Page 10 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10
Results 181 to 193 of 193
Thread: Prado 120
  1. #181
    Thanked: 20
    Replaced front discs at 231000km, cost met just under a R1000 at Gemini Spares, now my brakes dont pulsate at low speeds anymore.
    This car has cost me R11000 on parts (R8000 for rear driveshaft because I am not happy with balancing done by local propshaft shops) from 210 000km towards 231000 and about R4000 for the 2 services incl labour and parts. Even at this mileage, it works out to around 80c per km on maintenance
    Fuel is around R1.50 per km
    Running at about R2.30 per km
    '15 Honda CR-V Comfort Auto
    '05 Honda CR-V RVSI Auto AWD
  2. #182
    Patensie
    Thanked: 28
    So pas my 120 000 km diens laat doen deur Toyota. Remme, filters , al die olies en vonkproppe. Twee skarniere op die agterste deur en die rubber laat vervang. Hulle het 7h30 begin en was 13h30 klaar. Daar is nie tee of middag ete geneem nie hulle dwarsdeur gewerk. R7500-00. Ek vra altyd om by te staan. Ek dink nie hulle hou daarvan nie maar dit is my voertuig en ek betaal.
  3. #183
    My 160kkm service (which is the biggest service you can do on the Prado petrol) cost me R4500 incl Vat and front brake pads at Mackano 4x4.
  4. #184
    Patensie
    Thanked: 28
    Klink reg, skarniere en rubber was R +- R2500. Ek het ook die Circlip op die stuurwiel laat terug druk wat nog R500 extra was.
  5. #185
    Thanked: 48
    Quote Originally Posted by Heinri View Post
    Ditto. Myne was ook daar rond, maar ook verniet... Ek bargain baie lekker as ek karre koop en het die diens ingesluit gekry.
  6. #186
    Ek wil major service op myne laat doen (basically die 160,000km service). Toyota Sinoville het R5049 gekwoteer en Toyota Pta Noord R4200. Obviously weet julle waarheen ek myne vat..
  7. #187
    Pradotoria
    Thanked: 48
    Barloworld Toyota Menlyn charged me R3600 (120 000 km)
    4x4s
  8. #188
    I just phoned Menlyn Toyota - R6109 for the 160,000km service..
  9. #189
    Pradotoria
    Thanked: 48
    whats the diff between a 120k km and 160k km service Both are major services with the same work being done unless they do something extra like change the timing chain. Can someone please explain.
    4x4s
  10. #190
    Apr 2008
    Waverley, Pretoria
    Thanked: 122
    AFAIK the 160k km service is a full lube service where they replace all fluids (brake, diff oil, transfer case oil, brake fluid, coolant, etc) and the 120k km is just a major service done every 40k km. My car's cambelt was replaced on 140k km.
    Its 160k km service was recently done at Toyota Imperial in Jhb and cost R4800
    '15 Prado 4.0 VX
    '13 Jurgens Xcell
  11. #191
    Quote Originally Posted by HennieC View Post
    Cool, then R4200 sounds reasonable.
  12. #192
    May 2010
    HONEYDEW
    Thanked: 2405
    My 160k just cosr me R 5900 incl rear brakes.
    The only query I have is my fuel filter was R600 does that sound right?
    Zerubbabel the 2008 4.8 Patrol
    Nothing, not even a mighty mountain, will stand in Zerubbabel’s way!
  13. #193
    May 2010
    HONEYDEW
    Thanked: 2405
    Ha immediate improvement in Fuel consumption!
    The trip computer was permanently above 15l/100km normally about 16l/100 for in town driving. I reset it before leaving the garage and both last night and this morning was slow slow traffic and the trip computer is at ave 13.5l/100km.
    An immediate saving of more than 1.5l/100km or a 10% reduction.
    I know the trip computer is not accurate but such a clear change is obvious.
  1. Prado 120 suspension lift
    By marcovn in forum Toyota
    Last Post: 2013/07/11, 10:40 AM
  2. Prado 120 - ATF Replacement
    By benhur in forum Toyota
    Last Post: 2011/03/07, 09:43 PM
  3. Prado (120) vs Fortuner
    By Jeep001 in forum Toyota
    Last Post: 2010/08/15, 05:38 PM
  4. Prado 120 Satnav wiring
    By Vanguard in forum Toyota
    Last Post: 2010/02/25, 04:31 PM
  5. Prado 120 lift
    By Krummelpap in forum Toyota
    Last Post: 2009/10/31, 02:58 PM
