Companion - Tips, tricks and mods - Page 10
Page 10 of 20 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 ... LastLast
Results 181 to 200 of 396
  1. #181
    Nov 2006
    Lonehill
    Default Re: Companion - Tips, tricks and mods
    Yes. On my national Luna 90l twin a hole was drilled in the rear of the motor cover with a permanent wire running through it. I can take pics on the weekend if you like.
    BruceT
    ZS6EBT
  2. #182
    Feb 2016
    Tzaneen
    Quote Originally Posted by Jack Russell View Post
    So I got the 90L NL today. How on earth do you get the 12V or 220V to it once it is in the drawer?!! There is no space for the plugs!
    Is there a mod needed.
    Please help.
    You need to remove the cover plate and route the 12 volt cable through the back of the fridge. The 12v socket has a little plastic pin you remove in order to take it out of it's holder and it will stay on the inside...
  3. #183
    Jun 2012
    Baie dankie.
  4. #184
    And back to the awnings for the Companion. After a lot of searching and contemplation, have I decided I will go with a BunduAwn, almost same one that Charlie100 shared some photos of in post #150. Received it yesterday and will be fitting this weekend or if it looks to daunting, will have it fitted at Conqueror East Rand when the van goes for a service Monday. Will post some photos of the process if I do decide to DIY, otherwise just a before and after, .
    - Leonardo Da Vinci
    Also on
  5. #185
    Jun 2012
    Quote Originally Posted by Herman_db View Post
    Did what you said, quick 10 minute job... loop soos stroop
  6. #186
    Oct 2008
    Quote Originally Posted by Rooikop View Post
    Good luck. Hopefully some pics will be posted of the installation.... Hint hint
    Mitsubishi Triton 3.2 DI-D 4x4
    BL925 - Ratel 4
  7. #187
    Oct 2008
    Damn... I didn't know it clipped out. I opened mine up and soldered my 220v and 12v in place
    BL925 - Ratel 4
  8. #188
    Jun 2012
    Quote Originally Posted by Charlie100 View Post
    once you have the cover plate off, there is a little black plastic pin you need to pull out on the DC, for the AC it has clips you need to push in.
  9. #189
    Oct 2008
    My companion het nie met "seperators" gekom in die kombuis area nie. So ek het so paar bestel by conquerer Zambezi, saam met daai foam goed, en het dit vandag ingesit
    Hier is n foto wat wys die onderste rak sonder seperators en foam, en die rak bo dit het dit altwee nou in
    BL925 - Ratel 4
  10. #190
    Midrand Estates
    Wink Re: Companion - Tips, tricks and mods
    Quite a few new standard extras on the companion. Should be getting my bamboo mattress this week.
    Rail on the top of the cupboard in side the van. Also fitted a cover over the charging system so lights could be blocked out.
    How can you be old and wise
    if you were never young and wild
    2016 Ford Ranger 3.2 XLT 4X4 Auto
    2015 Ford Ranger 3.2 XLT Auto
    2015 Mini Countryman
    2016 Conqueror Companion 2B
  11. #191
    Midrand Estates
    For those with the Quick Awning,
    I have permanently fixed the triangle that attaches at the rear of the awning. This piece basically squares of the rear so that a side can be attached. It normally zips in place, but SWAMBO likes to have the rear of the van covered .
  12. #192
    Midrand Estates
    Gents,
    Got my Bamboo mattress yesterday and what a pleasure. Expensive but well worth it. Decided to sleep in the driveway to test, and slept like a baby. Contact Edward -
  13. #193
    Jun 2012
    Flexible hose for (drinking) water:
    I had the conversion done on the pipes, and the water taste terrible! Can anyone advise where to get flexible hose suitable for drinking water. Clear flex PVC is not suitable.
  14. #194
    Nov 2014
    The Far East (...Boksburg)
    Just down the road from you. Hose Centre, Edenvale.
    Ask for the food grade, steel helix wire pipe.
    I've always got very good customer service and advice.
    http://www.hosecentre.co.za/Plastic%...html#liquidfsd
    "Adventure is the distance between the present and the fulfillment of your dreams. How you navigate the in-between, is the great unknown."
    Platkar: 2002 Audi A4 1.8T 110kW Multitronic
    Swambo: 2014 Clio IV 0.9L 66kW Turbo Expression
    Camper Trailer: 2012 Metalian Maxi
  15. #195
    Feb 2016
    Tzaneen
    Has anybody looked at Airconditioning options?
  16. #196
    Moet asb net nie vir forum lid Biltong gaan vra nie, hy sal n fit vang as jy n portable wil insit.
  17. #197
    Has anyone ever changed a tyre on their Companion?
    I need to but only have the bottle jack from my vehicle and don't know where to put it under the van.
    I know there are high lift jack points but don't have a high lift jack.
    2018 VW Amarok V6 4Motion Auto
  18. #198
    Midrand Estates
    Yes,
    But to expensive or now. Last price was + R20K for a off road suitable unit.
  19. #199
    Jun 2012
    How are you going to power an AC in the bush, without a gen set?
  20. #200
    Feb 2016
    Tzaneen
    Quote Originally Posted by Rustie View Post
    Ek het gesien portable aircons het almal warm gemaak die naweek!
