Dual battery charge question
Results 1 to 2 of 2
    Oct 2006
    Little Falls, Roodepoort
    Default Dual battery charge question
    Hi
    I have dual battery system in my Colt , National Luna.
    My system is a removable sytem. By this I mean, the solenoid is permanently fixed in the engine bay, fom there I have cables that go to the back of my bakkie, hella plug, connects to the second battery, in a box with plugs for the fridges, lights, etc! (Not the box NL sells, build my own system, controller is fitted behind the rear seat!)
    My problem is, when I connect the second battery, and the timer on the solenoid goes on, it tells me on the controller that the main battery overcharge and when the solenoid engage, it also tell me the second battery overcharge! But when I dont have the second battery connected, the main battery works fine and all the lights on the display is lit.
    So what could be the problem here? I have measured the voltage when charging and it is round about 14,7 V
    Anyone that maybe knows what the problem could be, it would be much appreciated!
    2008 Land Rover Discovery 3 TDV6 SE (Chuma)
    BG Goodrich AT's 265/65/18
    2005 BMW R1200GS motorbike(Daily commuter)
    Nigel
    Thanked: 1912
    This is not my forte, but in my book 14,7v is a bit high.
    I remember it being 13,8-14,2v max
    +27 zero eight 2 four 95 9252
  1. Defender Question: Main & Dual battery mounting?
    By Trevor_Mathews in forum Land Rover
    Last Post: 2011/02/22, 08:04 AM
  2. Solar panel & alternator charging dual battery simultaneously?
    By Jaco Kruger in forum Camping, Fridges, Accessories
    Last Post: 2010/10/06, 07:14 AM
  3. Dual battery system for double Cab
    By Jengel in forum Vehicle & Technical Chat - General
    Last Post: 2007/09/18, 09:37 AM
  4. dual battery / charge systems
    By froggie in forum Camping, Fridges, Accessories
    Last Post: 2007/05/14, 11:59 PM
