Home made awning
Results 1 to 5 of 5
    Nov 2006
    Edenglen
    Default Home made awning
    I've done a search but couldn't find any relevant info.
    I want to make an awning for my 110. I've thought of fixing some of the stuff that you slot a caravan tent into along the length of my roofrack and then having a piece of canvas the the same stuff you find on the edge of a caravan tent made up. The opposite edge (away from the vehicle) could then be supported by 2 poles and guy ropes. It could fold up quite small when not in use and should be pretty cheap. Sorry, can't remember what the "stuff" is called.
    Comments or advice please. Will it work?
    Erin Bosch (082 342 1909)
    4xfagger no. GP0048
    2001 Land Rover Defender 130 TD5 D/C with everything
    The Windy City
    Caravan extrusion? And ropemould? I have exactly the same plan, and I know Stockman has already done one like that. My alu is at home just need to mount it now.
    Jul 2007
    Hi Imvubu
    I have exactly that on my Disco - in fact it rolls up neatly whilst in the track which is fitted to my roof rack. That way I always have it with me - get's a bit of weather damage, I suppose, but it works for me.
    I also put the 2 poles inside the awning when I roll it up - no loose items lying around. My poles are normal fixed length - I am thinking of replacing with the telescopic ones so you can always have the awning running away from the vehicle if it rains.
    andre
    Andre
    Discovery 4 V8
    Jurgens Xplorer
    Hi the photo is what i did on my custom built ali canopy. Tentco in Jetpark did the sewing of the rope mould.
    The caravan extrusion you can get from any caravan dealer/ Campworld. I have just find a place in PTA that can supply nylon material and want to replace the current oxford green material as it is a bit heavy.
    [SIGPIC]
    Nelspruit (Mbombela)
    2015 Pajero Sport - Shogun
    2009 Triton 2.5 DiD 4x4 - (EGR blanked off and DPF ("CAT") removed - )
    Echo 1 Trailer & Howling Moon Trailer Tent
    VHF - 4x4Com - 1047 / 29 Mhz - ZRB 4759
    Nov 2006
    Edenglen
    Thanks guys. Looks like its off to the caravan centre for me.
    4xfagger no. GP0048
  1. Home made Bash Plate made 4 my Triton
    By RichardG in forum Mitsubishi
    Last Post: 2015/11/10, 08:46 AM
  2. Home Security: External alarms required
    By macjohnw in forum The 4x4 Pub
    Last Post: 2010/10/25, 04:32 PM
  3. Awning material
    By James MacKay in forum General 4x4 Discussion
    Last Post: 2010/09/15, 09:09 AM
  4. Home made roofrack!
    By Sand Lover in forum Camping, Fridges, Accessories
    Last Post: 2008/01/25, 10:40 AM
