Reverse gear on in a 6 speed manual Rubicon
Results 1 to 8 of 8
    Thanked: 76
    Default Reverse gear on in a 6 speed manual Rubicon
    Hi Guys
    From day one selecting reverse has always been a little tricky, it feels like its in but then some times pops out or grinds unless i double check every time....I dont suppose this is normal is it?
    Jayson
    2016 Toyota Fortuner GD6 Auto
    2012 Jeep Grand Cherokee 3.0CRD
    2011 Jeep Cherokee
    2006 Jeep Grand Cherokee 3.0CRD-50mm EFS Lift, GDE Tune
    2009 Jeep Rubicon-50mm Coil Lift, Branches, Free Flow, K&N, MT`s
    2013 Suzuki Vitara-40mm lift
    2012 Suzuki Jimny-Fully Kitted.
    2007 Jeep Cherokee-Std
    Thanked: 16
    Mine does exactly the same. You get used to it eventually.
    2010 Jeep Wrangler Rubicon 3.8l
    3" J-Spec & Bilstein Suspension Lift
    Bilstein Steering Damper
    JKA Front Stubby Bumper
    33" Cooper ST Maxx
    Superchips Flashpaq
    Frontrunner Slimline II Roofrack
    Westward Ho!
    Thanked: 9
    Select first, then second and then reverse. Aligns it all to engage reverse easier...learned that driving old Alfa Romeo's where the syncromesh in the gearbox was worn a bit.
    2005 Jeep Cherokee 3.7 Limited | Sold
    2010 BMW F 800 ST | For the daily grind
    "In the beginning was the Word, and the Word was with God, and the Word was God."
    Orkney
    Quote Originally Posted by Jay4 View Post
    Hi Guys
    Jayson
    Jay, it is a Jeep thing you well get use to it
    DBJeep
    JEEP
    Since 1941
    Thanked: 76
    Ok thanks boys, good to hear its common. This Rubicon is starting to develop a real little personality
    2011 Jeep Cherokee
    May 2014
    Kroonstad
    Thanked: 18
    Mine as well Jayson . You'll get used to it.
    3.8 Rubicon 2Dr Manual . 2.5 Synergy Lift with Fox Shocks . Kumho KL71 Mt's.Rickstop front and rear bumpers.
    Dec 2011
    Thanked: 19
    My CRD unlimited Highsport 6 speed does exactly the same. I keep the gear lever pulled back until the Jeep start moving backwards.
    2007 Jeep Wrangler CRD unlimited sport 6 speed manual
    1973 Range Rover
    2001 ML 320 petrol
    2006 Conqueror Supra
    Thanked: 32
    Quote Originally Posted by Hollebollegys View Post
    Is your Jeep Black?
    2011 Jeep Grand Cherokee Overland 5.7
    Previous Jeeps:
    2012 JKU Rubicon 3.6 V6 on 37's with Synergy 5" Lift Kit with Fox 2.0 Factory Racing Shocks with Synergy Adjustable Control Arms
    2010 JKU Rubicon 3.8 V6 on 35's with Synergy 4" Lift Kit with Fox 2.0 Factory Racing Shocks
    2008 JKU Sahara 2.8 CRD 6sp Man on 33's with Full Traction 3"
  1. AT Tyre Tests
    By kalahari in forum Tyre chat
    Last Post: 2016/04/02, 08:58 PM
  2. Replies: 6
    Last Post: 2014/03/18, 02:23 PM
  3. Problem With Reverse gear on Navara
    By Henricow in forum Nissan
    Last Post: 2013/08/05, 02:06 PM
  4. Using Diff-lock on steep descent
    By piers in forum General 4x4 Discussion
    Last Post: 2008/12/09, 01:19 PM
  5. JK Rubicon Gear ratio change.
    By Joenel in forum Jeep
    Last Post: 2008/09/11, 09:36 PM
