Companion - Tips, tricks and mods - Page 21
Page 21 of 21 FirstFirst ... 11 12 13 14 15 16 17 18 19 20 21
Results 401 to 410 of 410
  1. #401
    Sep 2012
    Thanked: 38
    Default Re: Companion - Tips, tricks and mods
    Good Evening all,
    Just wondering if the best way to keep the batteries on the Companion is by plugging the caravan in and switching the charger on so that it charges through the panel. I have been using a trickle charger plugged into the multiplug that feeds through the cigarette lighter. In this setup, I switch the built in charger off. Which of these 2 methods is preferable?
    Kind regards
    2015 Discovery 4 SDV6 *** 2015 Conqueror Companion
  2. #402
    Apr 2008
    KZN
    Thanked: 11
    I retrofitted a BX-2 charger to my Companion when the original charger packed up.
    When not in use, I just left the Companion hooked up to mains, and the BX-2 kept the batteries conditioned, and everything shipshape.
    P
    Prado 4.0L VX
    BMW R1200 GSA
    "Two roads diverged in a wood, and I.....I took the one less travelled by, And that has made all the difference."
    -Robert Frost-
  3. #403
    Apr 2019
    Thanked: 344
    Quote Originally Posted by FatHuey View Post
    Good Evening all,
    Kind regards
    the factory charger (at least on mine, 2012) is not a smart charger - I’d think it would be very bad for batteries long term. Don’t know what yours has in it? Trickle charger should be great, provided it keeps up with the load (eg, do you leave anything on, like the fridge...)
  4. #404
    Jun 2019
    Forez
    Have you fitted front corner steadies to a companion? Which ones, and how did you fit them? Were they worth it?
    The jockey wheel usually slips, so I have been using a single axle stand under the A-frame, but it isn't great for levelling and takes storage space.
  5. #405
    Jul 2010
    Northwold JHB
    Quote Originally Posted by pieter_fourie View Post
    looks like the middle of the bed but runs in the seam and drips down the side. I will take some pictures
    With enough time and enough water pooling around (ie: is the water able to pool on the fly sheet?) canvas will eventually leak. I stopped using the side metal rods and put guy ropes on the sides of the front bed fly sheet and made sure every time that fly sheet was nice and ‘taught’ and never had an issue again.
  6. #406
    Thanked: 98
    Quote Originally Posted by KKampa View Post
    Mine has the Alko lifting legs, works like a dream
    Geoff Craig
    '98 Suzuki Samurai - Sami the Samurai
    '09 Toyota Fortuner 3.0 D-4D 4x4 (M)
    '10 Conqueror Comfort
  7. #407
    Thanked: 2271
    Those Alko supports works perfectly and are fairly easy to install. Not only do they prevent damage if the jockey slips, but also add to the stability of the caravan. +R1200 for two directly at Alko.
  8. #408
    Melkbosstrand
    Thanked: 163
    Also have the Alko steadies... they are brilliant.
    One thing though... rather mount them with the handles to the side, and not the front of the caravan... the handles don't like stones.
    2015 VW Amarok 4motion Auto
    2011 Conqueror Companion
  9. #409
    Jun 2019
    Forez
    Thanks. looks to be a good addition. How did you fit them? In one of the photos it looks like you may have to fabricate a mounting bracket?
  10. #410
    Melkbosstrand
    Thanked: 163
    I removed one of the bolts under the caravan as one of the mounting points, then drilled another home for the other mounting...
    Really simple to fit
