Page 131 of 382 FirstFirst ... 31 81 106 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 156 181 231 381 ... LastLast
Results 2,601 to 2,620 of 7630
Thread: Bush Lapa mods
  1. #2601
    Feb 2013
    Thanked: 304
    Bennie, during our December 2014 Namibia trip there were a couple of places we camped where we relied on the solar panel to keep the battery (1x lead acid deep cycle) fully charged. At Epupa the van was parked in semi shade with the result that the battery was flat within 2 days. At both Spitzkoppe and Klein Aus the van was parked in full sunlight and we had no issues to keep the battery charged. The fridge is a Snomaster 72litre with the small side set at -10 and the big side at +3. We used the LED lights very sparingly at night. I would suspect that you may have a problem with either the solar panel not being connected correctly and thus not supplying full charge, or the charger being faulty, or your batteries dead.
    Bush Lapa Miskruier: B116
  2. #2602
    Sep 2013
    Thanked: 24
    Quote Originally Posted by HJB01 View Post
    Your setup sounds the closest to mine with that Snomaster. I can't dare to go to -10, my snowmaster will start beeping very soon quickly. Organising a trip to BL for a checkup on the connections, but am still considering a second battery. Even if it means replacing the previous one (new and new, instead of old and new) which may have gotten previous damage.
    Fortuner 4x4 4L V6 aka "Tunafish" aka "Guzzler"
    Bushlapa Vlooi #B212 aka "FLOSSIE"
    Glamper, Rock Climber, Hiker, Diver, Rescue Medic, Professional and Volunteer Wine Tester.
  3. #2603
    Jun 2008
    Default Dave
    Hi Guys - Any Suggestions :
    On my last trip to the Game Reserve I noticed the voltage on the BMV climbing to above 16,3v so I disconnected the Solar Panel - tested it the next day and it did the same - voltage on the BMV started to register above 16v.
    HCdP checked out the unit , but the problem never went away - disconnected the solar panel after voltage started to climb above 16v on the BMV - sent the HCdP in a second time for checking, Johan from HCdP has tested it and cannot find any fault with the unit.
    Will trickle charge the 2xDeltec Batteries before collecting the unit from HcdP on Monday - any suggestions on what I should do or have checked at HCdP to solve the problem.
    Bush Lapa Muskrier is fitted out with the following :
    HCdP Mk3c - 180Watt Solar Charge Controler
    1 x 130Watt Monocrystaline Solar Panel
    2 x 105Ah Deltec Deep Cycle Batteries
    Victron BMV 600S Battery Monitor
    Many thanks in advance
  4. #2604
    hermanus
    Ctek dc to dc 250 will solve all yr charging problems...
  5. #2605
    Upington
    Thanked: 72
    The MCdP Mk 3 already have everything you need for a dc to dc charge. Just install a cable from the towing vehicle's battery to the BL.
    Mitsubishi Triton 3.2 Di-D 4x4 Auto with a Bush Lapa Miskruier (#30) following closely behind.
    In the process of going there and doing that.
  6. #2606
    Thanked: 135
    Quote Originally Posted by Klaxon of Africa View Post
    Well done Romeo , that looks like Andre's unit , the mods are certainly improving . I understand your order book is closed because of work in Botswana
    Hi everyone, sorry for responding so late...we are very busy and don't always have time available to respond. NO our books will never be closed, however we do go through very busy periods ( especially the last minute requests prior to holidays)
    We are always willing to help asn squeeze in another order.
    2009 D3 V8 SE - Family car, holiday and weekends
    2009 Mahindra Scorpio 2.6 GLX - Mom's Taxi
    2001 Ford Ranger 2.5 D/C - My Car
    2007 D3 TDV6 S - Family car, holiday and weekends ( RELUCTANTLY SOLD )
  7. #2607
    Sep 2014
    Rustenburg
    Thanked: 9
    Hi almal.
    Hoeveel volts en amps op vol son kan die pannel lewer.
    Monocrystaline Solar Panel 130watt
  8. #2608
    hermanus
    The absolute maximum i get from my 180 watt panel is less then 6 amps...
  9. #2609
    hermanus
    A good charger is as important as a good solar panel...a better charger will get you a higher output...
  10. #2610
    Hillcrest
    Thanked: 9600
    Quote Originally Posted by maxibelgium View Post
    Which may or not be a good thing.
    ZS5KAD - PROFFESIONAL DUMBASS
    3 Land Rover V8's
    NA - TwinTurbo - SuperCharged
    A V6 and an inline 4
  11. #2611
    Hillcrest
    Thanked: 9600
    Without the voltage that is meaningless.
    What is the current at the 12V side after the charge controller?
