Results 1 to 9 of 9
    Apr 2011
    JHB
    Question Disco 2 TD5 ECU Remap
    Hi All
    I have been doing some research about remapping my 2003 disco 2 td5 es auto
    and would like your help in making a decision, i understand that doing remap will likely shorten the life of the engine due to more pressure and strain on parts, i do know a madman with a egt monitor is also essential.
    What i would like to find out from people in the know is what different types of maps are there, what benefits where there eg
    Map: European Remap (just made this up)
    Performance: + 30kw
    Fuel Consumption: better urban - 10 open road -8 to the hundred
    Egt: 5degrees Increase in operating temp
    Installer: Landyonline, Torguetune, Steves Auto Clinc, landytech, etc
    Cost: R3500
    Kilos: 50000
    Problems: None, nothing replaced
    Opinion: Perfomance increase is great and i would do it again
    How: It works by ticking the computer that is running cooler and is below sea level
    If you don't know all the stuff still post some what you know, i am sure this will help td5 owners
    Thanks for all your input
    Moomoo
    Im also considering remapping my Td5 defender but tricking the ECU in thinking that its running at sae level and cooler temp would cause the ECU getting false feedback regarding the mass air flow and therefore under/over fuelling.
    Isnt the remapping more in the line of altering the fuel maps or adjusting the time periods in which the injectors are injecting fuel?
    2010 Defender puma 1108)
    Bellville
    Map: Custom Remap
    Performance: Unknown, but I can spin a TD5 auto with muds now!
    Fuel Consumption: Better, more torque and much quicker to get to lockup @ 90km/h
    Egt: 50'C Increase in EGT Temp, none on cooling and head temps
    Installer: UFix Goodwood via TorqTune
    Cost: R4000
    Kilos: 295000
    Problems: None, already setup for full performance
    Opinion: Better throttle response, torque is up, much smoother engine
    How It works: Read your Map, send to TorqTune, 1h max later they send new custom file back, ECU get flashed with new map, you drive off smiling.
    Driven by passion
    Jakes 071 9855 258
    Thanked: 50
    Best regards
    Philip
    LR: '11 Rangie 5.0 S/C, '01 Disco 2 XS 4.6 V8
    Ford: '19 Ranger 3.2 XLS Manual SuperCab 4x4 (XLT is ergonomic disaster)
    Chevrolet: '70 C10 350ci / 700R4 (4-sp Overdrive) & '59 Apache (Stepside)
    Apr 2011
    JHB
    Lightbulb
    Quote Originally Posted by LRwit View Post
    Hi all thanks for the responses, LRwit would you mind putting it in the format so we could all see clearly, have you tried any other maps?
    Has any one tried the map from Bell Auto Services in the UK or Eurospeed map
    I am also interested if people find alot more power past 3000rpm. Thanks All
    Thanked: 50
    Map: Torqtune + Unichip
    Performance: It feels like DOUBLE that of a standard TD5
    Fuel Consumption: 500km/tank but who cares really when you have so much under the foot...
    Egt: no idea, can see my coolant temp rise rapidly at low rpms (1000 - 1500rpm) under load
    Installer: Torqtune, Landytech (turbo and other mods), Steves Auto Clinic (Unichip)
    Cost: R13500 for the Turbo, R4000 for Torqtune map, Cant remember SAC bill (that was around the year 2000)
    Kilos: 120 000
    Problems: Its still not enough! I just know there is still lots more...
    Opinion: My brain still can not compute the power that comes out this 2.5L thing
    How: VNT turbo boosts from 1250rpm already (0.5bar) and does not stop till 4000rpm, Torqtune and Unichip just adds more fuel.
    Best regards
    Philip
    Nov 2011
    Strand
    Quote Originally Posted by DiscoMad View Post
    Cost: R4000
    Kilos: 295000
    Disco Mad, can you give us some contact details please
    Zatopec......
    2002 Land Rover Discovery 2 TD5 GS Auto
    2007 Land Rover Discovery 3 TDV6 S
    2010 Isuzu KB250LE D-TEQ DC 4x2
    1989 VW Golf 2 1.8 Crossflow Head with 40 Webber Sidies Rally Car
    1982 Toyota Hilux 4x4
    kyalami
    Thanked: 8
    Seems like Jakes may be busy fixing too many cars :0
    his number is 07 one 9855258
    Map: Solihull map from Denmark
    Performance: Sorted out the 3 second turbo-lag
    Fuel Consumption: 700-800 per tank
    Egt: Can't really compare before / after (installed EGT at the same time), but it's 380 deg at cruise, no aircon, minimal load.
    Installer: Solihuxx
    Cost: R2500 in 2009
    Kilos: 86,000
    Problems: None, but will have to do the intercooler next.
    Opinion: Well worth the spend
    How: Waiting for the gurus to answer that one.
    2003 Td5 110 DC
  1. Discovery 2: Buying and running a Disco II (Td5)
    By Craigb in forum Land Rover
    Last Post: 2023/12/26, 07:58 PM
  2. Bad Purchase - Taken for a ride Disco 2 TD5
    By little4by4 in forum Land Rover
    Last Post: 2011/05/14, 12:56 AM
  3. Disco II TD5 fuel consumption overlanding
    By janfloris in forum Land Rover
    Last Post: 2011/04/21, 08:50 AM
  4. Disco TD5 in Def 110
    By Wollie in forum Land Rover
    Last Post: 2009/08/21, 08:46 AM
  5. Disco TD5
    By Wielie in forum Land Rover
    Last Post: 2007/03/28, 11:56 AM
