Companion - Tips, tricks and mods - Page 4
Page 4 of 18 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 ... LastLast
Results 61 to 80 of 355
  1. #61
    Bedfordview
    Quote Originally Posted by mbremer View Post
    Hi
    How complicated is it to remove the rack when you want to camp?
    I had one bike at the back of the car and one INSIDE the trailer on the last trip and it was a mission!
    Hi mbremer
    4 x Hand screws along the top and two clips to the side would say 3 minutes on your own.
    We are a big family so even with the bike rack I still have another 2-3 bikes packed inside. (Small ones go inside now)
    Sean
    Sean
    Toyota Prado 4.0 VX (BRUCE)
    Conqueror Companion (Bush Bebbie)
    GSA 1200
    Some Big Trips
    Moz http://4x4community.co.za/forum/showthread.php?t=124931
    Bots
    http://wp.me/p4BXZK-7
  2. #62
    Utrecht
    Default Mattresses
    I'm not very happy with the mattresses that came with the Companion.
    1. The nylon is extremely slippery and it is difficult to get a fitted sheet around it
    2. It seems to be very hard for light people but yet it compacts a lot on "my side" to the extent that it forms a "ridge" next to me. The result is that you always feel like you are sliding towards the side of the bed.
    I experienced much better high density foam with other trailers and RTTs.
    Do you have similar experiences or any suggestions on how it could be modified? Someone mentioned using a thinner piece of foam with the fitted sheet on top of the current arrangement but I don't really want to drag another piece of bedding along.
    Martin
  3. The Following User Says Thank You to mbremer For This Useful Post:
  4. #63
    Bedfordview
    Martin
    Hi Martin
    When I purchased my QC Martin & Vivian from Conqueror Midrand told me about a mattress mod which can be done. I have yet to have any complaints with my bedding, perhaps give them a call about it.
    Sean
    Sean
    GSA 1200
    Some Big Trips
    Bots
  5. #64
    Utrecht
    There were two option for mattresses if I remember correctly. I bought the QC in a bit of a rush, so maybe I did not pay enough attention!
  6. #65
    Utrecht
    Default Water tanks
    Regarding the water tank issue mentioned elsewhere; I also had the issue where the water would run out of the overfill when filled from the bottom and the main tank not filling the bottom tank.
    In the end I removed the connection to the bottom tank (on the side of the tank) and felt for obstructions. There were some debris but you won't believe how small that hole is (not the neck itself but rather where it opens into the tank itself). The top end of my little finger could barely get in there.
    My guess (and hope) is that it is an manufacturing oversight and not a design flaw because the engineer that designed that should ask for his money back from wherever he studied!
    The problem seems to be solved after I forced a screwdriver through there and wiggled it around a bit.
  7. #66
    Utrecht
    Default Pump
    The pressure switch on the pump gave up on third outing.
    There is apparently an incompatibility between the "new" geyser and the pump. They are happy to replace it but I have to somehow make time to travel 350Km to the nearest shop.
    Maybe other owners should check this before it becomes an issue.
    By the way, you can short the two wires on the switch and operate the pump from the on/off switch inside the trailer in case of an emergency
    Martin
  8. #67
    Utrecht
    Default Solar power
    What are the options for solar on the QC?
    I have the BH plug that draws power from the car when towing. Can one just plug a mobile panel into it? Do you need a regulator or whatever or will the current charger (power panel) take care of it?
    Also on power, how much is the PBE conversion and panel that also includes the water meter?
    Martin
  9. #68
    Midstream
    Thanked: 12
    Martin
    We use a mattress topper, expensive, but works like charm. Bought it at Volpes.
    2015 DC Hilux Legend 45 3L D4D 4x4 AT (His)
    2017 VW T6 Kombi (Hers)
  10. #69
    Thanked: 28
    Is it also a Sureflow pump? Which wires do you short?
    Jacques
    2013 Amarok BiTDi DC 4Motion
    2018 Bushlapa Ratel 4 Military Edition - BL1402
    Sold - 2011 Conqueror Comfort
    Sold - 2004 Isuzu KB300 DC (was only 4x2 but a happy 240000km and 9 years)
  11. #70
    Capri Village, Western Cape
    Thanked: 51
    Please share the costs and setup of the panel, thanks!
    Sorry for the late reply!
    I have 105 W solid solar panel that runs through a regulater into the Companion to either charge the batteries or run the whole system. I pirmarliy use it for three hours or as needed throughout the day from day 3 onwards.
    The companion has two 105 Amp deep cycle batteries.
    "THE PURPOSE OF LIVE IS TO BE HAPPY ." DALAI LAMA
    Rob
    Toyota Hilux Legend 45 3.0 D-4D DC 4x4
    VW Cross Polo 1.6 TDI (Swambo's car)
    Conqueror Companion II
    Harley Davidson Dyna FATBOB
  12. #71
    Sep 2011
    Potch/Brits
    Thanked: 573
    Quote Originally Posted by piri View Post
    I like the two batteries, What type of regulater do you use, or did come with the QC?
  13. #72
    Thanked: 21
    Vossie, please elaborate.
    I find that the two tents fold out (up) the same as a normal dome type arrangement with the hooks unto the rods. It helps to apply pressure to the rods when you fasten the hooks (to get it over the rod) and I think you must also start at the top (point nearest to the trailer).
    Quite correct - and it works well but is not very strong. I already have 2 or 3 bent pieces - and it takes time. I do not understand why is could not be made to erect itself - like a rooftop/trailertop tent. They have it on the Commander!
    I started with some plans/ideas to change mine to work like that. I will let you know how I progress.
    Bite off more than you can chew - then chew!
  14. #73
    Utrecht
    Quote Originally Posted by pretorjn View Post
    It looks like it says "Flopower" from what I can see.
    There is one right at the top and another just below it (both red!). I think they are the only ones around so you can't go wrong.
  15. #74
    Thanked: 28
    Maybe I dont understand you. AFAIK these are the + and - from the battery/power source. If you short these then you will effectively short your battery terminals.
    Jacques
  16. #75
    Utrecht
    No, you are shorting the wires that goes onto the pressure switch (that is how I understood it). I had Vivian on the line and he said take this wire and that one and connect them, so I can't tell you for sure which ones they are other than "it is the two thin red wires at the top of the pump"
    I will try to get a picture today
  17. #76
    Thanked: 28
    Would appreciate that. Thanks
    Jacques
  18. #77
    Thanked: 51
    Quote Originally Posted by carlp View Post
    The regulator is a "PHOCOS SOLAR CHARGE CONTROLLER"
    Rob
  19. #78
    Sep 2011
    Potch/Brits
    Thanked: 573
    thanks
  20. #79
    Jul 2010
    Fairland, Randburg
    I have made some modifications to the plumbing of the Companion. I was tired of plugging in and out of the pipes every time one wants to open and close the kitchen drawer. This also opened up the nose a bit to provide easier access.
    You will note that I moved the gas cylinders to one side, providing more space on the kitchen side of the nose for the wood and charcoal.
    Deon
    The spiderweb (mind you a spider web is more organised than the pipes in the Companion was) of pipes are gone, allowing easier entry and more space.
    Herewith a pitcure of the mixer - Still need to figure out how to do it neater, but the current set-up at least allow direct access into the bin behind the mixer without have to dodge pipes.
    Nissan Navara - the monster diesel version
  21. #80
    Utrecht
    Wow, that is really neatly done.
    Do you have pics of what you have done at the mixer?
    Conqueror should really be ashamed of themselves that a customer should show their engineers how is must be done
