TJ Wrangler Auto Gearbox
Results 1 to 9 of 9
    May 2008
    Queenswood
    Default TJ Wrangler Auto Gearbox
    Hi
    I have a 2002 TJ Wrangler on which I have put JK rims and tyres (31.5"). It currently has a manual gearbox and I want to regear, but considering changing to an auto gearbox. Any suggestions on which auto gearbox, where I could get such installed in PTA and approximate cost thereof?
    Ricky G
    https://www.youtube.com/RickyG
    2012 Jeep Wrangler Rubicon JK 3.6L
    Sep 2010
    Meyerton
    Thanked: 16
    Why
    Team Rockhard
    Hard Core Jeep's
    Jeep Wrangler TJ - Hers
    Jeep renegade CJ7 - His
    Jeep Willys CJ2A - Boeta / Daugthers
    Jeep Cherokee KJ - Family
    Jun 2007
    Thanked: 65
    Read about it here: http://www.stu-offroad.com/engine/aw-4/aw-4-1.htm
    not impossible but prepare for bucketload of costs!!
    V51JP
    Namboyz Rule
    Thanked: 250
    Quote Originally Posted by Nano Fire View Post
    Hi
    What gear ratio are you currently running and why do you want to regear? Regearing has nothing to do with your gearbox - it all happens in the differentials. I run 32" BRG ATs with 3.73 gearing with my 4spd auto box and I am more than happy with it's performance.
    2013 Tata Xenon 3.0 Dicor D/C
    2006 Honda Civic EXi FN2
    May 2008
    Queenswood
    its a daily driver so would just enjoy the luxury of driving an automatic plus its easier whilst doing 4x4 - I have almost rolled my car off a little mountain, thanks to incorrect clutch use, was not pleasant.
    im running 31.5 with 3.07 so on the freeway on a an uphill, I can hardly use 5th gear, plus it has become more fuel thirsty. I guess it would be fine with 3.73 gearing.
    I was under the impression, that should I change to an auto gearbox that I would need to change the differentials anyway, which would be of benefit to my current setup.
    Ricky G
    CPT
    Expensive - rather sell this TJ and buy an auto TJ I am convinced it will be cheaper.
    Water covers 3/4 of the earth, Jeep covers the rest.
    Thanked: 250
    Quote Originally Posted by gunhog View Post
    I agree. Say for instance you switch to an 42RLE 4spd auto box then you will have to change your ECU as well - the ECU controls the gearbox. Then you will still be stuck with 32" wheels on 3.07 gearing which would be absolutely dismall with the 4spd and your overdrive will be totally useless which means you will still have to regear.
    May 2008
    Queenswood
    more than R20 - R30k?
    Ricky G
    Thanked: 250
    That will be about enough for regearing only.
  1. Replies: 45
    Last Post: 2013/07/09, 08:35 AM
  2. Fortuner Fortuner 4.0V6 Auto gearbox
    By toyotamad in forum Toyota
    Last Post: 2012/07/23, 08:32 PM
  3. Discovery 2: Disco 2 auto gearbox problems...
    By Mountain Goat in forum Land Rover
    Last Post: 2012/07/16, 12:06 PM
  4. Disco 2 auto gearbox adaptation
    By TwinDisco in forum Land Rover
    Last Post: 2011/09/07, 06:51 AM
  5. Wrangler auto
    By Bugdo in forum Jeep
    Last Post: 2008/08/13, 12:29 PM
