logo
Go Back   4x4 Community Forum > All about vehicles > Vehicle & Technical Chat - General > Mitsubishi
4x4Community
Mitsubishi Spirited cars for spirited people!
Reply
Thread Tools Display Modes
  #1
Old 17-01-11, 07:33 PM
SinWolf's Avatar
SinWolf SinWolf is offline
Member
Default How to fix the Triton steering column
Ok, so another forum member (thank you 4x4Freak) managed to get hold of his old steering column, which was replaced under maintenance plan. I had the column picked up in Cape Town, and brought through to Pretoria for me to inspect.
The Column I received.
At first, I could not find anything wrong with the column... All bearings and bushes on the shaft seem to be in perfect condition... And then, I tried something else...
The 4 circles marked in red, is the mounting points for the column inside the vehicle.
I grabbed hold of the one funny looking mounting with a vice-grip, and found this mounting to be loose...
I then discovered, that both these funny mountings are not solid...
Ok, so to fix the steering column, you just need to secure these mountings, but here’s the catch! Fixing this could be life threatening in the event of a head-on vehicle accident... Yes, by fixing this could perhaps kill you... WHY ?
Let me explain....
Let’s start by having a closer look at these funny mountings.
This mounting (as seen in photo)....
.....Slides onto the steering column’s bracket
Then, the mounting gets glued to the steering column...
See red circles in 2 pictures below...
Now these 4 glued spots are supposed to break during an accident... Why ??
In an accident (head-on)... The mountings (red arrows) will stay bolted to the vehicle... Then, the steering column (green arrows) will collapse in the direction of the yellow arrow. This will only happen if the 2 glued brackets are able to break loose. This makes for a “collapsible” steering in the event of an accident.
What happens now is that the glue breaks of during normal use, which causes the steering column to rattle on its own mountings.
I removed my Triton’s cover, grabbed hold of my steering wheel, and started pushing and pulling on it... I could clearly see that my Triton’s exact mountings are also loose....
So, to fix the “loose” steering column, you should just permanently attach these 2 little mountings to the steering column bracket.
Now I have not done this to my vehicle yet, so I have no solution on HOW to attach the two... But I’m either considering using a lot of Pratley Steel glue, or maybe to use 2 X 2mm bolts on each bracket (through the holes used for the glue). These 2mm bolts should (but I CANNOT guarantee this) break in an event of a head-on accident, which COULD perhaps still give you a collapsible steering column. There are a lot of ways to fix this, but as mentioned... Permanently fixing these little brackets to the steering column COULD cause your steering column NOT to collapse in a head on collision.
__________________
Mitsubishi Triton 2.5 HP 4x4 D/C
BFG KM2 Muds
40mm Body Lift
Lynx Bashplate
Metalian Alu Canopy
DIY Drawer system
DIY Drop Fridge Slide
DIY Rocksliders
My Triton Build Thread
  #2
Old 17-01-11, 09:00 PM
Cobus80's Avatar
Cobus80 Cobus80 is offline
Member
Eish! Very interesting.
So apart from rattling there should actually be no influence on the handling of the bakkie once these mountings have worked themselves loose?
Maybe a glue that does not bond quite as hard as pratley? I'd hate to have that column impale me in the even of an accident!
Maybe one can find some sort of plastic clip to mount through the glue holes that will still sheer off...
Seems like a iffy design on a vehicle that should be able take a fair amount of punishment...
__________________
2011 VW Amarok BiTDI DC 4Motion
(Ex) 2007 Mitsubishi Triton 2.5 DID DC 4x4
(Ex) 2001 Mitsubishi Colt 2.8 TDI DC 4x4
ORRA Call Sign: B327
  #3
Old 17-01-11, 09:45 PM
Die SwartKat's Avatar
Die SwartKat Die SwartKat is offline
Member
Baie baie goeie werk Regardt! Dit is uitstekende nuus! Ek is baie beindruk!
__________________
Nico Swart
Current : Triton 2.5 D/C aka Telkom
ZS6NJS
Orra Call Sign : H07
Experience is something you don't get until just after you need it.
