Differences between a normal lead-acid car battery and a deep cycle battery.
Results 1 to 20 of 21
    Thanked: 498
    Default Differences between a normal lead-acid car battery and a deep cycle battery.
    Fluffy, this was your suggestion.
    There should varying opinion on the subject. The text below is taken directly/unmodified from the source stated.
    Courtesy of: http://auto.howstuffworks.com/question219.htm
    People who have recreational vehicles (RVs) and boats are familiar with deep cycle batteries. These batteries are also common in golf carts and large solar power systems (the sun produces power during the day and the batteries store some of the power for use at night). If you have read the article How Emergency Power Systems Work, then you also know that an alternative to gasoline-powered generators is an inverter powered by one or more deep cycle batteries.
    Both car batteries and deep cycle batteries are lead-acid batteries that use exactly the same chemistry for their operation (see How Batteries Work for more information). The difference is in the way that the batteries optimize their design:
    • A car's battery is designed to provide a very large amount of current for a short period of time. This surge of current is needed to turn the engine over during starting. Once the engine starts, the alternator provides all the power that the car needs, so a car battery may go through its entire life without ever being drained more than 20 percent of its total capacity. Used in this way, a car battery can last a number of years. To achieve a large amount of current, a car battery uses thin plates in order to increase its surface area.
    • A deep cycle battery is designed to provide a steady amount of current over a long period of time. A deep cycle battery can provide a surge when needed, but nothing like the surge a car battery can. A deep cycle battery is also designed to be deeply discharged over and over again (something that would ruin a car battery very quickly). To accomplish this, a deep cycle battery uses thicker plates.
    A car battery typically has two ratings:
    • CCA (Cold Cranking Amps) - The number of amps that the battery can produce at 32 degrees F (0 degrees C) for 30 seconds
    • RC (Reserve Capacity) - The number of minutes that the battery can deliver 25 amps while keeping its voltage above 10.5 volts
    Typically, a deep cycle battery will have two or three times the RC of a car battery, but will deliver one-half or three-quarters the CCAs. In addition, a deep cycle battery can withstand several hundred total discharge/recharge cycles, while a car battery is not designed to be totally discharged.
    Eggie.
    - apology to Edward Langley.
    Hillcrest, Malaysia
    Thanked: 5972
    Quote Originally Posted by Eggie View Post
    That article is so riddled with rubbish that it doesnt warrant comment.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
    Thanked: 498
    Now that sounds like a solid thread killer... It was your suggestion so don't be scared, or as they say, laat waai my ou!
    Eggie.
    Hillcrest, Malaysia
    Thanked: 5972
    Too early in the day for a good technical discussion. Everybody is still sober.
    But here is an appertizer.
    Several hundred TOTAL discharge and charges.. mmm several hundred is at least 300. In practice - one holiday a year with 10 total discharge charges per day ( almost impossible to do ) buit lets say you manage to totally discharge and charge a 102Ah battery in 24 hours. That battery should last 30 years.
    Similar logic, once a month, 2 days, lets say 10 years.
    Ok you camp a lot, lets say every week, 52 times a year for two days, lets say 104 total discharge/charge cycles a year. Right so you are going to totally discharge/charge a battery twice every week for 3 years, yea right.
    To be honest I am leading the jury here, just laying down some thought for the real crux of my position....
    ZS5KAD
    3 V8's
    Dec 2010
    klerksdorp
    Thanked: 99
    is their anybody out there that knows about batteries?
    Thanked: 498
    Similar logic, once a month, 2 days, lets say 10 years. No logical logic found here.
    Do not read specs in isolation. You are stretching things, and I know you know this. Prudent would be rather to provide the explanation why this does NOT work the way you suggest here, although many would not even need that. Again I know that you know this too.
    Have a cold one (or more), and get back. Would love to hear about the "crux" thing...
    Eggie.
    I've got my glass of wine, let's get going.
    Bryan
    Disco 4 SDV6 S (me)
    Jeep Cherokee CRD (swambo)
    Hillcrest, Malaysia
    Thanked: 5972
    Right, so we have had no power since Friday evening.
    I have just had a cold bath.
    Mind you, the Engel is running on my high cycle Royal battery, so the beers are at least cold. Pity about the kreef and fillet in the deep freeze.
    ZS5KAD
    3 V8's
    May 2010
    Bergbron, Roodepoort
    Thanked: 208
    Quote Originally Posted by johnnybritz View Post
    There are too many. It's like the controversial "which is better, diesel or petrol" or "Toyota or Landie" or ...
    Franz
    Wartburg.
    Thanked: 491
    Diesel and yes Toyota ofcourse
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
    Thanked: 498
    Battery selection, performance, durability, suitability is subject to different factors. That is primarily what makes this a controversial and sticky subject.
