Death Wobble - Explanation - Page 2
Page 2 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 21 to 40 of 204
  1. #21
    Maroeladal
    Thanked: 33
    Quote Originally Posted by Jean Kotze View Post
    Why is this not a sticky yet?
    Rich
  2. #22
    Botriver
    Thanked: 82
    Was thinking about this a bit more today - our 1930 Graham Paige sometimes gets a death wobble at low speeds - you have to stop to make it go away
    Thankfully when it happens we might be going at about 30-40km/h
    I don't wanna know what it's like at a higher speed.
    PS. We have no idea why it does that
    '65 Jeep Wagoneer
    SOA conversion
    Work in progress....
    https://www.facebook.com/Honingklip-...6324709414350/
  3. #23
    Thanked: 563
    Richard, the higher the speed, the more energy the beast has to feed from, the bigger the in your pants.
    '89 LR 110 V8
  4. #24
    Gordon's Bay
    Thanked: 4378
    Mike, it's a good thing defenders are too scary to go over 80 or more people would understand the death wobble!
  5. #25
    Thanked: 563
    Quote Originally Posted by RichardMiddelmann View Post
    .......PS. We have no idea why it does that
    The maths for an exact solution is complicated, but the principle is simple. It is a resonance with positive feedback due to the interplay of axle lateral location stiffness and steering mechanism layout. At the "correct" speed, any small shimmy disturbance on the front wheels set the resonance in motion, the DW rapidly build from there. Theoretically a perfectly healthy set-up will also run into a DW, but the design parameters should ensure that it lies at an unatainable speed, even for a Jeep :-)
    '89 LR 110 V8
  6. #26
    Vereeniging
    Actually quite common on Defenders, happens at lower speeds though, around 80 km/h (the road speed at which DW happens depends on the natural frequency of the front axle system, Jeeps have pressed plate light duty components not weighing much, therefore natural frequencies tend to be higher, Landies have proper solid heavy duty components, therefore the natural frequency is lower. )
    Had it four times in one day, at an ever decreasing speed. First one at 80km/h, second one at 65km/h, third at 60km/h. last one at 40km/h. That was in one trip trying to get home! Did the last few km's at 10km/h, to scared to go any faster.
    89 110 3.5 V8
  7. #27
    Maroeladal
    Thanked: 33
    Quote Originally Posted by Combrink View Post
    Chicken
    Rich
  8. #28
    Boksburg
    So this only happens with cars with solid axles??
    '92 4.0 XJ
    Just Enough Essential Parts
    ‎=====o00o_
    //___|__,\____\,__
    |_---\____|---[]|||||[] ]
    (o)_)-o- (o)_)--o-)_)
  9. #29
    Parklands
    excellent post.
    WJ V8 4.7L, 2inch IronMan Suspension, 30mm spacers ,Maniac front diff truss, Iron Rock Adj TrackBar, Zone Steering Stabilizer, Bulli Prop, DIY BumpStops, 16" steelies with 265-75-16 Mud BF's
    Audi 1.8t 8)
    CBR 1000 Repsol
    No Replacement for Displacement
  10. #30
    andre` Guest
    Although it is not complete and not completely true on actual causes.
  11. #31
    Maroeladal
    Thanked: 33
    Quote Originally Posted by andre` View Post
    Andre, feel free to add. The benefit of this thread is that if something else is found, the user can add their experience/knowledge and everybody benefits.
    Rich
  12. #32
    Out of Town
    Thanked: 665
    Can anyone say if the death wobble is more prevalent on coil sprung suspensions than the older leaf sprung setups. I'm working on a SFA for the Sani and this has been something that has bugged me for a long time.
    I have been through a death wobble on a Army Samil 20 that ended me in the bushes next to the road, and a 1983 Safari that would cause it's EFI ECU to reset due to the violence and the action. Both of these were leaf sprung.
    Most my research on the net (youtube) shows the problem on Coil and Panhard rod setups. Only found one on leaf type and nothing yet on 4 link.
  13. #33
    andre` Guest
    Quote Originally Posted by Jeep Luvva View Post
    I will do a complete write up on my experience in conjunction with Shane JKA. I had the whole whammy last month and there is a lot more involved.
  14. #34
    Stilfontein
    Thanked: 617
    What lift kit did you fit to your Jeep??
  15. #35
    Apr 2008
    BLOEMFONTEIN
    Thanked: 101
    Quote Originally Posted by HeinrichC View Post
    Whether the vehicle was lifted or not is also an important factor. When relaying your experience and solutions state whether the vehilce was lifted or not.
    Mine for instance is a standard WJ. Will post once the problem is solved.
  16. #36
    Maroeladal
    Thanked: 33
    That would be great
    Rich
  17. #37
    andre` Guest
    I have an AEV kit that has been installed 2 years ago. My deathwobble was caused by everything on the front suspension and steering except the control arms failing at the same time. My ball joints had serious play, the one actually fell apart when it was pressed out, Tie rod, track bar, steering box. The steering box was reconditioned 3 times and eventually I decided to buy a new one. Even with everything new, if I fit the old OME damper, the death wobble is back. I have a standard damper now and I can feel the force of the 37" on the steering components. Will hopefully have a Fox damper by tomorrow.
  18. #38
    PTA
    Nice one Rich, finally a sticky \m/\m/
    3.6 Jeep Wrangler JKUR
    XRC front stubby
    XRC back bumper with tyre carrier and duel Jerry can holders.
    XRC Flat fender flares.
    Synergy 6" Full Long-Arm Suspension.
    JKA Suspension Brackets.
    17" Moto Metal rims with 37" Goodyear MTR Kevlar's
    LIFE IS TOO SHORT
    TO NOT DRIVE A WRANGLER
    3.8 Jeep Wrangler Unltd ( Sold - Awesome Times)
    2.8 CRD Jeep Wrangler Unltd ( Sold - Good Times )
  19. #39
    Stilfontein
    Thanked: 617
    37's wow, now that's big
  20. #40
    Gordon's Bay
    Thanked: 4378
    on a leaf spring set up, the leaves provide the transverse location (i.e. stop the axle shifting left to right) thus there is no possibility of serious death wobble.
    On most front axles with springs, axle location is by means of a panhard rod, so it's pretty much specific to the panhard rod (track bar for the 'mericans) systems, however, while I've never heard of watts linkage or 3 link location fitted to a steering axle, I am sure it could happen with any transverse link type locating system.
  1. Death Wobble / Balance Wobble
    By PeakRanger in forum Ford & Mazda
    Last Post: 2012/01/28, 08:42 PM
  2. Help with JK Death Wobble - Cape Town
    By Oppers in forum Jeep
    Last Post: 2011/10/31, 02:14 PM
  3. Death Wobble - Please Help!!!
    By min in forum Jeep
    Last Post: 2010/10/07, 10:42 AM
  4. Ford & Mazda Death Wobble
    By CoJack in forum Ford & Mazda
    Last Post: 2010/09/08, 07:54 AM
  5. Steering damper replacement?
    By Bad Santa in forum Jeep
    Last Post: 2007/03/18, 10:13 PM
