3.0D4D
    Bushlapa Miskruier BL15
  4. #7423
    Plett/Paulshof
    Thanked: 2052
    Quote Originally Posted by out of africa View Post
    I had same issue with one recently. I have decided to use bungee cord of correct length instead when this issue happens. I did bend the tip a bit which did help.
    Bruce Hunter
  5. #7424
    Thanked: 38
    How about cable ties to keep the eyelet in the rod?
    Hennie
    Toyota Legend 50
    Disclaimer: The views expressed by me in the above thread and replies are based on my personal experience and perceptions, which may be subjected to change from time to time.
  6. #7425
    Plett/Paulshof
    Thanked: 2052
    You need to keep the rod in the eyelet
    Bruce Hunter
  7. The Following User Says Thank You to BruceHun For This Useful Post:
  8. #7426
    Jhb
    Thanked: 63
    As an emergency hack I used guy ropes looped around the pole stickout with pegs in the ground. It worked ok but isn't an elegant solution.
    Bungees sound better and I think bending the tip would be the best option
    Bruce
  9. #7427
    Thanked: 38
    this works for me...Click image for larger version.
    Hennie
    Toyota Legend 50
  10. The Following 3 Users Say Thank You to Smiles For This Useful Post:
  11. #7428
    Jhb
    Thanked: 63
    Good idea, thanks
    Bruce
  12. #7429
    Thanked: 38
    Any ideas/suggestions to keep the stupid little awning poles above the horizontal poles in position in windy conditions?
    Hennie
    Toyota Legend 50
  13. #7430
    Plett/Paulshof
    Thanked: 2052
    mine fit tightly so no issue. If you use the guy ropes straight down by each pole this also prevents a potential problem.
    Bruce Hunter
  14. #7431
    Thanked: 38
    My ropes are strait down, awning is tight and the small poles are fitting snig, i sometimes struggle to push them back. Still when wind starts pushing and pulling they pop out.Click image for larger version.
ID:	593832Click image for larger version.
    Hennie
    Toyota Legend 50
  15. #7432
    Aug 2018
    Paarl
    Thanked: 308
    Why don't you put a horizontal pole from one small pole to the other.
    I will try and find a pic I saw
  16. The Following User Says Thank You to fatbike For This Useful Post:
  17. #7433
    Thanked: 7479
    Replace the rubber 'feet'. I see our new wing short poles has large feet made from quite a soft rubber compound. They grip the PVC patch better. The previous wing had the same as yours and one specific on always collapsed.
    Christa
  18. #7434
    Dec 2013
    Reebok, Mossel Bay
    Thanked: 90
    Velcro:
    Glue a square piece to the awning "roof".
    Cable Tie a larger piece to the plastic end to fit like a "glove".
    Herman Meyer.
    2014-01 Amarok DC 4Motion Auto , 2004-2014 Nissan HardBody 4x4 3.0TD DC
    2015-02-03: Bush Lapa Miskewer 394.
    2012-01 VW Polo Sedan 1.6 A/T.
  19. #7435
    Pretoria / Motopi Village, Northern Botswana
    Thanked: 416
    Quote Originally Posted by lekhubu943 View Post
    This works a charm...we recently purchased Miskruier No44 where BL were still experimenting with certain things...
    1. The upright poles had plastic end caps which males sliding the uprights into place very easy...and them collapsing in a slight wimd just as easy...replaced the end caps with rubber caps (such as the ones on a walking stick) and they grip so well now...
    2. The down poles of the awning were loose poles, purchased the hinges from BL in a full kit @ +-R650 and fitted them myself now making the whole awning setup a lot more sturdy...no more downpoles randomly falling out when tensioning the awning or wind blowing...guide ropes must be straight down too and not at an angle like tradisional tent ropes...
    Just my 2c worth...
    God bless
    Trev
    2018 2.8 Gd6 Hilux DAKAR with extras
    2012 Bushlapa Miskruier
  20. #7436
    Struisbaai
    Thanked: 928
    Quote Originally Posted by fatbike View Post
    I also bought rubber feet for office chairs at the local hardware.Rubber is fairly soft and grips nicely on the awning.
    Make sure its the rubber ones and not the plastic feet.
    2015 Land Cruiser 79 D/C V8 Diesel Turbo
    2000 Prado 90 KZTE SWB.
    Bush Lapa Boskriek No 607 - Die Kriek
  21. #7437
    Apr 2008
    Secunda
    Thanked: 373
    We also had some concerns in really bad conditions
    However, my issue was rather with the other "short uprights" not having PVC patches on the awning and the pinch marks/ "indentations" that the poles left on the direct canvas
    I thus cut some tennis balls in half and use them specifically on these areas - works like a charm - I think firstly because it stretches the wing that little more, has a larger and "rougher" bearing surface (the tennis ball) and it takes no added time as they go on when ever I put the uprights in - right out of the bag
    Swambo even suggested I glue the cut tennis balls on the poles, but that might not be a long term in bag solution...
    Camping this weekend will post a pic then
    2013 Toyota Hilux 3.0D4-D 4x4
    Bush Lapa 810 Miskruier
  22. The Following 2 Users Say Thank You to Hilux01 For This Useful Post:
  23. #7438
    Thanked: 12
    Our wing is quite old and lost its original shape; also got tired of puddles forming in the rain, so I bought some polycop water pipe and re-shaped it to proper dome again. Have not looked back yet.
    Rion
    Dakar: Tuna
    Dahouse: Miskruier B129
    Dafun: Camping/Swimming/Hikes/Offroad
  24. The Following 4 Users Say Thank You to rionf For This Useful Post:
  25. #7439
    Dec 2016
    Thanked: 90
    Hi
    Ek wil Al-Co Steadies voor onder my Baobab sit.
    Daar is 2 grootes beskikbaar 410/590 en 510/740
    Ek sien party mense sit die steady uit, geruit af. Vertikaal. Ander sit dit effens skuins, skat so 20/25 grade van vertikaal af. Wat werk die beste?
    Vertikaal dan moet ek die korter een vat. Effe skuins dan moet ek dalk die langer een vat.
    Advies sal waardeer word.
    Dankie
    Hugo
    Hugo Burger
    Ranger 3.2
    Baobab 1796 "Boom Huis"
  26. #7440
    Thanked: 2928
    Op die Baobab kan jy die langer een sit. Die enigste rede hoekom die korter een op die Goggas kom is omdat sy a-raam nie genoem plek het om die langer een horisontaal op te vou nie. Skuins na voor staan is die beste vir stabiliteit.
    Disclaimer - All my posts on this forum is without prejudice, is based on my fair assumptions or perceptions, might not be factually correct, is in no way intended to cause harm to anyone and is acted upon at your own discretion.
  27. The Following User Says Thank You to George For This Useful Post:
    OdM
  1. 3 Bush Lapa Miskruiers in one spot!
    By Kooskop in forum Trailers, Caravans, Towing etc
    Last Post: 2021/02/26, 04:24 PM
  2. Project Venter Bush Baby: first impressions
    By coala in forum Trailers, Caravans, Towing etc
    Last Post: 2014/10/28, 06:57 AM
  3. Bush Lapa Miskruier featured in.....
    Last Post: 2011/10/03, 03:18 PM
  4. Kyknet Buitelug Expo - Bush Lapa range
    Last Post: 2011/09/29, 08:20 PM
  5. Performance mods on TD's
    By 280iNyati in forum Vehicle & Technical Chat - General
    Last Post: 2006/09/12, 10:39 AM
