Nature Photo's for Comments & Criticism - Page 110
Page 110 of 148 FirstFirst ... 10 60 85 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 135 ... LastLast
Results 2,181 to 2,200 of 2941
  1. #2181
    Feb 2014
    Default Zebi
    Works in monochrome
    Zapiture,
    Discovery 4 Facelift 2015
    Defender D90 2.8 2003
    Conqueror Commander 2014
  2. #2182
ID:	349910   Click image for larger version.
ID:	349911   Click image for larger version.
ID:	349912   Click image for larger version.
ID:	349913   Click image for larger version.
ID:	349914   Click image for larger version.
ID:	349915   Click image for larger version.
  3. #2183
    Default Natural photos
    Our first cold day of the year. 4 degrees. Went out to take photos of the frost on the farm. We were fortunate to have no frost. Sun just starting to warm up Kaapsehoop Mountain top.
    [SIGPIC]MikevR Be determined to live the unlived life within you.
  4. #2184
    Port Nolloth
    Peter your last set of images are really special. To get that much detail on the guide without blowing out the background is not something that just happens that's for sure and the campfire ,Wow! Would you care to share the stories of the shots? I for one would learn from it.
    2004 Facelift Disco 2 - Raine - sold
    2006 Defender 110 csw - Jaeger
    "Land Rovers don't get stuck, people do, so always look before you leap and if you're unsure, don't do it" Chris Horne
    2019 Going back to Kgalagadi but this time without air suspension
  5. #2185
    Thank you Keith.
    The guide photo is fairly heavily post-processed (by my standards anyway). While shooting the scene, I was carefull to use base ISO (as dynamic range drops off quickly as ISO is increased) and not to over-expose the sky (-0.7 stops of exposure compensation), and afterwards I made the sky even darker and the foreground lighter using Lightroom.
    The fire shot follows almost the opposite approach. Firstly, to get the stars to show as dots rather than lines, one has to limit shutter speed in proportion to effective focal length (if one gets technical you can also consider the camera's resolution). In this case I could go to about 30 seconds. I also kept the lens wide open (f4) in order to capture as much light as possiible but to capture stars, I still had to elevate the ISO to 1250. At this point, there is not much dynamic range left and noise is already a big enough issue that one wants to do as little exposure adjustments in post-processing as possible, so I spent about half an hour slowly killing the fire untill I got the result I was looking for.
  6. #2186
    Sep 2008
    Swakopmund
    Mooi Peter - ek het nou nie na die EXIF data gekyk nie - is daai nog nie geskiet met 'n D7200 / D750 nie...?
    Fortuner 2.8 GD-6 4x4 Auto
    (Tough Dog Suspension / Frontrunner Roofrack and some more goodies...)
  7. #2187
    Quote Originally Posted by Sniper View Post
    Nee Hennie, ek is nog steeds op die D7000.
    MArk vir duur speelgoed is maar sleg, en niemend het nog gebyt aan die kar nie...
  8. #2188
    Aug 2010
    Centurion, Pretoria
    Gou vinnig iets getoets op my kamera in Swakop. So paar minute terug geneem.
    En ek sien die uploader draai dit weer landscape toe
ID:	350872   Click image for larger version.
    2011 Freelander 2 SD4 HSE AT.
    1999 Discovery II V8 XS AT.
    2016 Campmaster Compact 100 trailer.
  9. #2189
    Boksburg
    n Paar foto's wat ons laas naweek in KNP geneem het.
    Het onlangs my eerste DSLR gekoop en het nog baie om te leer
ID:	351136   Click image for larger version.
ID:	351137   Click image for larger version.
ID:	351138   Click image for larger version.
ID:	351139   Click image for larger version.
ID:	351140   Click image for larger version.
    2011 Defender Puma 110
    "The best 4x4xFar"
  10. #2190
    Sep 2008
    Swakopmund
    Default Damaraland
    A few shots taken in Damaraland two weeks ago:
ID:	351214   Click image for larger version.
ID:	351215   Click image for larger version.
ID:	351216   Click image for larger version.
ID:	351217   Click image for larger version.
ID:	351218   Click image for larger version.
ID:	351219   Click image for larger version.
ID:	351220   Click image for larger version.
Name:	Damaraland Stars.jpg
ID:	351222   Click image for larger version.
ID:	351223   Click image for larger version.
ID:	351224   Click image for larger version.
ID:	351225   Click image for larger version.
ID:	351226   Click image for larger version.
ID:	351227   Click image for larger version.
ID:	351228   Click image for larger version.
ID:	351230   Click image for larger version.
  11. #2191
    Sep 2012
    Vereeniging
    Very nice Hennie.
    Real engines use spark plugs
    2012 Trailblazer 3.6 V6
    2017 Jeep Grand Cherokee 5.7 HEMI
    Philip
  12. #2192
    North of Zambezi
    Default Fooling around
    First time fooling around a bit with a big stopper. Had to use the big stopper with a 85mm lens and yes the 85mm is more of a portrait lens but the big stopper does not fit my 14-24mm.
    The workflow was LR for normal quick adjustments then exported to NIK's Define 2 for noise correction and the BW was converted using Silver Effects Pro 2. I then edited both the versions in On1's Perfect Photo Suite doing Dynamic Contrast only. Editing time for both was about 5 min.
    File size increased from the original 74MB Nef file to the final PSD of 827MB
    15s @ f16 with ISO 100
ID:	352986   Click image for larger version.
  13. #2193
    Mar 2015
    Default Sony Z3 cellphone photos.
    Wow, what remarkable photos. Mother Nature... Thanks God 😁!!
    I have taken a few nature shots but not with a fancy camera. Sony Z3 phone was used to take these photos.
  14. #2194
    Mar 2015
    Default Blouwildebees met sononder
    Mooi ne
  15. #2195
    Mar 2015
    Default Jakkelsspoor
    Jakkelsspoor
  16. #2196
    Mar 2015
    Default Pof adder
    Die outjie was ongelukkig al klaar dood.
  17. #2197
    Mar 2015
    Default Ezemvelo
    Sunset.
  18. #2198
    Mar 2015
    Default Dragon fly
    Blue
  19. #2199
    Mar 2015
    Default Klein en fyn
    Rond speel.
  20. #2200
    Mar 2015
    Default Close up
    Close up taken on the floor
  1. Lekgalameetse Nature Reserve
    By Thys Willemse in forum 4x4 Trails / Routes / Clubs
    Last Post: 2016/09/14, 06:24 AM
  2. Dewildt in STD Jeep GC WJ
    By andrewbuch in forum 4x4 Trails / Routes / Clubs
    Last Post: 2011/12/02, 12:31 PM
  3. How do you store your photo's
    By Johan in forum Cameras & Photography
    Last Post: 2010/10/26, 12:44 PM
