Defender Knocking Noise and Trouble Pulling Off - Page 2
Page 2 of 2 FirstFirst 1 2
Results 21 to 22 of 22
  1. #21
    Dec 2006
    Sasolburg
    had the same problem on my 110 v8< skimmed the hand brake drum ( it had highspots) and problem went away. ask the guy that does the job to grind the drum for you. much better that machining
    Live today as if itís your last day to make a change in this world. Cause tomorrow is promised to no one.
    Driving the BEST 4x4's
  2. #22
    Feb 2012
    Namibia
    Yeah it must be the hand brake.
    I took a short drive and pulled up the hand brake slightly when I started to hear the knocking and it got drastically worse.
    I then went under again and loosened the hand brake adjuster as much as I could and took him for another test drive; the sound is 95% gone.
    Thanx for all the advice and a bit of healthy debate, haha.
    I will get the drum to the local engineering guy and see if I can order the shoes from RSA. Might as well do it all while I'm busy.
  1. Speedometer trouble
    By Ben W in forum Mitsubishi
    Last Post: 2011/12/15, 07:01 PM
  2. KZTE aircon bearing trouble
    By stalmaat in forum Toyota
    Last Post: 2010/02/15, 05:30 PM
