Bush lapa miskruier review - Page 605
Page 605 of 608 FirstFirst ... 105 355 505 555 580 595 596 597 598 599 600 601 602 603 604 605 606 607 608 LastLast
Results 12,081 to 12,100 of 12149
  1. #12081
    Thanked: 2284
    Default Re: Bush lapa miskruier review
    I'd agree that the spring thingies aren't the best for our awnings. We simply don't want to give it room to move and that's exactly why my logic says you don't want the L peg too close to the pole. Then you get vertical movement of the top part of the L. At a 45 degree angle, the rope is perpendicular to the peg part that's in the ground so no way of pulling out the peg. The top of the L (above ground) is then, with some tension, at a small angle to the rope. I'd usually, if the sides are not used, bring the rope down about 30cm on the pole before taking to the L peg.
    On a lose tent / gazebo you want to give slack on the one side and absorb the slack on the other side; then the springs are practical.
    Kooskop - daai steadies is by Tygerberg karavane en effe goedkoper ook.
  2. #12082
    Thanked: 1183
    Quote Originally Posted by fatbike View Post
    I am no bush lapa owner but I use these.
    Joh...those are next level in terms of quality... All you need is the quality van to go with those pegs.... Just pulling your leg... Camping is the answer...no matter what the question is with regards to how....
    Toyota FJ Cruiser
    BMW F800GS
    When in doubt, paint it black
  3. #12083
    Thanked: 1183
    Goed om te weet...dankie.
    Toyota FJ Cruiser
    BMW F800GS
  4. #12084
    PE & North Africa
    Thanked: 376
    Quote Originally Posted by Kooskop View Post
    Good to know. I do have a very nice hammer though... . I have never had any issues with how I do things now and have not had a wing pole go astray yet.. I do however have one pole where the lock mechanism lets go if the wind is really bad. I should probably just replace the lock thingy inside... easy fix but for now the hose clamp stays on the pole and works fine to keep the pole from slipping.
    Janee ons almal doen wat werk vir ons... ekt ook n lekker hammer
    Soos jy sÍ, solank ons kan kamp is dit al wat saak maak.
    @fatbike... those are some fancy pole steadies leke!
    2008 Fortuner 3.0 D-4D 4x4 "Sushi the Tuna" - SOLD
    2018 Baobab 4 - B1543 "Nala"
  5. #12085
    Loevenstein, Bellville
    Thanked: 401
    @Mushashi, I had thought of that, do you not think that would put extra stress on the stubbies and onto the lateral poles? I guess it depends where you place the strap, and just keep it tight enough as a last resort for the wing not to start flying?
    It might add some stress but I don't think anything it can't handle. The function of the storm rope is to reduce movement, not add tension. Basically as a gust comes in under the awning, the canvass itself is stopped before the force is transferred to the frame. There will still be some movement of the canvass but a lot less parachuting/ ballooning and much less force. You need some proper pegs for the storm rope though. If they come loose, you're at the edge of destruction.
    I bought some webbing many many years ago and made my own rope. Fox in Cape Town if I remember correctly.
    Niel
    2012 BMW F800GS
  6. #12086
    Dec 2006
    Thanked: 126
    Attachment 557355
    Who sells them or did you DIY
  7. #12087
    Thanked: 10
    Default Re: Bush Lapa Miskruier review
    Contact Eduard at Stainless Steel Camping Goods. His quality is excellent and delivers to your nearest Postnet. He has a FB page.
    Mitsubishi Pajero 3.2 Gen4 LWB Exceed
    Afrispoor Cheetah
  8. #12088
    Boksburg
    Thanked: 161
    Maxcon also sells them or you can buy at outdoorwarehouse @R45Click image for larger version.
  9. #12089
    Jul 2017
    Dundee
    Thanked: 33
    Quote Originally Posted by Dp123 View Post
    Hi
    Had these made for my BL poles, work like a Charm.
