Eastern & Southern Cape Mountain Passes Trip – March 2012
Results 1 to 10 of 10
    Default Eastern & Southern Cape Mountain Passes Trip – March 2012
    In my beste Ingels
    The idea for this trip originated from the Eight Passes trip that one can do in the Eastern Cape. Since I first read about the 8 passes, I wanted to do it. However, when I started to draw routes on T4A, I realized that there are many more passes one can travel. We ended up planning to do no less than 54 passes over 16 days and approximately 4520 kilometers.
    Plans and reality do not always come together. We left a day later and had to abandon most of the passes that originated this trip due to extreme wet conditions in the Eastern Cape that made the passes just too muddy and slippery for solo travelers with a trailvan on tow.
    For most of this trip we also tried to stay off highways or N-roads. Did a lot of gravel roads. Following is a list of the passes that we either chickened out on or did not even bother with after speaking to the locals. Also some we missed due to route changes.
    Lundean's Nek Pass (Gravel - 2162m)
    Volunteershoek (Bidstone) Pass (Gravel)
    Carlislehoekspruit Pass (Gravel)
    Naude's Nek Pass (Gravel)
    Elandshoogte Pass (Gravel)
    Potrivier Pass (Gravel)
    Bastervoetpad (Lapa Munnick) Pass (Gravel)
    Otto Du Plessis Pass (Gravel)
    Greylings Pass (Gravel)
    Killian's Pass (Gravel)
    Devil's Bellows Nek Pass (Gravel)
    Katberg Pass (Gravel)
    Prince Alfred Pass (Gravel)
    Montagu Pass (Gravel)
    Paardepoort Pass (Tar)
    Antoniesberg Pass (Gravel)
    Waaipoort Pass (Tar)
    Munniks Pass (Tar)
    Witnek Pass (Gravel)
    Groot-Doringhoek Pass (Gravel)
    Next is a list of mountain passes we did complete, in order of completion. It’s just a pity that a lot of passes are no longer clearly marked. We often could not find a name nor the height of the pass. All one could see, was on the GPS when you pass the marker.
    Kommissiepoort Pass (Tar)
    Joubert's Pass (Gravel)
    Rebelshoogte Pass (Tar)
    Grondnek Pass (Tar)
    Barkley Pass (Tar) – The most beautiful of all the passes.
    Penhoek Pass (Tar)
    Ecca Pass (Tar)
    Zuurberg Pass (Gravel)
    Doringnek Pass (Gravel)
    Van Stadens Pass (Tar)
    Potjiesberg Pass (Tar)
    Uniondale Poort Pass (Tar)
    Outiniqua Pass (Tar)
    The next 7 passes is from the Seven Passes road between Knysna and George.
    Phantom Pass (Gravel)
    Homtini Pass (Gravel)
    Karatara Pass (Gravel)
    Hoogekraal Pass (Gravel)
    Duiwelskop Pass (Gravel)
    Kaaimansgat Pass (Tar)
    Zwartrivierhoogte Pass (Tar)
    Mountain passes we did after the Seven Passes road -
    Schoemanspoort Pass (Tar)
    Swartberg Pass (Gravel) – a Work of art.
    Elands Pass Die Hel (Gravel) - The most scary of all the passes.
    Kredouw Pass (Tar)
    Meiringspoort Pass (Tar)
    Nuwekloof Pass (Gravel)
    Grasnek Pass (Gravel)
    Holgat Pass (Gravel) – Got very nervous on this pass.
    Combrink's Pass (Gravel)
    Ravelskloof Pass (Tar)
    Paardekloof Pass (Tar)
    Rubidge Kloof Pass (Gravel) – This is now on a tar road from the N9 to Nieu Bethesda.
    Naudesberg Pass (Tar)
    Lootsberg Pass (Tar)
    Apart from doing the passes, we tried to include some interesting routes off the beaten track.
    The first was a loop that we took on the R62 just about 14 kilometers before Joubertina, coming from Kareedow’s side. This was absolutely worth the +/- two and a half hours it took us to travel. Do yourself a favor and include this in your next trip along Route 62.
    Secondly it was “Kom se Pad”, just north of Knysna through the Diepwalle and Concordia forests. What a beautiful and scenic route and day trip this was. Will always recommend it to travelers going towards Knysna.
    Next was the trip down the Gamkaskloof to Die Hell. This is another “must do”. We opted not to try and take the trailvan into the valley. Instead we stayed over in Prince Albert for two nights and did a day trip down into the valley. This is a full day excursion.
    From Prince Albert we went via Meiringspoort to Baviaanskloof. Oury biggest regret here, was that we spent way to few days in the kloof. Two nights at Uitspan and one night at Kudu Kaya. We will go back in the not to distant future to explore this area more intensively.
    Last on our to-do list for this trip, was a visit to Nieu Bethesda and the very famous “Owl House”. Helen Martin’s life story brings a lump to your throat. The town is worth 2 nights at least, with a full day of exploring.
ID:	141797   Click image for larger version.
ID:	141798   Click image for larger version.
ID:	141799   Click image for larger version.
ID:	141800   Click image for larger version.
ID:	141801   Click image for larger version.
