Bush Lapa mods - Page 368
Page 368 of 371 FirstFirst ... 118 268 318 343 358 359 360 361 362 363 364 365 366 367 368 369 370 371 LastLast
Results 7,341 to 7,360 of 7404
Thread: Bush Lapa mods
  1. #7341
    Jul 2020
    Swakopmund
    Default Re: Bush Lapa mods
    you so right, the anticipation is definitely running high. Battling to get any info on the status of the trailer build/delivery is making matters worse. Think I read about every page of the thread and have been able to pick up a lot, but thank you for the offer.
  2. #7342
    Jul 2020
    Swakopmund
    <img src="images/smilies/grin.gif" border="0" alt="" title="Grin" smilieid="26" class="inlineimg">&nbsp;you so right, the anticipation is definitely running high. Battling to get any info on the status of the trailer build/delivery is making matters worse. Think I read about every page of the thread and have been able to pick up a lot, but thank you for the offer.
  3. #7343
    Oct 2006
    Pretoria (Rietvalleirand)
    Thanked: 86
    Inverters
    Boabab owners, please tell me where you mounted your inverters.
    Looking for some ideas to permanently mount mine with the shortest possible cable route.
    Johan
    Pajero Gen 4 GLX 30 Year Heritage Edition - Grondpad
    VW Tiguan 2.0TDi - Teerpad
    Bushlapa Boabab 4.2 in tow
  4. #7344
    Loevenstein, Bellville
    Thanked: 427
    Quoted below is a mod I did almost a year ago.
    Quote Originally Posted by Musashi View Post
    This is not a Bush Lapa specific mod but something I thoroughly enjoyed building.
    We always have a mercury type thermometer in the caravan which also shows the minimum and maximum temperature. I love seeing how hot/cold it is and was. Well now we're replacing it with an electronic unit in the caravan which shows inside temperature, minimum, maximum and humidity, as well as the same for a mobile external unit (communication is wireless). For now I mounted it above the door as the DB doesn't have space but I may move it if I find a better spot. Attached are some photos (excuse the quality - bad lighting).
    I upgraded this mod by designing and 3D printing a neat panel (looks much better) and replacing the external unit with a waterproof sensor connected by cable (less hassle to take out and plug in and more reliable communication).
    I want to give the panel a neat coat of paint but need to match the colour well.
    Niel
    2012 BMW F800GS
  5. The Following User Says Thank You to Musashi For This Useful Post:
  6. #7345
    Jul 2017
    Dundee
    Thanked: 54
    Quote Originally Posted by Smiles View Post
    A while back I decided to fit 2 drawers in the kitchen. So to the drawing board, laser cut, paint, assemble and install...
    Installed it today.
    Used Stainless steel.
    Pleased with the result.
    Attachment 581504Attachment 581505Attachment 581506Attachment 581503Attachment 581508
    Hi Hennie
    I have been out of touch a bit.
    My details if you can email me. [email protected]
    Dave
    Dave
    BL1942 - The Bug
  7. The Following User Says Thank You to ohalloran For This Useful Post:
  8. #7346
    Jan 2018
    Harare
    Thanked: 391
    Quote Originally Posted by LowRange View Post
    Inverters
    Johan
    Hi Johan
    We have a modified Baobab, was a 4 sleeper but removed side bed and had in converted to a Baobab "Kewer" design. We had a 500w inverter factory fitted at production stage. Bushlapa mounted the inverter under the seats where the batteries are fitted. From there a cable leads to a power point on the shelf next to the bed. This is a very short cable and works well. Unfortunately I can't send you photos as we are stuck in Australia while this Covid thing is on. Hope that makes sense.
    Cheers John
    John 2014 Toyota Hilux 4x4 3.0 D4D
    Baobab BL1715 "Kamba"
    "I never knew of a morning in Africa when I woke up and was not happy" - Ernest Hemingway
    Kgalagadi 2019 Namibia 2019 Gonarezhou 2019 Mana/Tafika 2018 Kgalagadi 2017 Lion, Hippo, Eland Leguaan, Python
  9. The Following User Says Thank You to Tedx2 For This Useful Post:
  10. #7347
    Jul 2017
    Dundee
    Thanked: 54
    Quote Originally Posted by Tedx2 View Post
    Hi Johan
    Cheers John
    Hi Johan
    On my BL 1942 being a Kewer, I installed the inverter in the back hatch, I moved the battery from the Back to the front, gave me extra space to put a few small items.
    I ran the Inverter via the Shunt, then to a Circuit breaker which I added onto the DB, from there to one of the 3 plugs that are on the outside. I also installed a remote switch which I will add onto the DB, that will be to switch the Inverter on and Off. Just waiting for the switch to arrive.
    Pictures below.
ID:	584913   Click image for larger version.
ID:	584914   Click image for larger version.
ID:	584915   Click image for larger version.
ID:	584916   Click image for larger version.
Name:	Shunt in the BL.jpg
    Dave
    BL1942 - The Bug
  11. The Following User Says Thank You to ohalloran For This Useful Post:
  12. #7348
    Plett/Paulshof
    Thanked: 1130
    Quote Originally Posted by ohalloran View Post
    Hi Johan
    Pictures below.
    Good info Dave, thanks. Just unsure why moving battery to the front box was necessary? Surely same size for front and back box? I am leaving the front box empty and fitting the battery a 200ah Lifepo4 plus inverter in the back box. Front box for additional storage. Also better to keep cabling as short as possible.
