Page 5 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 81 to 100 of 154
Thread: 132KW Amarok
  1. #81
    Mar 2007
    Thanked: 110
    Default Head Change
    I am told that the torque is still 400Nm and the increase in the Kw is due to a change to the head. The boost pressure etc. is all the same.
    I could not get a confirmation whether or not the 500 Rpm band of peak torque had been extended or not.
  2. #82
    Hillcrest
    Thanked: 21579
    Quote Originally Posted by Brent Clark View Post
    Once again I am confused, this time not officialy.
    If the torque hasnt changed then there is no way you can develop more Kw for a given RPM.
    NAGOF
    HAM Callsign - ZS5KAD
  3. #83
    Mar 2007
    Thanked: 110
    Default Time will tell
    Time will tell, as we will get the graphs at a point in time...
  4. #84
    Hillcrest
    Thanked: 21579
    Brent, nothing you can do can make a motor develop more power on its own.
    You either make it develop more torque or extend the RPM which then has a side effect of more power. Its a scientific fact.
    PS - I assume you know this and expect the graphs to verify it.
    NAGOF
  5. #85
    Jan 2011
    Thanked: 2348
    Default 132KW Amarok
    I am told that the torque is still 400Nm...
    Brent, Fluffer;
    AFAIK Peak Torque is up - to 420 or 440 or somewhere there.
    Fluffy, I'm not sure if you are implying that kW & Nm are linked & as you increase or decrease the one so the other must increase or decrease.
    Toyota has a 2.5 producing 75kW & either 200Nm or 260Nm.
    Toyota also has a 3.0 producing 120kW & the 343Nm or 400Nm
  6. #86
    Thanked: 151
    The changes on the 132kW engine compared to the 120kW are: turbocharger, high pressure fuel pump, injectors, egr valve (cooler and valve now separate), and a few other changes, as well as new software. Converting 120kWs to 132kW via retrofitment of the parts is not possible.
    Cheers,
    Current:
    2019 Amarok Dark Label 4Motion
    2023 T-Cross TSI (Swambo)
    2024 Caddy Maxi TDI
    2016 Metalian Maxi
  7. #87
    Thanked: 3308
    Power (kw) is the rate of doing work (the nm or torque) so when the engine can spin faster, without loosing too much torque, then the result is more power. The typical f1 engine does not have too much torque, but the rate of doing the work is very high, hence the high power. Like wise a typical heavy truck has enormous torque, but can not do the work very fast as they normally max out around 2000rpm.
    Stephen
  8. #88
    Jul 2010
    Was chatting to a mate of mine yesterday, bought his wife the RAV 2.2 diesel. He said that it towed his boat better than his father in laws amarok tdi 4motion. There still seems to be an problem with the power delivery of these vehicles...
  9. #89
    Apr 2011
    Brisbane, AUS
    Quote Originally Posted by PUW View Post
    Or most likely your mate is talking rubbish. I have about 4 years worth of driving experience in the current shape 3.0 diesel hilux, and my old man has had the 120tdi amarok since last year in January. I can say with certainty that the amarok is more torquey and has a wider spread of power/torque from about 1200rpm up to the redline than the hilux. It's faster, more punchy, and smoother/quieter. The amarok has no problems with towing whatsoever.
  10. #90
    Mar 2007
    Thanked: 110
    Default Exactly
    I am told, but believe when I can verify the facts... The source is the dude responsible for the VW aftersales service, Dealer technical training etc..... so we wait...
  11. #91
    Jan 2011
    Thanked: 2348
    I must agree with Gavin, although the RAV4 @ around 110kW & 300Nm of torque is not far behind the 120kW Amarok,
    the only reason the RAV4 could be felt to tow better would be better
    power to weight ratio.
    Remember, also, that the RAV4 4wd only sends power to the front wheels when towing...
  12. #92
    Mar 2007
    Thanked: 110
    Default Interesting
    How do you get this?
    The RAV 4 system is totally electronic, it sends power to where it is needed, as it is needed...
  13. #93
    Waterkloofridge Pretoria
    Quote Originally Posted by gavinlg View Post
    Lucky I don't need to listen to a mates stories. I own a Amarok, and I tow very heavy loads, not only small dingy's, and if there is a vehicle that can, it is the Rok!!!. Gaveling I totally agree with you. They can at any time bring that Rav, I'l show them.
    Pieter Swart.
    2011 Amarok Bi Turbo 4 Motion
    Julle ouens wat dink julle weet alles maak ons ouens wat alles weet die donner in!!!
    Dis 'n manne ding! As Swambo saamgaan kos dit twee maal so veel en dis net die helfte so lekker!!!
  14. #94
    Jan 2011
    Thanked: 2348
    Brent, AFAIK it uses that Part-Time Haldex clutch system whereby drive is ONLY sent to the rear wheels when slip is detected on the fronts.
    Similar to other Soft Roaders (Freelander, Evoque, CRV, X-Trail, Koleos, Captiva, XC60, XC90 etc)...
