Results 1 to 11 of 11
    Thanked: 798
    Default Serious oil leak-how to find?
    I have a serious oil leak on the front bottom end of the 3.9 V8 that ends up coating every thing up to the cross member at the gearbox in oil.
    The problem is I cannot find it. Pressure clean everything as far as possable, let the car stand and idle for hours, no oil anywhere to be traced to the source.
    It is not autobox or powersteering oil, its engine oil. The front diff never needs top up either so its not coming from there when driving.
    At first i suspected the front crank seal, but at lenghty idle nothing from there, nor from the oil cooler pipes or the oil pressure sensor. The sump gasket also looks sound, no obvious oil from there after a cleanup.
    The only oil leaks I can find is the tappet cover seals has an oil sweat, but nothing so serious that its running down to the sump area coating it all in thick grimey oil deposits.
    Any sugestions?
    Thanked: 104
    Any oil on the valley gasket?
    '09 Suzuki Grand Vitara 3.2
    Thanked: 798
    Cant see any oil from the valley gasket area, RH tappet cover does show some oil sweat wetness 10mm high all around, could maybe coming from there going down the front of engine, but it does not look substantial enough for the mess I see under the car.
    Thanked: 486
    Hi Fanie
    check where the dipstick tube enters the block. Leaks can also originate from there.
    Good luck!
    George Bosch
    Distributor for:
    Thanked: 798
    A drive to the shopping centre and I found some oil on the diff housing, so it's coming from the rh side of engine, not the dip sick side. I'm going to find the bugger :-)
    Vereeniging
    Sounds like the steeringbox, while idling, turn fully to one side, keeping it there for only a second or two, now turn it to the other side and lock it for a second or two- check the paving.
    89 110 3.5 V8
    Thanked: 104
    Is the area around the distributor filling with oil?
    How about the oil pressure sensor or oil pressure release valve? Or even the oil filter seal or the oil filter itself. I've had a faulty oil filter that leaked around the crimped end.
    Only other alternative I can see is the timing cover.
    Springs
    Thanked: 285
    you have not mentioned the sump
    they love to leak
    the fan then blows everything all over the show
    Thanked: 798
    After driving around a bit it seems some fresh oil is coming from somewhere above the oil filter.
    Feb 2012
    Thanked: 13
    check the front crank seal, on idle it doesn't leak (I assume oil level is below the seal), but while driving oil splashing around inside and causes it to leak.
    its quick to replace anyhow, and R60 if I recall, fan off, pully off and check it.
    after driving around maybe just feel inside of crank pully to see if its oily there first?
    Thanked: 798
    Replaced the oil pressure switch, still leaks, the only other source is the crank seal as per Stretch, will do that later this week.
  1. :mad: Oil leak
    By Benson in forum Land Rover
    Last Post: 2011/07/26, 07:14 AM
  2. Stupid oil leak on Prado!
    By Die Skim in forum Toyota
    Last Post: 2011/07/22, 04:19 PM
  3. Defender Oil filter leak.
    By Jacque W in forum Land Rover
    Last Post: 2011/07/14, 08:13 PM
  4. Gearbox oil cooler leak?
    By Riceburner in forum Land Rover
    Last Post: 2011/07/13, 08:05 AM
  5. Oil Change: men vs women
    By Hello2Africa in forum The 4x4 Pub
    Last Post: 2010/05/09, 09:13 PM
