Cherokee Your honest opinion on the XJ TD
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 42
    May 2008
    Default Your honest opinion on the XJ TD
    Hi everyone
    My boet and I have always loved Jeeps and are both currently trying to buy a Cherokee. has He is looking for a newer model, but his little brother(aka me) has always loved the older square XJ. I would preferably like to purchase the turbo diesel model but know nothing about these vehicles at all - other than the fact that they give me goosies every time I see one!
    Can you guys please give me your honest opinion on if they are generally a safe buy and if I am looking things that I'd need to be mindful of and check before buying? Your help on this one would be much appreciated!
    Looking forward to joining the fray very soon!
    Kind regards
    Lyle
    Thanked: 568
    Hi & Welcome Lyle
    Honest opinion = don't buy a diesel XJ. They are trouble.
    Rather go petrol if you want an XJ
    Thanked: 568
    The TD XJ is powered by the VM Motori 2.5-litre diesel engine, which is effectively an Italian boat engine. They generally battle with the SA heat. It has 4 separate cylinder heads which cost a fortune to replace, as do the injectors.
    The fuel consumption is not particularly good for a diesel either - 14L/100.
    The 4.0L actually makes slightly more torque than the diesel, so there is no real reason, that I can think of, that would make someone buy one
    Dec 2006
    Durbanville, Otjiwarongo
    Thanked: 101
    All XJ junkie says... except that the fuel consumption unmodified is closer to 9l/100km. Mine with bigger wheels, knobblies, lift, roof rack and full load got 12 on a trip to and back from the Richtersvelt. I thought that was quite heavy. I subsequently found out the intercooler was clogged solid with mud so I could have been doing less. Before the lift and modifications I would be happy with a sub 10 on a trip and 12 in town.
    I like my Jeep but it has been in the family since day one and looked after. Cooling issues were sorted out by having a good cooling system flush and fixing the viscous coupling. And using anti-freeze.
    So like anything looked after it is a good vehicle. The problem is finding a good one.
    XJ Td 140Hp 236 ft lb torque
    XJ petrol 190Hp 225 ft lb (for post 96 models)
    Petrol fuel consumption:
    12-15 l/100km open-road
    15-19 l/100km town only
    That is why you consider a diesel.
    Offroad during the Hex trail myself and 3 XJs all filled up at Winelands on the way there and I used a quarter tank for a whole days rock crawling... XJs and Tjs were worried and looking for a petrol station in De Doorns. Petrols offroad have a big drinking problem. That is why you would consider a diesel.
    Also during the Hex I had to live with the constant squealing of brakes from the petrols on the long technical descents while the diesel was happily chugging along on engine braking. That is why you consider a diesel.
    That is why I love my Diesel.
    Only issue I really have is that the noise it makes starting up scares all the wildlife away... and the noise it makes when turning off is almost as bad.
    Oct 2008
    Grabouw
    Thanked: 232
    Quote Originally Posted by Biggles View Post
    Biggles, but you are also comfortable working on your diesel and probably maintaining it whereas the 4.0 needs less TLC
    Thanked: 568
    The figure of 14 I quoted was from CAR mag, but they didn't actually do a road test
    Nah, this is a myth. We just stop to see if the pumps are all working ok
    The petrols have to use brakes to stop going into the back of diesels
    Only issue I really have is that the noise it makes starting up scares all the wildlife away....
    ....& the chicks - they don't dig diesels
    Wilderness
    Thanked: 1221
    My 2.5 does 9.4-9.8l/100km. But then i drive softly.
    The Vm motor is now made by Detroit motors. The London Taxis now run on the 2.5 Vm motor. It is not as fast as all the other but will comfortably do its 120 on the open road. Boy oh boy! Put it offroad! Its like a tractor. Low, 1st and take your foot of the juice and it will climb most obstacles while idling.
    My Jeep rusted the welch plugs through and i am currently doing the repairs myself. Head Gasket R1080. Inlet+ exh gasket R150. Welch plugs R30 for 8. The rest is elementary and elbow grease. While doing all this i have removed the Viscous fan and have fitted a 16" electric fan. This should give me another km or 2 on fuel. And a few horses.
    Unfortunately my Jeep was a lemon when i bought it, but it still is a good vehicle, as all Jeeps are. Electric seats, aircon, speed control, power steering. Good ground clearance and the possibility of many mods to make it exactly what you want it to be. Dont listen to the petrol heads, they dont know what they are talking about. The only thing they know is that the service intervals is a bit shorter. But that is why a diesel lasts longer.
