Bush Lapa mods - Page 352
Page 352 of 361 FirstFirst ... 102 252 302 327 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 LastLast
Results 7,021 to 7,040 of 7216
Thread: Bush Lapa mods
  1. #7021
    Default Re: Bush Lapa mods
    Quote Originally Posted by Kooskop View Post
    Hi David. I just checked with Martin at Bush Lapa and he confirmed that it will not be an issue on the Miskruier. You can fit the 285/70R17 KO2.
    Thanks Michael. I appreciate the quick phone call. Now to source some new BFG KO2's in that size without having to go to Namibia!
    David Killough
    2016 Landcruiser 200 GX-R
    1995 Landcruiser (UK Spec) SOLD
    Bushlapa Miskruier 321
    www.killoughfamily.com
  2. #7022
    Jul 2017
    Dundee
    Got mine back on Friday and I must say the alu plates up front are installed extremely professionally and way better than if I did it myself. I'd think BL could to add that as standard.
    Hi
    I somewhat agree with you, they should make it standard.
    Dave
    Dave
    BL1942 - The Bug
  3. #7023
    Jul 2017
    Dundee
    I Have sent a mail to BL asking why it is not included in the Build, If one whanted to add it after the fact, it is quite a bit of work.
    Makes sense to just include it, also look nice.
    Dave
    Dave
    BL1942 - The Bug
  4. #7024
    PE & North Africa
    Some tow vehicles are very kind to the Bush Lapa following behind them. I took precautions but the Hilux caused minimal damage to my 2 Miskruiers over 7 years but in less than a year, the FJ was like a demon trying to destroy this thing behind it...
    Very true! I think the "kortgat" vehicles tend to chuck more stones and then of course what type tyres you have make a difference.
    I recently changed my stone protections setup, as I previously had a horizontal canvas between the Fortuner and BL. This worked great but was a little bit of a hassle.
    So I made up some large mudflaps hanging from brackets on the chassis that are easy to remove. This stops almost 95% of the stones I would say. We did some bad gravel and gravel at speed (80-90) last week, and I did not get a single chip on the edges of the Baobab, that are still exposed while I am waiting for my new cover.
    More important, I did not hear one stone hit the rear window, so this tells me the flaps are really doing the work.
    Grumbles
    2008 Fortuner 3.0 D-4D 4x4 "Sushi the Tuna"
    2018 Baobab 4 - B1543 "Nala"
    Bacon fact #16 - Bacon is Healthier than Crystal Meth!
  5. #7025
    Quote Originally Posted by observer View Post
    Is the MPPT (75/15) just a straight swap out of the old PWM?
    What are the main benefits? More efficient charging?
    I've been in contact with Martin from Bush Lapa and to upgrade to a Victron MPPT 75/15 on a NEW order would be around R1,200 since they credit you with the value of the PWM controller. If they do the upgrade on an existing van, you will be looking at around R1,800 for the Victron MPPT 75/15 and R300 labour (excl. VAT). I suspect the other price mentioned included an upgrade of the control panel as well.
    There has also been some questions here around the controllers and I am clueless when it comes to these things...so if you have any questions on the below feedback Martin got directly from Victron, you will have to contact him yourself....
    The first number, 75 or 100, is the maximum open circuit voltage (Voc) from the panel (as found on the label). Typically this would be 20-40V but will increase if you connect panels in series (add all the panel voltages to get the total)
    If this is exceeded, you WILL damage the controller
    The second number, 15, 20 or 30, is the output current (Amps). This can be used to calculate which controller must be used given the panel power. Use this number multiplied by 14 (Battery voltage during bulk charge). E.g. for the 75/15 model: 15 x 14 = 200W. If the panel power exceeds this value, it will NOT damage the controller, but the extra power will be wasted
    Toyota FJ Cruiser
    BMW F800GS
    When in doubt, paint it black
  6. #7026
    Jan 2011
    Just check one thing.
    You get the normal BlueSolar 75/15 (no Bluetooth) and then you get the SmartSolar 75/15 that has Bluetooth. Latter much better in my opinion and about R400 or so more IIRC.
    2017 Toyota Fortuner 2.8 GD6 4x4 iMT
    2016 Hyundai Tucson 1.6 T-GDi
    2019 Bush Lapa Miskruier BL1861
  7. #7027
    Jul 2017
    Dundee
    Quote Originally Posted by Grumbles View Post
    Grumbles
    Hi
    I like that MOD, how did you fit them to the Car
    Dave
    Dave
    BL1942 - The Bug
  8. #7028
    Jul 2017
    Dundee
    Quote Originally Posted by ohalloran View Post
    Hi
    Dave
    Hi I spoke to Loftus at BL re the Checkered Plate, why not standard. He said it is a personal taste, some guys take the Gas geyser and others don't.
    Dave
    Dave
    BL1942 - The Bug
  9. #7029
    PE & North Africa
    Hi
    Dave
    Like so Dave.
    Each Flap attaches to the hanger with two locknuts, takes 30 secs to remove for town driving.
    Hangers are 4mm steel... overkill but they won't move IF they BY CHANCE touch something during hectic offroading.
    The flaps are attached to angle/equal iron.
    Only thing is one has to be careful when reversing in rough terrain so as to not get a stone to jam the flap under a wheel. I put them very close to the wheels because my Fortuner chucks stones at a very steep angle.
