logo
Go Back   4x4 Community Forum > All about vehicles > Vehicle & Technical Chat - General > Toyota
4x4Community
Toyota Lead the way!
Reply
Thread Tools Display Modes
  #1
Old 28-08-11, 06:29 PM
WayneMan WayneMan is offline
Member
Default KZ-TE Suspension Upgrade
Hi Guys
Im pretty new to all this and Im trying to understand how the suspension on my vehicle works and what are the best options available in terms of upgrades.
I've always maintained that the standard wheels on my KZ-TE look a bit small.
I would like to beef up and improve the suspension and ground clearance, but Im not entirely sure where to start. What are my options ?
Bigger tyres, new springs / shocks, body life kits etc etc
Please could you help and give pro's / con's for the various options.
Much appreciated.
  #2
Old 28-08-11, 06:39 PM
Liaan's Avatar
Liaan Liaan is offline
Member (ex ToyotaMan)
Hi Wayne
Welcome!
The normal tyre size for the KZ is 245/75 R15(or 30 9.5 R15)
You can fit 265/70or75(not exactly sure) R15 (or 31 10.5 R15 without modifications if I'm correct.
This will definetly increase your vehicles height. +- 20mm
This is the first mod I'll do on a 4x4.
If you still need more clearance you can the fit OME, IRonman, TJM, Mikem ETc Etc suspension. This will give you an additional 50mm clearance.
20mm and 50 mm doesn't sound like much but will make a huge difference.
Your vehicle would also be a little heavier on fuel.
Good luck!
__________________
Almal kry die voorreg om onnosel te wees, net jammer party maak misbruik daarvan
  #3
Old 28-08-11, 08:54 PM
djtzar's Avatar
djtzar djtzar is offline
Member
I'm no expert but I have the SRX , basically the same bakkie
I have the 31 BFG's AT on , upped the torsion bar a bit (make sure to get this done at a wheel fitment centre don't want to lose an arm) got excellent service from the guys at Tiger Wheel Centurion. When turning sharp the inside did catch on the stabilizer bar as well as the mudflaps , but the guys fixed it. I also removed the stabilizer bar at the front , gives some articulation but then affects the body roll so if you don't like body roll don't do it.
Wait on the suspension upgrade , rather spend a few bucks and get your blade springs re-tensioned I'll be doing this sometime soon (my bakkie se gat hang :P)
If you want ride comfort take a look at Camil suspension , very good and after sales service is great (just search the forum)
Just my 2c
__________________
Hilux SRX D/C 4x4 31 BFG's - Die G.W.B
Suzuki GV 2.4 M/T - Goldie
"Experience is what you get when you didn't get what you wanted"
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Current model Fortuner suspension upgrade davidlight Toyota 9 29-02-12 04:28 PM
JK Suspension Upgrade - help / Suggestions JK2008ZA Jeep 19 12-05-11 08:21 PM
Fortuner Suspension Upgrade - Advice Required Defenderman Toyota 8 11-05-11 04:30 PM
Suspension upgrade feedback after an unusual test iangage General (non vehicle/technical) 4x4 Discussions 2 31-10-10 01:44 PM
Template-Modifications by TMS
