Electrickery
Results 1 to 2 of 2
Thread: Electrickery
    Sep 2008
    pretoria
    Post Electrickery
    Hi guys
    I took out my window lift ECU from my Disco 1 SE and managed to break it in half. I soldered it together again but now my windows work without the ignition being turned on. Now my battery is taking strain and I think the ECU is the culprit.
    The usual Landy dealers does not have the ECU secondhand and Im thinking of installing a cutoff switch for the battery. Does anyone have some advice for me as to what my options is?
    Hunters Close, Port Elizabeth
    Thanked: 76
    sounds like it your repair something got soldered and created a short cause it to continue using power. if you can't find a unit i second your idea of finding a descreet place for a switch and leave it as is.
    Luke aka Jedi
    1954 Landy Rover Series 1 86"- Rambling Rose
    Best company slogan: Cherrybomb performance exhaust, Disturbing the peace since 1968
  1. Disco 3 electrickery fundi
    By Will F in forum Land Rover
  2. Electrickery vs Mechanical Failure
    By Estee in forum Land Rover
  3. Electrickery on platkar
    By The Big Silver Hole in forum The 4x4 Pub
    Last Post: 2010/08/19, 12:53 PM
  4. Electrickery - spotlights
    By Coops in forum Vehicle & Technical Chat - General
    Last Post: 2009/01/15, 09:54 AM