    It should be a lot more than 10A under reasonable conditions.
    3 Land Rover V8's
  12. #2612
    hermanus
    What are ideal conditions? Correct angle, no shade, correct position to the sun..
    How long does that last?
    Sun is moving constantly, bl not...and...i want to be on the shade...{last week near etosha we had 43°}
    My last motorhome in Europe had 300 watt panels in total...maximum i could get was 11 to 14 amps (with a very expensive regulator)
    also: How many amps do you need? Nat luna needs on full power 4,5 and runs 50 % on a 24 h base
    Make your calculation..
  13. #2613
    Sedgefield
    Thanked: 97
    Red face Ronald
    see my generator is starting to look not bad hey !
  14. #2614
    Thanked: 123
    Quote Originally Posted by Jorrie Jordaan BL87 View Post
    Hi almal.
    Jorrie, as a layman in this field I look at the specs of the solar panel.
    http://www.lowenergydevelopments.com...onocrystalline
    If you take the power (W) of the panel and devide this by the power voltage (V) of the panel you get the current(A).
    Thus 130/18 = 7 A (per hour)(in ideal loading conditions)
    Ps 16:5
  15. #2615
    Hillcrest
    Thanked: 9600
    mmmm
    3 Land Rover V8's
  16. #2616
    Aug 2014
    Thanked: 37
    Question Front stabiliser mounting bracket
    Hi All
    Martin and myself worked on a way to mount the front stabiliser on the A-frame of the Bush Lapa. Here is what we came up with:
Name:	2015-03-01 07.59.37.jpg
Name:	2015-03-01 08.00.05.jpg
Name:	2015-03-01 08.00.18.jpg
Name:	2015-03-01 08.00.27.jpg
Name:	2015-03-01 08.01.33.jpg
Name:	2015-03-01 08.01.08.jpg
Name:	2015-03-01 08.01.46.jpg
    Kudus to Martin for manufacturing and fitting the bracket in a very short time. The Bush Lapa crew as always gave excellent service.
  17. #2617
    Aug 2014
    Thanked: 37
    Default Back tap plumbing to wash basin
    Here is my 'plumbing' attempt to connect the two back taps to the wash basin:
Name:	2015-03-01 08.03.56.jpg
    In the picture above is the complete system assembled. The top section uses standard 'Gardena' hose connectors to connect to the taps for easy attachment and removal.
Name:	2015-03-01 08.09.57.jpg
    Picture above shows how the piping runs without the wash basin.
Name:	2015-03-01 08.04.07.jpg
    The front section can rotate to ease the wash basin removal,
Name:	2015-03-01 08.04.25.jpg
    and to allow filling of other containers.
Name:	2015-03-01 08.06.21.jpg
    The front section is also threaded to allow the attachment of the shower head.
Name:	2015-03-01 08.07.37.jpg
    It's handy for us to have the shower in the tent to clean dirty little feet and other bits at night.
Name:	2015-03-01 08.07.58.jpg
    The shower head has adjustable spray options.
Name:	2015-03-01 08.09.02.jpg
    The tap attachment was constructed using standard 15.00 mm irrigation connectors and piping.
Name:	2015-03-01 08.09.09.jpg
    The shower system was made using standard plumbing flex piping and off the shelf shower head. The same system also connects directly to the geyser in front.
    Toyota Prado 4.0VX
    Bush Lapa Ratel #B740
  18. #2618
    Lynnwood, Pretoria
    Thanked: 143
    Nice mods Charl.....
    Groete
    Harry
    BL Vlooi # 195 aka Jakkalas
    Lexus LS 470
    BMW 1150 GS Adv
  19. #2619
    Thanked: 45
    Quote Originally Posted by CharlLaas View Post
    Hi All
    Very nice. Can you buy the bracket or was it custom made?
  20. #2620
    Aug 2014
    Thanked: 37
    I can't speak for Bush Lapa, but I'm sure they will be happy to make more of these brackets.
    Toyota Prado 4.0VX
  1. 3 Bush Lapa Miskruiers in one spot!
    By Kooskop in forum Trailers, Caravans, Towing etc
    Last Post: 2021/02/26, 04:24 PM
  2. Project Venter Bush Baby: first impressions
    By coala in forum Trailers, Caravans, Towing etc
    Last Post: 2014/10/28, 06:57 AM
  3. Bush Lapa Miskruier featured in.....
    Last Post: 2011/10/03, 03:18 PM
  4. Kyknet Buitelug Expo - Bush Lapa range
    Last Post: 2011/09/29, 08:20 PM
  5. Performance mods on TD's
    By 280iNyati in forum Vehicle & Technical Chat - General
    Last Post: 2006/09/12, 10:39 AM