    Enjoy
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
    Thanked: 568
    @Pieterk.....we all know you want a 4.0L
    Oct 2006
    CAPE TOWN ,SOUTH AFRICA
    Thanked: 565
    Hey biggles, howzit ...i recall you have the Hyster engine in your Jeep ....
    ORA
    Ian
    Dec 2006
    Thanked: 101
    Servicing is no more difficult than any other diesel and much easier than a petrol. Oil and filters.
    Junkie... Chicks dig diesels. Something to do with low revs and the vibrations.
    Thanked: 568
    Nah, that your SYE coming loose
    Wilderness
    Thanked: 1221
    @ XJ Junkie. Unlike some persons i dont suffer from an inferioriority complex and dont need bigger things as a crutch. Its all in the vibration and the way it ticles. With smaller things you need the right techniques.
    Unlike some who are closet diesel fans and tel everyone that diesel stinks?
    Malpas, UK
    Thanked: 30
    2 images spring to mind when talking about XJ TD's
    Steve Wright
    2007 Grand Cherokee CRD Overland
    2017 Renegade Ltd, SWMABO's ride
    Planet-X London Road x2 & 2011 Cube Analog, powered by chips & beer
    Previous Jeeps- 8 XJs, 3 KJs, 3 WJs, 2 TJ's & an MJ
    CPT
    I know of only two people that has been reasonably happy with the XJ 2.5 and its Biggles and Pieter all the others I have met have spent $$$ on it.... somoene on the forum wanted to an axe to it awhile ago and sold it.
    I would not recommend the 2.5 or the 3.1 to anyone.
    The 4.0litre petrol is a much better option.
    Water covers 3/4 of the earth, Jeep covers the rest.
    Henties
    Thanked: 747
    Unless you are confident to be able to identify a technically spotless one and do most of your repairs & maintenance yourself, rather go for the 4.0 petrol. That motor is said to be bulletproof.
    As I said a couple of times before: I have NOT been able to save money by driving the turbodiesel version of any vehicle vs. the petrol version. All the fuel savings (and more) went into maintenance.
    There are a few turbodiesel engines out there, I would still buy 2nd hand (e.g. Isuzu D-TEQ) but the 2.5 Vm Motori Jeep is certainly not one of them.
    2012 FJ Cruiser
    1983 FJ60 Landcruiser
    Thanked: 568
    Can't sell it then hey?
    Douglasdale Fourways
    Thanked: 8
    I had the second 2.5 Diesel in South Africa. Drove it 105 000 km before I sold it. The only thing that broke was the idler tensioner pulley. I was a fantastic car but could not stop for love or money. The brakes were pathetic to say the least. If I had gone with my gut feeling on this purchase I would of bought the Country with ABS. Other than that what a car. When I drove on the 4x4 course it made the other 4x4 look a little silly. The instructor could not get it stuck while trying to show how to get out or a axel twister. Do not leave this thing in low and in 2nd gear and climb out the cab, you will fetch it in Cairo. What an underrated 4x4. I loved mine. I also had a button fitted on the dash to bypass the stupid idea that you had to have your foot on the brake to start it.
    sorry one last point. It is still driving around today saw it not so long ago has two little dolphin stickers above the Sport logo on the door. Maybe someone on the forum actually has it.
    Thanked: 568
    Quote Originally Posted by kevjones View Post
    Lol. Brilliant
    Dec 2006
    Thanked: 101
    I would keep an eye out for one with a fubared engine buy it for nothing and drop in 3.0D4d or something similar. The 2.8Td VM used in the later Cherokees should also fit.
    CY ek sÍ!
    Steve......don't even think to bastardize a XJ. You will be sent to hell camp!!
    It's a J e e p thing...........you would'nt understand!!
    Ek ry met stok-ou Jeeps, want dan dink almal ek's al lankal ryk!!
    Gee vir my 'n Coke......skoon Coke......met 'n dubbel Brannas in asseblief!!
  1. Opinion on Makro Wilderness Trailer
    By DeVilliers in forum Camping, Fridges, Accessories
    Last Post: 2012/04/22, 09:06 PM
  2. influencing public opinion
    By Brian1 in forum The 4x4 Pub
    Last Post: 2011/12/07, 05:39 PM
  3. Leeupoort Holiday Village
    By Senyetse in forum The 4x4 Pub
    Last Post: 2010/03/03, 11:37 AM
  4. UV Filters - your opinion please.
    By Sniper in forum Cameras & Photography
    Last Post: 2009/08/31, 09:38 AM
  5. Superwinch....your opinion Yes or No...
    By JeanCT in forum 4x4 Recovery & Recovery Gear
    Last Post: 2009/07/20, 07:18 PM
