Page 2 of 8 FirstFirst 1 2 3 4 5 6 7 ... LastLast
Results 21 to 40 of 154
Thread: 132KW Amarok
  1. #21
    Central Coast
    Thanked: 12
    Quote Originally Posted by Bogaards View Post
    Dankie Schoemie
    PS. Sal ook graag wil voel hoe die Auto ry...
    Ek ook!
    2016 Mitsubishi Triton Exceed
    Previous 2014 AutoAmarock
  2. #22
    Middelburg
    Thanked: 74
    Baie geluk Bogaards.
  3. #23
    May 2007
    Veels geluk Bogaards!
    Jakes
    Just smile and wave boys..... Smile and wave.
  4. #24
    Krugersdorp
    Thanked: 1333
    Dankie ouens. Waardeer dit!
    Bush Lapa Miskruier 586
    Youtube Channel: https://www.youtube.com/c/HenkBogaards4WheelingSA
  5. #25
    Mar 2011
    Kenmare
    Thanked: 48
    Getting back to the 132 auto.
    How exactly will the 8 speed work? I dont want to go and read up on it as I think you okes will give me a better understanding. Is it 8 gears inclusive of the lowrange or what?
  6. #26
    Thanked: 21
    Have they got any indication of price yet??
    If the current 120kw 4x4 Retails for around R420k
  7. #27
    Thanked: 21
    Quote Originally Posted by Eurard View Post
    Nope - no low range! (O, shikes - here it comes!!!) They use lower than ussual ratios for 1st and 2nd gear - together with adaptive engine management and - combined with controlled slip on the torque converter - achieve the ideal ratio and torque to take it where low range would take it. This is simmilar to the systems they used succesfully in other 4motion products.
    Bite off more than you can chew - then chew!
  8. #28
    Klerksdorp
    Thanked: 65
    slip on the torque converter in my mind equates to eventual overheating when you need it most on a difficult trail......
    "Blue Thunder"
    Gert Ferreira
  9. #29
    Thanked: 21
    Quote Originally Posted by BansheeZA View Post
    I am sure VW would have thought of this when they designed the cooling of the box, just like they would have taken the bigger stress on a small motor with high output in account when they designed the little 2 liter!
  10. #30
    Klerksdorp
    Thanked: 65
    look im not dishing the idea/concept of VW, we all now they are brilliant with these complicated things but with the concept there will always be a chance for overheating. same with braked traction controll systems.
    "Blue Thunder"
    Gert Ferreira
  11. #31
    Mar 2011
    Kenmare
    Thanked: 48
    Quote Originally Posted by Vossie View Post
    O okay cool. So you will have very low gear ratios in 1/2 gear and then a NORMAL 1st gear as 3rd. Makes sense.
    So you will only use 3-4-5-6-7-8 when driving on Tar? Or is 8 including the reverse?
    Will the car be set in 3rd and then start there everytime for highway city driving?
    Will it be called 3rd or 1st?
    Lekker klomp vrae, thanks Vosman!
  12. #32
    Central Coast
    Thanked: 12
    Ek het verstaan hy trek weg in 2de. 3de klink beter. Met 8 ratte voorentoe.
  13. #33
    Thanked: 2163
    I think the tech is fantastic, I really do, but I can only see a repeat of the D3's when these are 4 or 5 years old and the warranty's finished, people will be reluctant to buy 2nd hand because of fixing all the tech and the resale will reflect this?? We will have to wait and see??
    FJC - Just Cruising
  14. #34
    Krugersdorp
    Thanked: 1333
    I think the 8th gear is also a over drive...
    Will be interesting to see how it performs...
  15. #35
    Thanked: 21
    If its the same as the other Vollas then its 8 forward gears, numbered 1-8 and reverse. The control system decide which gear to use on pull-off, depending on circumstances. It would then also have an off -road switch which changes the way the box works. As I said - apparently it works very well and the changing is very smooth - to the extent that the driver are not always able to tell which gear is engaged. I also heard that it gears back when you slow down - like on the Pajeros.
    Has anybody, besides Manny, read the May issue of LW - there should be more info in that article WRT the box?
    In the mean time, I'm watching the international forums to see when the first one hits the road - probably in the UK or Germany.
  16. #36
    Mar 2011
    Kenmare
    Thanked: 48
    I have the issue, but scanned it quickly and didnt see a great explaination, will grab a look tonight again.
  17. #37
    Pretoria/Langebaan
    Thanked: 350
    The article does not say anything more than what we have read on the internet except that it mentions an 8-speed DSG box, which it is not. Furthermore the 8-speed is on VW's German website, already available since January this year. (www.vw.de)
  18. #38
    Krugersdorp
    Thanked: 1333
    If I am correct it is not a DSG gearbox, but something else (can't remember the name now).
  19. #39
    Thanked: 1002
    Is it the ZF unit that's been in use by Chrysler for a while now?
    More recently also in the Touareg.
    Attached Files Attached Files
    Johnie
    Volvo XC60 T5
    180kW/350Nm (1500 - 4800 rpm)
  20. #40
    Pretoria/Langebaan
    Thanked: 350
    Quote Originally Posted by JJJ View Post
    Yes, of which over 1 million units have to date been built (for those who will come with their their "unreliability" rants again).
    If you can read germanic: http://auto-clever.de/26972-eine-mil...etriebe-von-zf
  1. Amarok 7800 Km Off road Feedback
    By Bergh in forum Volkswagen
    Last Post: 2014/09/02, 11:29 PM
  2. My Amarok experience
    By Trebla in forum Volkswagen
    Last Post: 2013/10/02, 09:23 AM
  3. New User: VWAmarok
    By Bergh in forum Introduce yourself
    Last Post: 2013/08/15, 09:00 PM
  4. Amarok - Strong and Weakpoints, Hard or Soft Roader?
    By PTA LC 76 in forum Volkswagen
    Last Post: 2012/04/20, 03:02 PM
  5. Monster Delta 'force' Amarok
    By DouglasN in forum Volkswagen
    Last Post: 2011/03/04, 09:07 PM