    Bruce Hunter. 2020 FJ Cruiser, 2020 Audi Q5S Tdi, 2019 VW Tiguan 4motion 2.0tsi(work vehicle), 2019 FJ Cruiser, Bush Lapa Kewer 2202, Fusion 17 boat-Yamaha FT100hp 4st.
  13. #7349
    Jul 2017
    Dundee
    Thanked: 54
    HI
    Batteries fitted in the front, as it is slightly bigger. When I moved the battery, I did not need to extend any cabling, Also when they are dead I will replace with a Li-on.
    The Cable for the Inverter both Neg and pos are the same length and used a 26mm cable 1700mm long. I also have and extra MPPT Controller in the front box for my mobile Solar panel. I have installed the BH by the 220 input plug.
    Dave
    BL1942 - The Bug
  14. The Following User Says Thank You to ohalloran For This Useful Post:
  15. #7350
    Plett/Paulshof
    Thanked: 1130
    I used to use the grey BH on the A frame, the car charge cable for my fold up extra solar panel which has an mppt on it. This was for when BL was in shade. It is a 140w panel. I don't use the car cable for charging whilst driving, let my 300w roof panel do that.
  16. #7351
    Jul 2017
    Dundee
    Thanked: 54
    I also use the PV to charge whilst Driving.
    Another Mod or Change I did was to put a new Table Mount Bracket on my Slider. This is the proper mount, imported from USA, as not made in RSA.
Name:	Table Wall mount.jpg
ID:	584923   Click image for larger version.
Name:	Table wall mount OLD.jpg
ID:	584924   Click image for larger version.
Name:	Wash Basin Stand 2.jpg
    Dave
    BL1942 - The Bug
  17. The Following 2 Users Say Thank You to ohalloran For This Useful Post:
  18. #7352
    Clanwilliam
    Thanked: 24
    Good day to all the BL owners.
    Quick questions on the Al-Ko corner steadies.
    I see some of people installing it on the T of the frame and not on the corner? With the steadies then only being a meter apart how much do they help?
    Why would you not install it on the corner? Is the frame to weak at this point? It would obviously provide the most stability at this position.
    And lastly if you do not install it on the corner do you have a modified spanner to extend it as a normal Cross-spanner will not work.
  19. #7353
    Apr 2017
    Thanked: 8
    Quote Originally Posted by HiluxRoux View Post
    Hi Hilux. I've rather have 4 stabilizers instead of just the two at the back, one on each corner. No Alkos.. I can be struck by hurricane Catrina and wouldnt feel it.
  20. #7354
    Thanked: 2343
    Arrow Re: Bush Lapa mods
    The T is just much stronger. At the corners might add marginally more stability, but it does the job perfectly at the T. It ain't moving anywhere.
    A normal 4-point wheels won't work. You need the caravan lever or one of those foldable wheel spanners usually found in car spare wheel kits. I found one lying in the garage and it works perfectly.
  21. #7355
    Clanwilliam
    Thanked: 24
    Thanks yeah took a second look and the T is not that far of the corner in anycase. I will just have to improvise a spanner with a long reach. Thanks again
  22. #7356
    Plett/Paulshof
    Thanked: 1130
    Do the Alko's not come with the tool?
  23. #7357
    Aug 2015
    Roodekrans
    Thanked: 69
    Hi Bruce
    My Alko voor steady's is op die hoeke en geen tool by gekry nie. Ek gebruik wheelspanner. Maar dit is maklik omdat hulle op die hoeke van die ratel is.
    Stefan
    2018 Toyota Hilux V6 auto 4X4 double cab with a few extra's
    2019 Bush Lapa Ratel 4
    2019 BMW X1 M-Sport 2.0D (Swambo platkar)
    2018 Toyota Etios Sprint (daily platkar drive)
    2017 Ford Ranger 3.2 auto 4X4 double cab - sold
    2016 Volvo V40 D4 Geartronic - sold
    2008 Gypsey Gold Caravan - sold
  24. The Following User Says Thank You to 4x4Superman For This Useful Post:
  25. #7358
    Jul 2019
    Thanked: 94
    Mine did.
    Bush Lapa fitted the Alkos at the T for strength- there isn't a huge difference between the T and the side in any event.
    Toyota Fortuner 2.8 GD6 4x4 AT - Shadowfax
    Bush Lapa - iKewer - Dogmatix
  26. The Following User Says Thank You to Voyageur For This Useful Post:
  27. #7359
    Clanwilliam
    Thanked: 24
    Quote Originally Posted by Voyageur View Post
    Mine did.
    Yeah I think all steadies comes without a tool. As BL fitted yours they probably supplied the tool.
    A friend with a commader had his fitted by conqueror and also got no tool.
    If its fitted at the corner than a normal cross spanner will do. But at the T the 30 or so cm will require a specialist tool.
  28. #7360
    Thanked: 2343
    This is the tool I use.
  1. 3 Bush Lapa Miskruiers in one spot!
    By Kooskop in forum Trailers, Caravans, Towing etc
    Last Post: 2019/12/29, 07:25 PM
  2. Project Venter Bush Baby: first impressions
    By coala in forum Trailers, Caravans, Towing etc
    Last Post: 2014/10/28, 06:57 AM
  3. Bush Lapa Miskruier featured in.....
    Last Post: 2011/10/03, 03:18 PM
  4. Kyknet Buitelug Expo - Bush Lapa range
    Last Post: 2011/09/29, 08:20 PM
  5. Performance mods on TD's
    By 280iNyati in forum Vehicle & Technical Chat - General
    Last Post: 2006/09/12, 10:39 AM