    Dave
    Dave
    BL1942 - The Bug
  10. #12090
    Aug 2018
    Paarl
    Thanked: 49
    Quote Originally Posted by Sebastiaan View Post
    Eduard at stainless steel camping goods
  11. #12091
    Dec 2006
    Thanked: 126
    Please share details, can't find anything on Google
  12. #12092
    Aug 2018
    Paarl
    Thanked: 49
    Here you go
  13. #12093
    Thanked: 96
    There is a fine balance between strength and weight. I'm sure the change in design was not taken lightly in terms of strength.
    As a BL we need a light quick Bushwing setup. So I like the new design.......
    Ps 16:5
  14. #12094
    Jan 2018
    Harare
    Thanked: 94
    Beware of these. I bought 5 of the Maxcon ones for my Baobab earlier this week from Outdoor Warehouse. On arriving home I discovered that rubber stopper on the end of the poles for the bush wing are larger than the holes in the support. The pegs are made of sprung metal and are very difficult to stretch open. I was able to enlarge the holes using a vice, large hammer and heavy duty chisel but it was a real struggle.
    John
    2014 Toyota Hilux 4x4 3.0 D4D
    Baobab BL1715
    Don't let your dreams remain dreams
  15. #12095
    Plett/Paulshof
    Thanked: 903
    Quote Originally Posted by Tedx2 View Post
    I just remove the rubber feet and refit.
    2020 FJ Cruiser, 2020 Audi Q5S Tdi, 2019 VW Tiguan 4motion 2.0tsi(work vehicle), 2019 FJ Cruiser, Bush Lapa ?, Fusion 17 boat-Yamaha FT100hp 4st.
  16. #12096
    Clanwilliam
    Thanked: 18
    Do you remove and refit every time or leave them on?
  17. #12097
    Plett/Paulshof
    Thanked: 903
    Quote Originally Posted by HiluxRoux View Post
    Every time, takes 10s no big deal
  18. #12098
    Oct 2006
    Thanked: 131
    After selling our Comfortvan a couple of years ago due to not using it, we are ready to get back into caravanning. After tons of research the favourite was the Baobab but it is larger than what we need and won't go into the garage. I figured the Boskriek would be ok as we are only 3, but the Miskruier beds and roof appeals the most. Going to get final ok from the boss (wife) on Saturday, at BL. Hoping I'm making the right choice Oh and thinking of ordering it in white.... Any advice on my choice, extras etc. would be appreciated
    CAMP AND CLIMB -
    Website
    CENTURION
    012-665-2079 e-mail BELLVILLE 021-949-0039 email
    PAARDEN EILAND 021-510-8112 e-mail
    Shop Securely Online at www.outdoorshop.co.za - Please contact the shops directly for fast service!
  19. #12099
    Brackenfell
    Thanked: 237
    For your needs the Miskruier will be perfect. You will never regret your choice.
    Uys Snyders
    Trailblazer 2.8DuraMax
    Bushlapa Vlooi B237
  20. The Following User Says Thank You to Uys Snyders For This Useful Post:
  21. #12100
    Plett/Paulshof
    Thanked: 903
    Quote Originally Posted by Dogbert View Post
    The space inside the Baobab and the easy entry door were what sold me on it initially. For 3 people it would be ideal, especially when all 3 are getting ready for bed etc. However if this is not an issue and you find getting in an out the rear hatch is ok and you happy with interior space then the Miskruier is great. I find the Baobab for longer trips and especially winter allows better packing space...much better. The Miskruier now has pop up roof which is great for headroom. I saw a guy at the show on Saturday who was inside the Miskruier with his wife and dad no way could he live with the limited space and prefers the Boaba as he can move around easier. He was a biggish guy.
    For 2 people the Baobab is just too much van therefore I'm selling.
  1. 3 Bush Lapa Miskruiers in one spot!
    By Kooskop in forum Trailers, Caravans, Towing etc
    Last Post: 2019/12/29, 07:25 PM
  2. Bush Lapa Miskruier featured in.....
    Last Post: 2011/10/03, 03:18 PM
  3. Kyknet Buitelug Expo - Bush Lapa range
    Last Post: 2011/09/29, 08:20 PM
  4. Bush lapa's "miskruier" tested
    Last Post: 2011/07/27, 08:19 AM