    George on the forum did some nice ones for his Disco, that hang off the towbar. Every car will be different.
    Grumbles
ID:	541324   Click image for larger version.
ID:	541325   Click image for larger version.
ID:	541326   Click image for larger version.
ID:	541327   Click image for larger version.
ID:	541328   Click image for larger version.
  10. #7030
    Jul 2017
    Dundee
    Like so Dave.
    Grumbles
    Is That’s a great idea. Thank you.
    Dave
    BL1942 - The Bug
  11. #7031
    PE & North Africa
    So been busy with a few other mods... as you camp obviously you come across things that might just make life easier in your BL. (Not that its not easy enough )
    One of these mods I have not seen anywhere, maybe I missed it, but I thought about it last week whilst sipping a cold one in the middle of the Baviaans.
    There have been many discussions on how to prevent the wing poles from folding inward if a gust of wind raises the wing.
    Think I found the solution... so I am claiming it and sharing
    So the other mods I have done are as follows...
    1. Hooks on pop-up roof bar to hang towels when it is damp/cold/wet outside.
    2. Hooks at Baobab entrance, perfect for car keys and BL keys and hats.
    3. Replaced the internal clamps on the wing poles with external clamps... work great.
    4. Then... I used Folding Stays (or Flap Up/Down hinges) like the ones on camping tables / chairs, to lock the pole in position!!
    Anyway, enjoying the Baobab more every time we take her out!
    Grumbles
ID:	541374   Click image for larger version.
ID:	541375   Click image for larger version.
ID:	541376   Click image for larger version.
ID:	541377   Click image for larger version.
ID:	541378   Click image for larger version.
ID:	541379   Click image for larger version.
  12. #7032
    Jul 2017
    Dundee
    Grumbles
    OOOO Dear I like the Pole Mod, External Clamps. I am goinf to do that, thats if you don't mind.
    Dave
    Dave
    BL1942 - The Bug
  13. #7033
    Wartburg.
    Ek ook, daai internal clamps werk nie vir my nie.
    Waar kry jy daai clamps van Grumbels?
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
  14. #7034
    PE & North Africa
    Hier by ons in PE by East Cape Caravans / Campworld.
    Hulle het takke orals, net ander name?
    Ek dink meeste groot karavaan plekke sal hê, nie seker of ODW het nie.
  15. #7035
    These pictures are for David (Voyageur) since I cannot send pics via PM.
    David, as discussed, this is what I do with the protector when not in use and while camping. This gives you access to the nose cone and the whole setup remains attached to the Miskruier.
ID:	542144   Click image for larger version.
ID:	542145   Click image for larger version.
    Toyota FJ Cruiser
    BMW F800GS
  16. #7036
    Rondebosch
    Default Re: Bush Lapa mods - Fridge drawer support pole.
    Thought you guys may be interested in this mod.Got BL to make me a drawer support with a telescopic pole (as used on Bush Wing) for fridge drawer.Fits into a hole drilled underneath.Works like a charm - especially with two boys under 5 years old!
  17. #7037
    Upington
    Quote Originally Posted by Jetlagster View Post
    Gonna make me one of those, thanks. Together with a little piece of plank, it should work in soft sand as well.
    Mitsubishi Triton 3.2 Di-D 4x4 Auto with a Bush Lapa Miskruier (#30) following closely behind.
    In the process of going there and doing that.
  18. #7038
    PE & North Africa
    Not really a new mod... many have done something similar, but after our last very rough excursion, I made a divide behind the fridge so that the few loose items I store on the right hand side don't fall into and the area between the fridge rails.
    Also gives space for air circulation at the fridge intakes.
    Then added some clips for my mop and broom.
    Grumbles
    PS: It is removable by taking off 4 x locknuts, in the event I need to crawl in there to unplug the fridge etc.
ID:	542851   Click image for larger version.
  19. #7039
    Grumbles
    I like the mop and broom idea! I have the full length nose cone and keep mine in there. It can be a mission sometimes to dive it out under all the "stuff" I keep in there...
    Toyota FJ Cruiser
    BMW F800GS
  20. #7040
    Plett/Paulshof
    Grumbles
    What/where are the mop and broom for? for awning maybe before packing up?
    I use a chamois and small brush and pan for quick cleaning.
    2016 LC 200 VX, 2014 D4 SDV6 HSE(sold),2015 Suzuki Jimny, 2019 VW Tiguan 4mtion 2.0tsi(work vehicle), "A little Red Car", Swambo 2013 A3 Sportback Quattro, Bush Lapa Baobab 1873, Fusion 17 boat-Yamaha FT100hp 4st.
  1. 3 Bush Lapa Miskruiers in one spot!
    By Kooskop in forum Trailers, Caravans, Towing etc
    Last Post: 2019/12/29, 07:25 PM
  2. Project Venter Bush Baby: first impressions
    By coala in forum Trailers, Caravans, Towing etc
    Last Post: 2014/10/28, 06:57 AM
  3. Bush Lapa Miskruier featured in.....
    Last Post: 2011/10/03, 03:18 PM
  4. Kyknet Buitelug Expo - Bush Lapa range
    Last Post: 2011/09/29, 08:20 PM
  5. Performance mods on TD's
    By 280iNyati in forum Vehicle & Technical Chat - General
    Last Post: 2006/09/12, 10:39 AM