  15. #95
    Jan 2011
    Thanked: 2348
    Quote Originally Posted by KEKPIET View Post
    Just a point, the 2.2 Diesel motor in the RAV4 was also fitted to the Avensis.
    It was fitted to the Lexus IS in the UK & other markets where it delivered 140kW & over 400Nm of Torque.
    Good motor that...
    Does anyone know the rolling mass of a RAV4 compared to a 'Rok Bi-Turbo 4 motion..?
  16. #96
    Mar 2007
    Thanked: 110
    Default Haldex
    Manny
    AFAIK there is not one Toyota with a Haldex system... VW, plenty... Toyota like the torsen route in the middle..
  17. #97
    Mar 2007
    Thanked: 110
    Default Mass
    Good motor that...
    RAV 4 VX 2.2 - 1585 Kg, Rok = 1886 Kg
  18. #98
    Kathu
    Thanked: 7954
    I have read the comments on the 8 speed auto gearbox of the new Amarok. ZF has always build some of the best gearboxes available. I am sure that the wide ratio choice will do the Amarok good. It is specially designed for economy. It might do good in off - road conditions but you but cannot beat a transfer case. You got 8 speed with the Amarok. If we take the new Ranger 6 speed auto and ad its transfer ratios you have a choice of 12 ratios. The first low on the Amarok is not as low as suggested have a look at the ratio comparison below.
    Amarok ZF 8HP ratios
    1st gear 4.696
    2nd 3.160
    3rd 2.104
    4th 1.667
    5th 1.285
    6th 1.000
    7th 0.839
    8th 0.667
    R 3.300
    Ford Ranger 6R80
    1st 4.17
    2nd 2.34
    3rd 1.52
    4th 1.41
    5th 0.87
    6th 0.69
    R 3.40
    Ford Ranger Transfer ratio
    2.02 low range
    1st 8.42
    2nd 4.73
    3rd 3.07
    4th 2.84
    5th 1.78
    6th 1.39
    R 6.89
    Yes diff ratio`s do differ but it is about available gearbox ratios . If you do this caculation wit a 4 speed auto with low range you still beat the Amarok with available ratios. Wonder how you are going to reverse out of a real tight spot with a 3.300 ratio. You can never beat a transfer case off- road. 8 Speed may be better for the open road but having a look at you last ratios ( 8th and 6th ) for the boxes I doubt. A real granny 1st like in some older boxes have ratios of about 6.7 to 8.0 but the t – case has still the advantage.
  19. #99
    Bellville
    Thanked: 727
    I agree with Manny (a truly mind boggling experience ) - the RAV defaults to front wheel drive and the transfer of power power to the rear is electronically controlled when needed (when there is a loss of traction at the front). During high way towing, there should not be traction loss, so it will effectively be a front wheel drive vehicle, without the drive train losses of a 4wd vehicle. The same should however apply to the 'Rok, but I assume it defaults to RWD. I suspect Manny's comment of power to weight ratio and gearing is the real reason why it feels as if the RAV tows better.
  20. #100
    Jan 2011
    Thanked: 2348
    Thanks Thys.
    I know this is an hi-jack, so apologies.
    Getting back to PUW's statement that his friend finds the RAV4 2.2 diesel a better tow vehicle than the Amarok.
    Now, before I go further, no one is saying the Amarok is not a great tow vehicle.
    The stats;
    RAV4 2.2 Diesel
    110kw @ 3600rpm
    340Nm @ 2000 - 2800 rpm
    Weight 1660kg
    Power to weight ratio 62
    Amarok Bi-Turbo 4 Motion
    120kw @ 4000 rpm - 5000 rpm
    400Nm @ 1500 - 200 rpm
    Weight 2083kg
    Power to weight ratio 58
    So, assuming the boat is the same weight & all else is equal, the RAV4 should tow as good as, if not better than the 'Rok.
    At 100km/h (in top) the RAV will rev at just under 2000rpm, the 'Rok at 1910rpm
    At 3600 rpm the RAV produces, theoretically, 340Nm, compared to the 'Rok's 320Nm.
    I say theoretically as peak outputs can only be achieved at sea level at full throttle...
    So lower weight is largely where the RAV4 scores...
    Again, I am not saying the RAV4 is a better tow vehicle or that the 'Rok is not good.
    I'm just pointing out that the differences are much smaller than one would expect...
  1. Amarok 7800 Km Off road Feedback
    By Bergh in forum Volkswagen
    Last Post: 2014/09/02, 11:29 PM
  2. My Amarok experience
    By Trebla in forum Volkswagen
    Last Post: 2013/10/02, 09:23 AM
  3. New User: VWAmarok
    By Bergh in forum Introduce yourself
    Last Post: 2013/08/15, 09:00 PM
  4. Amarok - Strong and Weakpoints, Hard or Soft Roader?
    By PTA LC 76 in forum Volkswagen
    Last Post: 2012/04/20, 03:02 PM
  5. Monster Delta 'force' Amarok
    By DouglasN in forum Volkswagen
    Last Post: 2011/03/04, 09:07 PM