    What I say and what you say could be different, but both could be accurate (or wrong) - the context determines this. Grabbing a few specs and elaborating on that can easily be misleading as Fluffy so colourfully demonstrated. I hope the cold bath helped. And get that solar water system installed before Eksdom puts us all in the dark & cold.
    Now lets get started with that thing about so "riddled with rubbish that it doesnt warrant comment" bit. I have six cold ones at the ready.
    Eggie.
    Thanked: 2322
    neither is better than the other (same as vehicles) - it depends on the application
    Normal Batteries
    - large power in short bursts
    - doesn't like being run down flat
    - less charging cycles lifespan
    - fast charge
    Deep Cycle Batteries
    - low power in long duration
    - can be run down fairly flat without negative effects
    - more charging cycles lifespan
    - prefers slow charge
    These points go into great detail and the variances of it can be discussed to no end as is some brand comparisons.
    JBay
    Thanked: 238
    Normal Batteries
    - fast charge
    This might be true for Flooded Lead Acid batteries, the everyday car battery of a few years back, but with Gel and especially AGM, things have changed big time.
    Patrol TB48
    Patrol TD42T
    Ex-4x4-partners:
    105 Cruiser
    80 Cruiser
    60 Cruiser
    Tdi Defender
    2.8D Hilux
    http://4x4africa.co.za/
    Thanked: 498
    Kiri, is it not true that the average/typical car battery is still of the flooded type?
    Gel is not suited to car starting, whereas AGM will do very nicely, but at a premium (cost).
    Eggie.
    JBay
    Thanked: 238
    Eggie, I replied to the post of Marius"the everyday car battery of a few years back"
    His advantages of starting and deep cycle batteries don't hold water any longer, with new Gel and AGM technology.
    Patrol TB48
    Patrol TD42T
    Ex-4x4-partners:
    105 Cruiser
    80 Cruiser
    60 Cruiser
    Tdi Defender
    2.8D Hilux
    Kathu
    Thanked: 2375
    Why do you want a deep cycle battery if you fridge cut out at about 11v
    automatically ? My last deep cycle battery packed up a few months ago ( about 4 years old. ) I replaced it with a sealed car battery. Yes if you run lights and stuff and really needs to drain a battery I will go Deep cycle.
    grips
    Thanked: 498
    Why do you want a deep cycle battery if you fridge cut out at about 11v automatically ? My last deep cycle battery packed up a few months ago ( about 4 years old. ) I replaced it with a sealed car battery. Yes if you run lights and stuff and really needs to drain a battery I will go Deep cycle.
    grips
    Grips, 11V is not a magical voltage cut-off point that will save your battery for long service. With all factors taken into account that 11V cut-off means that your battery will probably recover by itself to about 12V when the load is disconnected. Check this with a meter 30 to 60 minutes after disconnect.
    It means that your battery is now about 75% discharged. Bad news for a car battery. You will have a battery that will die on you way too soon when you do this. Your deepcyle is better dsigned to handle just this very type of "abuse".
    Eggie.
    Kathu
    Thanked: 2375
    Eggie ,
    I agree with all the above said . The point I want to make is that my dual battery seldom has to power my stuff for longer than 12 hours with out a charge. Have not once run a battery flat. The only time I had trouble was when a T-Max system packed up. I am in the Electro technical field an know all the tech stuff about batteries and charges. Two of my Deep cycle batteries in my Off road caravan packed up during last year. I usually trickle charge them when in storage. A friend of mine only uses lead acid batteries for camping purposes and he got about similar life out of his batteries than me. But horses for courses , yes if your application need a deep cycle install it.
    grips
    North of Zambezi
    Thanked: 356
    Some interesting battery resources
    Thanked: 498
    Don't you also find it interesting that nowhere on these (and other) battery "bible" websites do you find any reference to the "new" lead crystal technology?
    Eggie.
  1. High Cycle or Deep Cycle for Aux Battery
    By Gerrit Loubser in forum Vehicle & Technical Chat - General
    Last Post: 2015/10/09, 04:05 PM
  2. DEEP CYCLE Vs. ORDINARY CAR BATTERY?
    By Jaybee in forum Camping, Fridges, Accessories
    Last Post: 2010/11/07, 06:13 PM
  3. Stoor van battery
    By HendrikG in forum Camping, Fridges, Accessories
    Last Post: 2010/09/28, 03:59 PM
  4. Charging deep cycle battery with normal charger?
    By BigRed in forum Camping, Fridges, Accessories
    Last Post: 2009/10/13, 05:55 AM
  5. Re-surrecting an old battery
    By Frans in forum Vehicle & Technical Chat - General
    Last Post: 2009/02/09, 10:06 PM
