DeWildt
Results 1 to 20 of 21
Thread: DeWildt
    jhb
    Default DeWildt
    Did most of this a few days ago. They say it is rated 1-5. Does anyone know what obsticles are a 4 or a 5, how is this determined and who does so?
    Just interested...
    Thanked: 1022
    Their toughest obstacles are Gert se klip, and another rocky piece that most people miss. Immediately after entering the gate, turn right and follow the fence. At the stream, you turn left and there is a toughish obstacle there where you have to be carefull.
    I don't know who gives the ratings, but I would not have given it a 5 for sure.
    Thanked: 368
    Jup, I wouldn't rate any part of dewildt as a grade 5 either. But its a fun trail non the less
    JHB
    I did Gert se klip in the jeep with HT Sport tires with my eyes closed & napping behind the wheel..
    That other Section, I did not even try as clearance is an issue with the Jeep..
    I would rate Dewild a 2 to 3 with that other section a 4.. but this could raise by 1 if its raining
    Thanked: 7
    The other section,
    we were going down
ID:	126366   Click image for larger version.
ID:	126367   Click image for larger version.
ID:	126368   Click image for larger version.
ID:	126369   Click image for larger version.
ID:	126370   Click image for larger version.
    Francois Hamman
    2011 Nissan Patrol 4.8GRX
    1992 Mitsubishi Pajero JDM SWB 3SGTE ST205 32x11.5x15 Maxxis Bighorn
    Vtown
    Thanked: 101
    I think one should always rate your 4x4,as well as conditions when 'rating a trail'
    What a guy might find easy in a modern electronically aided 4x4,or locked axles,will be a lot more difficult in a old school truck.
    I often hear guys smugly remarking how easy it was-not talking about De Wildt specifically,I tell them to do it again in a Series 1 Land Rover,or similar,if they can do that,they have my respect.
    Baboons Pass is a good eg-have the right truck,good conditions,road already built from recent travellers,do it in 6 hours.
    Do it in the snow in a standard older 4x4........
    A legend in his own mind
    Thanked: 217
    Very well said Bob I drive a Defender with NO powersteering , NO lockers ! Axle twisters can at stages be a nightmare , one front and one rear wheel in the air , and i have a problem Steering is also not that easy as this Defender is heavy
    2004 Defender TD5
    1992 Defender 3.5V8
    PROJECT OVERHAUL http://4x4community.co.za/forum/show...oject+overhaul
    Bethlehem
    Thanked: 136
    De Wildt dry is probably a 3, but if it was pouring with rain, you will not get through some of the mud holes at the top of rocky river route in any vehicle, hence I think the 1 - 5 rating
    even the rocky river route I would rate a 3 when dry
    Rmember though that weather conditions changes a trail very quickly
    Christo Davids
    Land Cruiser 105 4500 EFI
    Hilux 2.8GD6 Extracab 4x4
    May 2008
    Mooinooi
    Thanked: 46
    I agree with Christo. Many trails that I have done indicated a rating of 3 to 5....3 for dry conditions and 5 when it's wet. I would imagine that even the uphill axle twister section got be tough when it is pouring rain....not to mention the rocky sections such as Gert se Klip. I once did a rocky section on another trail and with the wet rocks I had problems the first meter or two of the obstacle; normally this obstacle only becomes really tough 10 to 15 meters further.
    ______________________________________
    Jeep - it goes nowhere when it is upside down...
    Thanked: 1047
    We are looking at opening a piece that will probaby fall under the 5 most difficult sections in the country. Christo is right, its a 3 max.
    Training: 4x4, bush mechanics, recovery, defensive, 4x4 trucks
    Angel Construction
    COMBAT19: Large scale fogging and decontamination of coronaviruses
    [email protected]
    [email protected]
    +27824453301
    May 2010
    Bergbron, Roodepoort
    Thanked: 223
    I take it that this difficult section will be at De Wildt?
    When are you expecting it to be open to the public?
    Franz
    Rustenburg
    Thanked: 119
    Only whooses do the "special" section downwards......
    Thanked: 14112
    The cross-axle bit on the left-hand koppie is tough without lockers or traction control.
    Our Jeep WJ doesn't struggle, but the 110 with 235/85-16 Generals couldn't make it, and I wasn't going to risk 23 year old side-shafts.
    Gert se Klip is the same: a modern 4x4 or an oldie with a locker won't be too challenged.
    A nice course for a Sunday drive.
    Just leave the big mud-hole alone......
    Jan 2011
    Thanked: 2348
    Default DeWildt
    Quote Originally Posted by incrediblebob View Post
    I often hear guys smugly remarking how easy it was-not talking about De Wildt specifically, I tell them to do it again in a Series 1 Land Rover, if they can do that, they have my respect.
    If they manage to drive from home to De Wildt in a Series I Land rover they can have my respect too...
    Vtown
    Thanked: 101
    Any LR for that matter
    Mar 2011
    Boksburg
    Thanked: 64
    Default Re: DeWildt
    sorry for starting up an 8 year old thread. was this section ever added? is it the orange part on the latest map at de wildt?
    2015 Amarok BITDI D/Cab 4 Motion
    2011 Amarok TDI D/Cab 4x2 (SOLD)
    2001 Isuzu KB 320 V6 D/Cab 4x2 (SOLD)
    DISCLAIMER: I'm not an expert in the subject posted about above, i'm a member of an internet forum only and my comments, advise, suggestions and ideas should be taken from that point of view
    Mar 2011
    Boksburg
    Thanked: 64
    Default Re: DeWildt
    Quote Originally Posted by Dustbin View Post
    I went up that section, for my very first obstacle, in a standard auto. stupidity and inexperience got me to the top....
    May 2018
    Thanked: 87
    Default Re: DeWildt
    We did the section where you turn right by the entrance in my standard Triton with original sidesteps, they never looked the same after that and had to be replaced. One of my favourite places for a day outing though.
    Mar 2007
    Harties Boet
    Thanked: 841
    Default Re: DeWildt
    Quote Originally Posted by LeonP View Post
    Id also like to know. Im assuming it is though.
    Dewildt really is a great place for a day outing, alot more scenic than hennops I think.
    2004 Nissan Patrol 4.8
    1999 Nissan Patrol 4.2D
    Mar 2011
    Boksburg
    Thanked: 64
    Default Re: DeWildt
    is it perhaps the "brandpad" seen on some youtube videos? we ended up with 2 amaroks on a "track" with only plastic tape hanging from the trees to indicate the route. it was exciting, but we turned around after realizing this is probably best suited for modified-modified vehicles. The double modified is intentional irony.
  1. DeWildt 7th jan
    By sarge in forum The 4x4 Pub
    Last Post: 2012/01/23, 03:10 PM
  2. Dewildt 4x4 trail Map with Photos & videos
    By andrewbuch in forum 4x4 Trails / Routes / Clubs
    Last Post: 2011/12/02, 03:00 PM
  3. Free recovery training 2 May dewildt
    By Engel in forum 4x4 Training / Certifications
    Last Post: 2010/05/07, 07:05 AM
  4. DeWildt Sat 17 April
    By drepan in forum Gauteng
    Last Post: 2010/04/16, 11:26 AM
  5. back of the moon - DeWildt
    By kfxnando in forum General 4x4 Discussion
    Last Post: 2009/06/18, 04:46 PM
