Treg Owners - Page 101
Page 101 of 530 FirstFirst ... 51 76 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 126 151 201 351 ... LastLast
Results 2,001 to 2,020 of 10585
Thread: Treg Owners
  1. #2001
    Johannesburg South Africa
    Thanked: 24
    Marius,
    Thanks for the info on these gear ratios. Does the 8-speed V6 TDI have the same gearbox and diff ratios as the V8TDI
    Quattro
    2005 Touareg V10
    2006 BMW M5
    2017 Invader Duo
    2007 Noble Ferrari P4 replica
    2013 High Spec TRD Toyota 86
  2. #2002
    Jan 2014
    Ezulwini Eswatini
    Thanked: 1634
    Also some extra info not related to my vehicle.
    1. Tim seeing a few Treg's with damaged front differentials coming in, he showed me a diff he had opened and the pitted bearings inside. His suspicion is that these are Tregs which have had water enter the diff via the breather. The breather is clipped to the air filter box, but is easily forgotten and left dangling by a careless mechanic. He is working on a method to replace the bearings in the differentials, rather than being forced into a whole new unit by VW.
    2. He mentioned that new air struts (complete units), are 50% cheaper from Porsche compared to VW/Audi in RSA.
    3. There are apparently a fair amount of oil leaks happening on the V6 TDI CASA engines (mostly the new generation Treg's). The leaks are from the cam chain housing at the rear of the engine. Repair is a massive procedure requiring engine removal.
    4. Not aware of any issues with the new V8 TDI's.
    5. Dead opposed to EGR blanking. Don't do it!
    Hi Kortgat
    did you perhaps discuss if and when one should change the ATF fluid gearbox?
    2011 VW Touareg V.8 TDI
    2006 VW Touareg 3.0 TDi air suspension aka Pumba ( sold)
    2003 Pajero IO 2.0 aka Bosvark
  3. #2003
    Thanked: 2322
    Quote Originally Posted by Quattro View Post
    Marius,
    I believe they are.
  4. #2004
    Thanked: 2322
    I have been unhappy with the rebound of the air suspension for a while.
    I have done all bushes except for the lower control arm front bushes which seemed fine when I did the other ones.
    So yesterday afternoon and I jacked up the car and looked for play and found play on that bush.
    So I pulled the lower control arm quickly and surprise surprise the bush is fine.
    Sat back and thought about the play and then it hit me.
    The bolt has play in the barrel of the bush.
    So, I have to order some eccentric bolts from VW - R109 each!
    I'm wondering If I shouldn't order the bushes as well as the bush barrel might be worn. But I suppose doing the bolts is easy. If that doesn't fix it, I will pull the arm again and change the bushes.
    PS : I was very upset that I had to reassemble with those dud components as I need the car tomorrow.
    So if you feel a loud thud when going over a bump as if the air suspension is rebounding too hard, jack up the wheel and wiggle the wheel while holding at 3 & 9 o'clock positions. Then look at the lower control arm front bush for play.
  5. #2005
    Thanked: 590
    Ok so the Cape 2 Cape Touareg world record setters left the Cape this morning at 10h00. They will be coming through Johannesburg around midnight tonight. This time around I won't be there to greet them.
  6. #2006
    Jan 2015
    Vredenburg
    Thanked: 935
    So I'm spending the weekend with friends at the Eagle Rally.
    Told the fiancé she and her friend could take the Touareg to Cape Town to fech the wedding gown.
    I get a call...
    She parked at an incline sidewas and when she closed the door she pulled the handle right out from the door...
    What can I say. It's an accident.
    - Instand Weekend killer...
    Words cannot explain my feelings right now.
  7. #2007
    Thanked: 2322
  8. #2008
    Jan 2015
    Vredenburg
    Thanked: 935
    Outside handle or inside handle?
    Inside drivers door.
    And I don't do pirate parts. Not on the Beast.
    Am concerned about colour differences and quality of newer replacement parts.
  9. #2009
    Thanked: 2322
    Please take pictures and share what you find. I want to fix mine that was fixed poorly by a previous owner.
  10. #2010
    Jan 2015
    Vredenburg
    Thanked: 935
    This is the picture she sent me.
  11. #2011
    Thanked: 2322
    Ouch. Mine has obviously suffered the same fate in the past. Previous owner fixed it with coach bolts. Looks a bit crude but lasted over 50k kms so far. Would like to fix it properly so any tips from your fix would be appreciated.
    Thanks in advance. Hope its not too pricey and difficult.
  12. #2012
    Jan 2015
    Vredenburg
    Thanked: 935
    I will do so Marius.
    This will have to be fixed bofore the wedding in two weeks time.
    Thing is, I understand exerted forces and my Jetta started showing cracking around the drivers side door handle a while back.
    Since then I always hook in my right index finger inthe door handle closest to the door hinges and then pull it closed that way.
  13. #2013
    Thanked: 185
    Must be a weak part. Are you going to try and fix it or replace? Looks like a new inner panel?
    Touareg V10
    KTM 1290 Super Adventure R
  14. #2014
    Jan 2015
    Vredenburg
    Thanked: 935
    Quote Originally Posted by SpiderGear View Post
    I don't want to lap&plak anything on my Touareg.
    I will just have to order the part.
    From what I could find it looks like a separate part for just the handle. But quotes on the internet shows a cost of $92.26
    Part #: 7L6-867-161-B-2V4
    http://www.vwpartsvortex.com/oe-volk.../7l6867161b2v4
  15. #2015
    Thanked: 185
    That's a relief! Wonder what a whole new inner panel would cost!
    Touareg V10
  16. #2016
    Jan 2015
    Vredenburg
    Thanked: 935
    I will find out and share the information with you.
  17. #2017
    Thanked: 185
    I see the panel alone is over $1000.
    Touareg V10
  18. #2018
    Jan 2015
    Vredenburg
    Thanked: 935
    So Sad...
  19. #2019
    In transit
    Hope I am not high jacking this thread.
    I am looking at perhaps getting Toureg 2010/2011 3L Tdi.
    I see the 2011 looks upgraded?
    Do they all come with air suspension?Is there a big difference between this and normal vehicle suspension.
    Please give me the good and bad.
    Appreciated.
    Howard
    Nissan Murano
    VW Caddy 2LTdi
    Metalian Off Road Trailer
  20. #2020
    Thanked: 2322
    Drive 4 or 5 examples. Buy the best one.
    If you can get one with air suspension, go for that.
    They are awesome cars!
  1. For Land Rover Owners
    By incrediblebob in forum Land Rover
    Last Post: 2015/08/11, 06:49 PM
  2. Triton owners unite!!!!
    By Die SwartKat in forum Mitsubishi
    Last Post: 2011/10/07, 04:17 PM
  3. Gauteng Land Rover Owners Take Note!!!
    By 4x4offroad in forum Calender & Events
    Last Post: 2011/05/18, 09:21 PM
  4. Land Rover Owners Function
    By AndyF in forum Calender & Events
    Last Post: 2011/01/19, 04:30 PM
