Results 1 to 10 of 10
    Default 1uz conversion: cooling
    Hi
    I am in the process of replacing the 2L-TE in my LJ78 with a 1UZ-FE. The conversion is going pretty well and I now need to start looking at the cooling system.
    My thoughts are to replace the standard 2L-TE radiator with something a little larger as from what I have read there can be some cooling issues. Does anyone have any suggestions as to what radiator I should be looking at using? As I am using 1UZ's auto box, I will also need either an integrated oil cooler (like the 2L's radiator) or an external one.
    Or, more importantly perhaps, does anyone know where is a good place in the Gauteng area to source radiators / oil coolers / fans / hoses / etc?
    Aug 2010
    Centurion, Pretoria
    Thanked: 119
    PM sent..
    2011 Freelander 2 SD4 HSE AT.
    2016 Campmaster Compact 100 trailer.
    Nigel
    Thanked: 2637
    Just make 100% sure that the pitch on your radiator fan is in the right direction. MillaS had a problem on that one.
    Uniglide
    +27 zero eight 2 four 95 9252
    Sorry if this is a stupid question, I just want to make sure I understand. By pitch do you mean the angle of the fan relative to the radiator, or the pitch of the blades? I'm assuming the latter, as I would expect the radiator fan to operate best when the air flow is directly through it. In that case do you know what the optimum blade pitch should be?
    Nigel
    Thanked: 2637
    MillaS bought a LC71 with a 1UZFE motor. The thing had overheating issues. The when he looked closely, he saw that the fan blade itself was the wrong blade. The blades were pitched in the wrong direction. It was blowing in stead of sucking.
    Uniglide
    I guess that can happen if you mount the fan the wrong way around. It is definitely something I'll check when I find a radiator and fan. I am going to some scrap yards as my first point of call. If I don't come right there I might just import something as the prices I have seen online are very reasonable.
    Hillcrest
    Thanked: 8514
    Quote Originally Posted by germondc View Post
    Mmmm
    ZS5KAD - PROFFESIONAL DUMBASS
    3 Land Rover V8's
    NA - TwinTurbo - SuperCharged
    A V6 and an inline 4
    Kathu
    Thanked: 4185
    Do not try and save money on a radiator. I doubt if the 2.4 radiator will be enough for the Lexus. Get your self a big fat alu radiator from one of the V8 shops ( Talk to Swanie of THE V8 SHOPPE 0118695153). Also get yourself decent electric fans ( Swanie stock them as well ). The ones you buy at Midas are no good. 4X4`s move slow during off road conditions with basic no air flow generated by the moving vehicle. So having a potent cooling system is a must. Money now spend is money saved later.
    Thanked: 70
    Read this post again, lots of very important advice given.
    Thanks very much for the reply and good advice. I will definitely get hold of Swanie. Thanks again.
  1. Overland Journal Portable 12V Fridge Review
    By ChrisH in forum Camping, Fridges, Accessories
    Last Post: 2011/11/30, 11:26 AM
  2. 1UZ Lexus into 96 Cruiser GX 4.2
    By EtienneSA in forum Vehicle & Technical Chat - General
    Last Post: 2011/01/30, 07:50 PM
  3. hilux 1uz conversion and transmissions
    By shorecreature in forum Toyota
    Last Post: 2010/07/27, 04:30 PM
  4. Lexus V8 conversion for 96 Cruiser GL 1HZ
    By EtienneSA in forum Toyota
    Last Post: 2010/04/16, 12:02 AM
  5. SJ410 Coil suspension conversion
    By Santana SJ410 in forum Suzuki
    Last Post: 2009/09/20, 05:16 PM
