Defender 300Tdi engine Failed
Results 1 to 13 of 13
    Mar 2011
    Thanked: 9
    Default 300Tdi engine Failed
    Decided to spend the day with Swambo and kids at Kungwini, but just after the Boshkop off ramp on the N4 towards Bronkhorstspruit, the Landy just died. It made a horrifying rattling sound, engine immediately stopped and the “Little Black Box” started beeping, temp was fine with no warning lights. Pushed the clutch in and stopped on the grass next to the N4.
    Opened the bonnet and removed the oil cap, a steam-like white smoke came out but the engine didn’t feel excessively hot. Oil and water levels is fine, all belts and hoses 100%. Tried to start but no luck, starter just grinds some gears but the motor doesn’t turn at all.
    2 hours and R850 later we are back in Centurion.
    Any advice on where to start checking and what to look for?
    Serviced 2000km ago, 306000km on the clock. Engine was rebuild on 270 000km.
    AMAROK 2.0 BiTDi HIGHLINE 120KW 4MOT D/C P/U Manual
    Gordon's Bay
    Thanked: 4378
    I'd start with the timing chain or belt..
    FOURWAYS GARDENS
    Thanked: 400
    Snap! Alex. My first thought is the cambelt. The only thing that bothers me is that would have been renewed with the engine overhaul.
    Take Care
    Take Care
    Gordon's Bay
    Thanked: 4378
    Haha, Peter, I was going on symptoms - Until now I didn't know if it was a belt or a chain!
    Maybe not new/ over tensioned/ idler pulley or tensioner bearing seized.. Might even be just the injection timing that's slipped a tooth or something like that...
    But it's a fair bet it's timing related. Hopefully no major damage ...
    Thanked: 451
    Hi BMT
    sounds like the cambelt snapped. This has to be changed every 60'000km. I would take the rig to Landyonline (Muldersdrift) or to Landyworx (Randburg).
    The vehicle will need:
    1 X New Cambelt plus all idler pulleys
    1 X New pushrod
    1 X New rocker
    When the cambelt snaps, it normally damages one pushrod and one rocker arm.
    There will be no damage to pistons or valves. That is why I like the Tdi. You can fix it in the field.
    While you are doing this job, have a new (OE) water pump fitted. Also change the Poly-V belts and the tensioner pulleys.
    It is not a big job, but the cam and pump timing is critical. Brian Cotton of Landyonline sets the pump timing dynamic with a Snap-On tool. This is done VERY accurate. My belt is due for renewal in 15'000km and the pump timing is still 100%. ( you will immediately feel it when it is out due to lack of power.)
    Good luck!
    George Bosch
    Distributor for:
    Mar 2011
    Thanked: 9
    Checked the pushrod's and rockers, all fine, removed sump and found that the crank shaft has broken at no4. will continue to strip the motor today to try and establish what could have been the cause.
    now to find a crankshaft any ideas?
    Thanked: 451
    Quote Originally Posted by BMT View Post
    Hi BMT
    speak to Peter (TGWInduna) at Landyworx, they had a similar case about two months ago. I am sure he can give you some pointers on that one.
    Once you get the new crank, have the journals polished if they check out ok for size and then have the crank assembly with vibration damper (front) and flywheel balanced. This increases redundancy and the bearings will last that much longer, provided the lubrication side is ok. I would also fit a new oil pump.
    A crank you can get from British 4x4 they got quite a few 300Tdi motors.
    Good luck!
    George Bosch
    Distributor for:
    Thanked: 232
    sjoe, broken crank...sounds serious... I'm leaning towards a tdi, but maybe I should keep my 2.8...
    good luck, hopefully it wont cost you too much..
    D90
    D130
    Jan 2007
    Thanked: 43
    Broken crank is not at all common for the 300tdi so I would like to know the reason.
    Mar 2011
    Thanked: 9
    Default Update
    The motor was stripped completely with no other damage at all, just the broken crankshaft. Talked to a few people about this and the following were given as possible causes:
    · Crank was dropped previously
    · Metal fatigue
    · Main bearings not properly tighten
    Well the “new” 2nd hand crank is polished and ready, just waiting for bearings and some gasket sets.
    Mar 2011
    Thanked: 9
    Got the Landy back, motor was stripped completely to assess any damage, turned out to be only the crank and some bearings. Replaced all parts that showed some wear and tear including the turbo and clutch.
    Injectors tested and it seems that the 30 000km they have done from new with 2s0 paid off as they are still brand new.
    Took it for a 300km test drive yesterday and noticed a lack of power at the slightest inclines. Checked the hoses between turbo and intercooler and noticed some oil in the pipes from the new turbo. Surely a new turbo should have no oil leaks Also not sure if the boost is at 1bar but I’m planning to have the diesel pump and turbo checked, not sure where Any suggestions for Centurion area? Intercooler and hoses were properly cleaned during rebuild.
    Jan 2007
    Thanked: 43
    Hi BMT
    If your landy pulled OK before the fix then I would not put the lack of power down to turbo or injectoer pump as surely those were not fiddled with. It could well be that the cambelt was not put back 100% correctly.....timing out by some degrees or even one tooth out is also possible. I would get that checked out by a landy indy before doing anything else. So by the way, there will always be some oil in the turbo to intercooler pipes.
    All of the best.
    Secunda
    Thanked: 76
    Let Landyworx have a look, my 300tdi did the same, lack of power on inclines after the timing belt was replaced, Walter replaced it, ran like a steamtrain there-after.
  1. WJ 2.7 CRD Maintenance
    By wtrlan in forum Jeep
  2. Advantage of a Diesel vehicle?
    By Krimpie in forum Mitsubishi
    Last Post: 2014/12/26, 12:05 PM
  3. Defender price of 300tdi engine and gearbox rebuild
    By Richie rich in forum Land Rover
    Last Post: 2011/04/09, 09:26 PM
  4. Oil leak at the rear of a 300Tdi engine
    By henkc in forum Land Rover
    Last Post: 2007/12/23, 08:42 AM
  5. Raised engine temp on 110 300TDi
    By Landy Nut in forum Land Rover
    Last Post: 2007/03/07, 12:43 PM
