ML 500 using oil
Results 1 to 5 of 5
    Live : Bethal , Work : Saudi
    Question ML 500 using oil
    Hi Guys need some advise
    My 2003 ML 500 V8 150 000km is starting to use oil it started in feb this year 500ml n month didn't think anything of it then it become 500ml with every second tank fill up.now every 1000 km or so it needs 500ml or so.
    Can it be that the oil rings went
    There's no smoke as yet.
    One life Live it
    Take The Roads less traveled
    Alles in die lewe gebeur met n doel
    Kathu
    Quote Originally Posted by 4x4 Bedinges View Post
    Manufacturers rate oil consumption of 1000ml per 1000km as normal. If it does not smoke I will not worry. Do an oil change and fill up with good quality oil within the Merc`s specs
    Thanks Uncle grips will do a full service on the ML when I'm back in S.A in June.
    Just want to make sure it wont leave gogga standing next to the road.
    Its at this stage our only wheels.
    One life Live it
    Kyalami
    Merc uses Mobil 1 0W-40 as standard on the AMG models (I use it as well with no issues). Your car has a 113 engine and if you find that your rings are shot it may be repairable, read this
    http://www.marcusfitzhugh.com/CLK/DIY/rebuildable.html
    A common problem with these motors are that they leak oil from their tappet covers. Is there any visible leaks?
    --Kar
    Quote Originally Posted by Ne3M View Post
    Thanks Ne3M I will have a look when I'm in S.A again.
    One life Live it
  1. Navara oil pump failure
    By Ace in forum Nissan
    Last Post: 2014/06/18, 08:43 AM
  2. Oil Change: men vs women
    By Hello2Africa in forum The 4x4 Pub
    Last Post: 2010/05/09, 09:13 PM
  3. Zero Based Maintenance and Oil Analysis
    By Estee in forum Land Rover
    Last Post: 2010/04/13, 09:20 PM
  4. Differential Oil Specification
    By Herlu in forum Mitsubishi
    Last Post: 2009/05/07, 09:22 PM
  5. Buying oil
    By OFFROAD ADDICT in forum General 4x4 Discussion
    Last Post: 2008/07/04, 10:25 AM
