Side Wall Cut
Results 1 to 4 of 4
Thread: Side Wall Cut
    Oct 2006
    Little Falls, Roodepoort
    Default Side Wall Cut
    Hi
    When does one know when your side wall has been cut to deeply and could be dangerous.
    I have Pirelli Scorpions on the bakkie.
    The cut is 3cm, but you only see it when you have the cut at the bottom of the tyre, meaning when the side of the cut is touching the ground.
    Does the Scorpions have reinforced Side Wall protection like BF Goodrich?
    I haven't even been offroad so dont know how this happened!
    Charl Esterhuysen2008 Land Rover Discovery 3 TDV6 SE (260 000km)BG Goodrich AT's 265/65/182005 BMW R1200GS motorbike(Daily commuter)
    Mar 2007
    Thanked: 25
    The Safest will be to replace the tire! Remember all the mass is on the sidewall and can be dangerous.
    Adriaan
    May 2007
    Langebaan
    Thanked: 113
    Default Tyre
    See if there is a Bandag dealer in your area or ask the guys where you can get truck tyres re-treaded (versool).
    I had a sidewall cut that was not too big in my one Cooper. The vulcanized it for me and I use it as a spar now. If the cut is not very deep it is OK, sometimes it is just a surface cut. But rather let a tyre guy check it out for you.
    If you cannot have it vulcanized you ask them to attach a patch on the inside in the area of the cut and put a tube in, you can then use it as a spare as well.
    It all depends on exactly where on the sidewall and how long the cut is. If you say it is not all the way through yet it might really be only a surface thing.
    1999 Hilux Raider 4x4 2700i, 'n groene met swart tyres
    19 Voertsheck Jeep CJ5 Built on 1984 Nissan Safari mechanics
    2011 Touareg 4.2 V8 Diesel.
    Series IIA Landy being Rebuilt (for the past 4 years)
    1963 Willys Traveller
    Jan 2007
    Tamboerskloof, Cape Town
    Thanked: 136
    Trentyre may also be able to help you there. I once had a set of 12" tyres which they retreaded for me with a more agressive tread pattern I had selected from the available range, ie I received some personal service from them! 8)
  1. Defender Defender Side Kitchen Unit
    By Smiles in forum Land Rover
    Last Post: 2012/06/11, 04:26 PM
  2. Engine cut off
    By atlantic in forum Hyundai
    Last Post: 2011/05/20, 01:19 PM
  3. Overheating side by side
    By cfmans in forum General 4x4 Discussion
    Last Post: 2011/03/30, 10:44 PM
  4. Side step diameter
    By Flagster in forum Isuzu
    Last Post: 2011/02/28, 04:27 PM
  5. An interesting TJ Jeep Article.
    By Big Hilux in forum Jeep
