3.2DiD grinding/squeeking front wheel
Results 1 to 3 of 3
    May 2010
    Thanked: 217
    Default 3.2DiD grinding/squeeking front wheel
    Hi All,
    My uncle's 3.2DiD Pajero has grinding/squeeking front wheel. The noise goes away as soon as he applies the brakes.
    This leads me to think brake pads/vibration plates/loose caliper?
    Please let me know if it could be anything else because I will be taking the wheel off this afternoon and am clueless
    Thanks again!
    Thanked: 2494
    check the front right inner CV cup (usually green in colour) for play. It may be the dreaded inner shaft bearing.
    http://www.pajeroclub.co.za/forum/viewtopic.php?t=3696
    MB160662 for the bearing - R107.10 from the dealer
    and a pic of the new CV boot
    Rustenburg
    or it could be that one of the clips on the brake pad is making contact with the brake disk.
    i had the same issues. the clip broke and made enough contact with the disk to grind a 2mm gash in the front disk.
    Its only funny until someone gets hurt.
    Swambo: LadyangeL
    2001 Pajero 3.2 Di-D LWB Manual & Auto
    2013 Metalian Maxi Trailer aka BOSSIE
    2011 Conqueror Companion
  1. Foton Tunland
    By Frans E in forum Foton
    Last Post: 2018/08/30, 01:00 AM
  2. Fitting new front wheel bearings Hilux
    By Big Hilux in forum Toyota
    Last Post: 2014/05/28, 02:58 PM
  3. Mazda Drifter 4x4 front wheel vibration
    By bergie1 in forum Ford & Mazda
    Last Post: 2014/05/02, 05:04 PM
  4. Colt 2.8TDi (2001) Front Wheel Bearings
    By Scoob in forum Mitsubishi
    Last Post: 2009/04/03, 09:20 AM
  5. Diff-locks versus better suspension articulation
    By arnoc in forum General 4x4 Discussion
    Last Post: 2008/04/02, 01:52 PM
