logo
Go Back   4x4 Community Forum > All about vehicles > Vehicle & Technical Chat - General > Jeep
4x4Community
Reply
Thread Tools Display Modes
  #1
Old 26-05-11, 08:11 PM
GTAgazza GTAgazza is offline
Member
Default Vacuum reservoir solenoid...
Hey all
Im getting two fault codes on my '05 Jeep Cherokee 2.8 CRD...P1250(Vacuum Reservoir solenoid open circuit) and P1252(Vacuum Reservoir Solenoid short circuit).
Is this solenoid behind the airbox and has a small filter attached to the bottom?
Power from the Jeep is very sluggish at low revs but after about 2700rpm the turbo kicks in and it drives as normal, as soon as the revs drop below 2700rpm its sluggish again.
Any help will be much appreciated
Gary
  #2
Old 27-05-11, 12:11 PM
Quiksilver's Avatar
Quiksilver Quiksilver is offline
Member
Hi
Common problem. Happened to me too - Controls the turbo vanes. Thats why no power from down low.
You can get a replacement at Stealers, or import one from here.
http://www.trademotion.com/partlocat...layCatalogid=0
Temp fix is: this is an on/off solenoid that is supposed to power on with the key in the run position and off with key off. The unit was designed to keep vacuum stored in the vacuum reservoir overnight to have enough vacuum to power the turbo after a morning cold start. If it has failed closed, as it did on one of our test vehicles (no vacuum allowed to turbo and no boost), you can just unplug the vacuum supply line from the engine that goes to the reservoir/on-off solendoid and plug it directly into the EVM that controls the turbo. The turbo EVM has a little dust element on the bottom side, in order to be able to tell the difference between the two solenoids. The turbo EVM has two ports, one labeled "VAC" and the other "OUT". Engine vacuum line should go into VAC and the OUT is the line to the turbo.
This is a fix to keep the engine making boost and you can get a new IVS at your liesure.
Dont let the stealers talk you into "fitting it" for a fee, its like a 3sec job
__________________
2007 Jeep Grand Cherokee 3.0 CRD Overland - GDE Eco Tune.
2006 Canary Yellow Jeep Wrangler TJ (Old Mans')
Ex - 2005 Cherokee CRD
  #3
Old 27-05-11, 12:32 PM
warden's Avatar
warden warden is offline
Member
Just a quick question does it smoke a lot while it has no power if so check the throttle body by taking the boost-pipe off on that side and check the butterfly valve and make sure it is open and not closed, mine did that, after I cleaned and flipped the valve open my car ran normal. Hope it helps
__________________
As jy dom is moet jy suffer
Es ist ein Jeep, was Sie nicht verstehen würde!
  #4
Old 27-05-11, 12:35 PM
Mielie 84's Avatar
Mielie 84 Mielie 84 is offline
Member
Hi Quiksilver,
Just for interest's sake, what is the price for the solenoid at the stealers?
Emile
__________________
'07 Volkswagen Touareg V6 TDi
  #5
Old 27-05-11, 01:36 PM
Quiksilver's Avatar
Member
if I remember correctly about R700 ex vat if they have in stock.
obviously importing just that one piece wont justify the freight. I ordered 3 fuel filters and the replacement piece for my busted blower setting for about R1500
As Warden says - that blasted throttle body is also a nuisance. mine is stuck open luckily. That being said mine smoked LOTS when the solenoid was dead, especially under heavy throttle.
If you do the temp fix you will be able to test that it is indeed the solenoid as it effectively bypasses it. It will still throw CEL.
To answer your original question - yes the thing with the little filter attached behind the airbox
The blue thing top left? thats it, pipes going into the top of it are what you need to change around like in my first post.
If you need help PM and we can chat.
__________________
  #6
Old 27-05-11, 02:14 PM
Mielie 84's Avatar
Member
Cool, thanks for that, will check mine and see whether it works, also experiencing a lot mor lag than I'm used to...
__________________
  #7
Old 27-05-11, 02:27 PM
Member
Thanks quiksilver
That's done it, Jeep back to full power
If that solenoid is a simple on/off valve though, would leaving it permanently bypassed cause any problems in the long run? Apart from the CEL?
  #8
Old 27-05-11, 02:34 PM
Quiksilver's Avatar
Member
Quote:
Originally Posted by GTAgazza View Post
Thanks quiksilver
Good stuff
Apparently not - might just take 2 minutes or so after start up to get full vacuum, so possibly under powered temporarily. I didn't really notice that though.
__________________
  #9
Old 14-01-12, 07:33 PM
jspriver jspriver is offline
Member
to Quiksliver. THANK YOU !!!!!!!!!!!!!!!!!!!!!!!!!!! this saved me !!!!!!
  #10
Old 22-11-13, 10:44 AM
MaX83 MaX83 is offline
Member
Bump for a good fix. Had this on my CRD2.8 now and took SAC a week to diagnose. They know now so should be easy fix. Part including vat was about R800.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
WJ 2.7 CRD Maintenance wtrlan Jeep 213 30-03-16 06:54 PM
Part catalogs & other useful info charlatan Jeep 88 02-12-15 12:11 PM
4x4 vacuum system Fanie Mitsubishi 4 29-03-11 01:03 PM
Grand Cherokee Error code Nick47 Jeep 4 30-08-10 01:28 PM
Vacuum Solenoid Valve theo Mitsubishi 1 26-03-07 10:17 AM
Template-Modifications by TMS
