logo
Go Back   4x4 Community Forum > All about vehicles > Vehicle & Technical Chat - General > Land Rover
4x4Community
Land Rover Go Beyond! The best 4x4xfar!
Reply
Thread Tools Display Modes
  #1
Old 21-09-11, 11:07 PM
mariusrautenbach's Avatar
mariusrautenbach mariusrautenbach is offline
Member
Default V8 viscous fan
Hi guys.
How do you know when the viscous fan is on its way out??
When I stop at home after say 1 minute the electric fan comes on. But temp stays the same, and have never had a problem with the temp since she was super hot last in late Desember..
Can it be the viscous fan? Or is it something else??
Thanks guys
  #2
Old 21-09-11, 11:28 PM
phuma phuma is offline
Member
How do you know the temperature stays the same - because the needle on the temp gauge is not moving? The standard temp gauge sits in the middle from about 60 degrees to probably 110 degrees... so it's not really a "good" measurement.
The fan will come on if the coolant temperature is 100 degrees Celcius (and in some other cases - check RAVE, and search in this forum - I have previously had a thread about this). Could be the viscous that is dying, could be the thermostat that is a bit stiff etc. I have a madman and are monitoring the coolant temperature from a probe in the upper radiator hose going to the radiator. My V8's coolant temp is about 90 degrees when driving. If it sits idling it will go to about 95 degrees. The thermostat is only fully open at 96 degrees...
RAVE makes for interesting reading ;-)
__________________
2013 Amarok d/c TDI 103kw 4motion
stuff I have in the classifieds | the story of my dad
  #3
Old 22-09-11, 09:08 AM
Member
How do you see when the thermostat is fully open??
How do I know if the thermostat is vrot?? Or just buy a new one? She has 193k km on her..
  #4
Old 22-09-11, 09:30 AM
Silver Shadow's Avatar
Silver Shadow Silver Shadow is offline
Member
Hi Marius
Ek sien jy het so bietjie issues met die old girl?
Hoop jy kom gou reg!
__________________
Discovery 3 V8 SE
Self designed Rock and Tree Sliders.
Next: Project Bashplate
1981 Series 3 S R6 88" Allmost Perfectly Restored
  #5
Old 22-09-11, 11:15 AM
Member
Nee sys fine, ek wil net nie langs die pad gaan staan nie...
'N landie is 'n duur ding, maar wil haar oppas op my beste wat ek kan.
Sys dalk oud, maar ry tog nog nuwe karretjies weg... Soos 'n golfie... Love om hulle te waste van robot tot robot
En wil haar reg kry vir my botswana toer, wil kyk of ek volgende jaar julie kan doen..
Of dalk matroos berg... Maar wil gaan as dit sneeu
  #6
Old 22-09-11, 12:16 PM
offroadrover's Avatar
offroadrover offroadrover is offline
Member
Try stop it while its running when warm.
I think mine locks up when hot as it drops in power and sounds like a jet turbine.
__________________
Godzilla - 1997 Range Rover 4.6 HSE
Monty - 1972 Series 3 LWB (moved on)
"Life's tough. It's even tougher if you're stupid."
-John Wayne
  #7
Old 22-09-11, 02:40 PM
Rain Hard's Avatar
Rain Hard Rain Hard is offline
Member
There are many differences resposes to this.
I have investigated and what I believe is....When the cold engine is started the fan should start to spin. It then "disconnects" after a minute or 2. When driving at 60km + it should not spin. When you stop and idle (and it's not spinning cos you've been driving fast), it should then engage again.
__________________
Range Rover Sport 4.2 S/C 2009
No Mods
Disco2 V8 2000
OME 776/781
Yoko 255/65 16
TNT Branch - SS Freeflow
CDL added
  #8
Old 22-09-11, 02:44 PM
Member
Some how, I want the fan to sound like a Cresida...
Don't know why, but I love it with a V8
  #9
Old 22-09-11, 03:06 PM
Member
Has anyone successfully fitted an electric replacement fan instead of the viscous on a V8 Landrover?
__________________
-John Wayne
  #10
Old 22-09-11, 06:05 PM
Member
Good question...
I hope there is
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Wrangler 4dr Viscous fan for JK Jean Kotze Jeep 44 28-06-12 07:21 PM
'96 Disco V8 Viscous Fan vs. Electric Fan CJBH Land Rover 22 17-03-11 10:03 PM
Nissan Terrano Viscous Fan & Waterpump leonlieb Nissan 0 04-05-10 01:40 PM
Viscous fan problem? 2.8 Tdi Fanie Mitsubishi 7 04-06-08 10:34 AM
Viscous fan query - 2.8 tdi dc Fanie Mitsubishi 2 13-05-08 08:11 PM
Template-Modifications by TMS