ID:	141802   Click image for larger version.
ID:	141803   Click image for larger version.
ID:	141805   Click image for larger version.
ID:	141806   Click image for larger version.
ID:	141807   Click image for larger version.
ID:	141808   Click image for larger version.
ID:	141809   Click image for larger version.
ID:	141810   Click image for larger version.
ID:	141812   Click image for larger version.
ID:	141815   Click image for larger version.
ID:	141816   Click image for larger version.
    CT/PE
    I was just thinking of doing something like this after Juan put on that image of all the passes we have in the Eastern Cape. I was thinking to myself I should make it my goal to do em all.
    But seriously... WOW. Awesome.
    Nick "Useless/King of Stuck" Sjoberg
    2000 Jeep Cherokee (XJ) 4.0 litre Country
    * Zone 4.5" Lift & Nitro Shocks * D30 sleeved & trussed * D35Trussed & Chromolly shafts * BDS QD's * 31" Maxxis Trepadors * 15x8j Black A-line's * Rugged Ridge TBS * Zone Steering Damper * Cowley Branches, Maniac Freeflow & Cowley Mufflers * Maniac Hood Vents * Maniac Rocksliders* Maniac Recovery Points * Smash and Grab *
    Previous: 2002 Isuzu KB 300 TDi LX 4x4 D/Cab - Phantom
    Disclaimer:
    All comments and actions made by me were made hypothetically and shouldn't be accepted as fact or tried at home.
    Jul 2010
    Fantasties!! Tannie skuld my nog ne!!
    NISSAN PATROL GU 4.2D
    “Donkey”
    Life is a journey, not a destination!!
    Try slowing down once in a while
    and soak up your surroundings.
    You might just surprise yourself.
    Rangeview Krugersdorp
    For those interested in our wonderful passes there are a few books you might want to get to browse thru. Sadly there are over 490 passes in all so doing them all is impossible. Choose an area or do all the Bain's passes first [32] to see how they 'dry packed' stone which lasts to this day ! Their understanding of drainage was way ahead of their time too. Have a look at; A Colossus of Roads by Patricia Storrar - ISBN 0-620-07593-7 and The Romance of Cape Mountain Passes by Graham Ross - ISBN 0-86486-596-1. Both books I've read over and over and always check them before any trip.
    Chev Aveo and Atos and Polo.
    I've got this book and must agree. Reading up on the Cape mountain passes is very interesting. Like you say - especially Thomas Bain's passes. Had a thorough look at the Swartberg pass and it's amazing to see how it was done. Even with water trenches. A work of art!!!
    IMO one of his finest 'sloots' is found here on the Swartberg ?
    Sunnydale, Cape Town
    WOW!! Now you've really got me fired up for our trip that starts this coming weekend.
    Cape Town to:
    Bontebok Park
    De Hoek Camp
    Mountain Zebra Park
    Mbotyi
    Waterfall Bluff
    Coffee Bay
    Morgan Bay (Double Mouth)
    Cannon Rocks
    Baviaanskloof
    Vleesbaai
    Estimate 3,500km without deviations
    39 mountain passes
    60 rivers (flowing or not)
    10 major dams (at least)
    COME ON SUNDAY!!!!
    I'd rather be fishing, camping or brewing beer...
    Delmas
    Tina, pragtig maar ek weet jy het meer foto;s. Hoe lyk dit met nog?
    Ek moet saamstem die kaap het pragtige passe. Ons het self laas week 'n paar gery -
    Elize
    en ry saam met SarelF in
    VW AMAROK MET BLINKGATCAMPER:
    My Platkar:- Peugeot 208
    Kyk gerus by www.blinkgatproducts.com
    Vir enige aluminium produkte,canopy's, campers kontak gerus
    Sarel 0828209413
    I know it is an old thread but this is exactly what I want to do on my yearly trip in 2014. Want to focus on Bains passes but looking at this list it seems like there are more than enough options.
    Never new there was this this thread. Being doing passes for a while now.
    As said there are an ineradicable number of passes and not all are listed on a single source. Eastern Cape seems to be blessed with a large amount. What I did is went onto the Wikipedia and searched for "mountain passes in South Africa" You then get list per province with co-ordinates. I then plan weekend drives to see if I can take in a few passes. Just another tip, by putting the co-ords into Google earth you get a better idea of what the pass entails.
    Did the 8 passes of the Eastern Cape Highlands end of last year and as said you actually end up doing a lot more. Want to see how many passes I can do. I needs to start a list some day.
  1. Trip Report: First trip to Namibia
    By chris-2 in forum Namibia
    Last Post: 2008/11/11, 02:03 PM
  2. Southern Cape Get Together
    By Dave Faddel in forum Western Cape
    Last Post: 2008/08/29, 09:17 AM
  3. Back from the Eastern Cape
    By SimonB in forum Eastern Cape
    Last Post: 2008/08/07, 08:34 AM
  4. Saddle Hill March 2008 Trip Report
    By Khosaan in forum Namibia
    Last Post: 2008/05/26, 10:33 AM
  5. March Namib trip - suggestions
    Last Post: 2007/11/16, 12:36 AM
