logo
Go Back   4x4 Community Forum > All about vehicles > Vehicle & Technical Chat - General > Land Rover
4x4Community
Land Rover Go Beyond! The best 4x4xfar!
Reply
Thread Tools Display Modes
  #1
Old 01-09-11, 11:08 AM
FCSteenkamp's Avatar
FCSteenkamp FCSteenkamp is offline
Member
Default Defender td5 Service
Iím attempting my first solo major service soon and even bought a Haynes Workshop manual.
I have a few questions or rather concerns which I hope the experts could help me with.
This is on my to-do list:
  • Engine oil change (Maganatec 10W40 with a new sump plug copper washer)
  • Oil filter
  • Rotor oil filter
  • Diesel Filter
  • Grease diff and universal joint nipples
  • Gearbox oil change
  • Transfer case oil change
  • Diff oil change
  • Replace air filter
Other than checking the brakes, fuel lines, water pipes, aux belt and oil at ECU and loom Ö..What am I missing?
What oil should I use for the gearbox, transfer case and diffs irrespectively?
Is this the only way to get oil into the transfer case?
__________________
2012 Land Rover Defender 110 2.2 Puma
2004 Land Rover Defender 90 td5 (SOLD IT)
  #2
Old 01-09-11, 11:36 AM
NewLandy NewLandy is offline
Member
Default Nice oil pump!
Nice oil pump , where did you get it and how much?
  #3
Old 01-09-11, 11:40 AM
Member
Quote:
Hi NewLandy,
This is not my patent.....got it from here (I dont own this oil pump....just saw it on the web). Im wanting to know if this is the only why to change the transfer case oil as I have not done it before.
__________________
  #4
Old 01-09-11, 04:56 PM
Imvubu's Avatar
Imvubu Imvubu is offline
Member
Transfer case you may manage with the 500ml bottles that have the pull-out spouts. It's the gearbox that's a bugger to get at IIRC.
__________________
Erin Bosch (082 342 1909)
4xfagger no. GP0048
2001 Land Rover Defender 130 TD5 D/C with everything
1970 something Land Rover Forward Control IIB camper (SOLD)
  #5
Old 01-09-11, 09:48 PM
seekingserenity's Avatar
seekingserenity seekingserenity is offline
Member
I've been looking for a pump like that for a very long time, after repeatedly skinning my knuckles topping up the gearbox. This online shop has them (at a price) but I'm sure we are all creative enough to make our own All it takes is a trip to Plastics from Africa, something like this and a length of fish tank hose. Heck, I'll even settle for one of these (or a horse syringe) and a length of pipe...
__________________
Michelle - Olivia the 1976 S3 Landy's human
  #6
Old 01-09-11, 10:04 PM
Landyluvver's Avatar
Landyluvver Landyluvver is offline
Member
http://www.amazon.com/gp/product/ima...86168&s=garden
i use ones similar to these extensively.
about R140 each and carries up to 5 litres.
remove the nozzle and use the pipe only.
they are normally indexed so adding the correct amount is fairly easy.
fill to the mark and then insert the pipe into the gearbox etc.
pump up and leave till empty.
found it a great time saving device.
place one each at diffs, gearbox and transfer case and fill all simultaneously.
__________________
0833006099
  #7
Old 02-09-11, 08:15 AM
Member
Thanks for the advice guys.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Defender Buying a 2002 TD5 Defender, advice needed. constantlm Land Rover 9 05-10-11 12:12 PM
Defender td5 rebuild 2011 JohanJvV Land Rover 116 15-03-11 04:46 PM
Defender defender 90 2001 td5 ecu problem. albie odendaal Land Rover 11 09-12-10 10:24 AM
110 TD5 Service LAB Land Rover 2 01-09-10 07:44 AM
Td5 service and diesel pump Kadila77 Land Rover 4 31-08-10 01:27 PM
Template-Modifications by TMS
