logo
Go Back   4x4 Community Forum > All about vehicles > Vehicle & Technical Chat - General > Mitsubishi
4x4Community
Mitsubishi Spirited cars for spirited people!
Reply
Thread Tools Display Modes
  #1
Old 09-05-11, 08:02 AM
Bush Man Bush Man is offline
Member
Default 2.8TD Pajero - white smoke on start-up
Hi guys,
During the cold months our 2.8TD Pajero has a bit of a tough time getting going in the mornings (like most of us, I guess...)
The engine will kick into life at the turn of the ignition. No problems there.
However, lots of white smoke (actually a cloud). This persists for about 30 seconds, and mostly disappears after about 4-5 mins (i.e. once the engine has warmed up). During the warm-up period, engine sounds a bit rough, but soon settles down. We are very easy on the accelerator until she has warmed up.
I don't really have a problem in the summer months (or at least it is not as bad).
The vehicle is services regularly (everk 5k) and we change oil filters, etc. Oil used is Delo 400 multigrade.
Any suggestions welcome.
Thanks !
  #2
Old 09-05-11, 08:15 PM
Haydn Haydn is offline
Member
White diesel smoke is caused by un burnt fuel.
Possible causes; firstly and most often the glow plugs are faulty or not functioning at all.
also look at the injectors dribbling and over fuelling along with the pump timing.
__________________
2002 Colt, 2.8 tdi Rodeo, 4x4, ARB Bull Bar, Excalliber Running Boards, Monroe Gas Magnum Shocks, Cooper AT3's, Excel 53l long range tank, National Luna Dual Battery System, Campmaster 80l Fridge/Freezer Combo, FrontRunner Fridge slide and Bin Slide, Alpha Gte Canopy with FrontRunner Roof Rack and Homemade Awning...[SIGPIC] Pulling a Caravan sometimes
  #3
Old 10-05-11, 02:39 AM
Numbnut's Avatar
Numbnut Numbnut is offline
Member
I agree with Haydn, glow plugs are 90% the cause. I am also replacing mine in about 2 weeks. Come winter time they show their true working condition.
Just be ready for the big shocker, I bought mine last month from Midas and they cost R449 EACH, almost R2000 for the four glow plugs.
What I usualy do when my glow plugs is shot and just before I change them is to add some Spanjaart Injector Cleaner to a full tank and only when tank is driven completely empty I change the glow plugs. Reason being that I have found that Injector Cleaner is not good for glow plugs.
Some members have different views on additives, but this works for me and it helps to improve fuel consumption.
BTW, the glow plugs you want to get are NGK CY-55, ceramic coated tip. They will last you a very long time. Don't go cheap, not worth it.
__________________
2012 Ford Ranger 3.2tdci DC 4x4 Auto aka "Fytjie"
Opposite Lock Bumper; 330w & 480w Phillips 4D LED Lightbars; Phillips HID Headlights; Ford Snorkel; 63mm SS Free Flow; De-Cat; EGR Blanking Plate; Cobra Suspension, Load Hogs, 50mm Mikem Extended Shackles, 8mm Teflon Spacers; Custom Leisure Tech alu Canopy; Rear View Camera; Escape Gear Seat Covers
Everything Works Better When It Is Properly Maintained!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Bellows of white smoke while idling whitters Vehicle & Technical Chat - General 11 12-12-10 10:59 AM
white smoke couper-zn Jeep 14 05-07-10 06:02 PM
Smoke on idle- Pajero diesel Transkeicowboy Mitsubishi 6 13-06-10 05:07 PM
white smoke coltrodeorb Mitsubishi 6 04-11-09 07:36 AM
My Pajero went up in smoke yesterday. turbonutters Mitsubishi 27 16-03-09 03:46 PM
Template-Modifications by TMS