  #4
Old 18-01-11, 06:59 AM
SinWolf's Avatar
Member
Just to let you know... I will be fixing mine sometime in the future... And if it does happen that I'm involved in a head-on, then what will happen will happen... I could just as easily end up in a head-on with SWAMBO's citi golf...
Thanks Nico
__________________
BFG KM2 Muds
40mm Body Lift
Lynx Bashplate
Metalian Alu Canopy
DIY Drawer system
DIY Rocksliders
  #5
Old 18-01-11, 07:06 AM
Henris's Avatar
Henris Henris is offline
Commercial Member
My suggestion would be a very small tac with the welder. Not, very small. Welding on steel carries 1tonne per 10mm. So it must be about 0,5mm. Your Pratley steel trick should also work. I suggest a copious amount, as Pratley Steel is very brittle.
Come to think of it, Sikaflex should work quite well. Not brittle and not as soft as Silicone. But will sheer under load.
__________________
Let me be your link to anything property related. Buying, selling renting or letting.
I would love to make sure you are taken care of, the way you are supposed to be cared for.
Anywhere in the country.
  #6
Old 18-01-11, 07:16 AM
SinWolf's Avatar
Member
Henris,
I'm not sure how you would weld it (what type of welding), cause the bracket is not made of steel... It's some sort of aluminium alloy... The steering column bracket is steel though... So for a PERMANENT fix, you could remove those funny inserts, and weld a piece of flatbar in it's place... But then there is no way the the steering will colapse...
__________________
BFG KM2 Muds
40mm Body Lift
Lynx Bashplate
Metalian Alu Canopy
DIY Drawer system
DIY Rocksliders
  #7
Old 18-01-11, 08:15 AM
4x4 freak's Avatar
4x4 freak 4x4 freak is offline
Member
Sinwolf ek se weer jou beaut. jy is slim.. Dis reg wat van in plaas van gom n klein bietjie epoxy ? Dis flippen sterk. Dalk kan jy dit toets op daai ou coloum van my ? Dit is goeie werk meneer
__________________
Fortuner V6 4L
DRAGON 29 Mhz
Maxxis Bighorn
Starting with the mods
  #8
Old 18-01-11, 08:24 AM
SinWolf's Avatar
Member
Quote:
Thanks... En nee, nie slim nie... Net oplettend
Ek kan daai ou een van jou plak, maar die toets werk sal moet in 'n voertuig gedoen word, sodat die column aan all die daaglikse stress blootgestel kan word...
Now I understand why Mitsu dealers say the problem is not life threatening.... It's actually life saving
__________________
BFG KM2 Muds
40mm Body Lift
Lynx Bashplate
Metalian Alu Canopy
DIY Drawer system
DIY Rocksliders
  #9
Old 18-01-11, 08:32 AM
4x4 freak's Avatar
Member
Thanks bulla
__________________
Fortuner V6 4L
DRAGON 29 Mhz
Maxxis Bighorn
  #10
Old 18-01-11, 10:57 AM
Triton Lion
Guest
Posts: n/a
Nice om te weet ons het sulke kundige mense op die site!!
  #11
Old 18-01-11, 11:10 AM
NerdBakkie's Avatar
NerdBakkie NerdBakkie is offline
Member
Amazing work Regardt, well done and thank you!
Even should I decide not to fix it (unlikely) at least we all know exactly what is going on now and can rest a little easier.
I am curious to see everyone's solution to this now that we know what to do (sikaflex, pratley, flat bar etc) but i have a question for some of you:
Those of us with big heavy BullBars obviously have a concern already i.c.w crumple zones when making contact with another solid object (ie head on collision)... so is the crumpling of the steering column as much of a concern in these instances?
__________________
__________________
Aaron
Mitsubishi 3.2 Triton with stuff
Member - 4x4AG - GP0108
  #12
Old 18-01-11, 05:38 PM
David Maritz's Avatar
David Maritz David Maritz is offline
Member
Citi Golf vs Triton in headon collision?
Collapsable steering vs fixed steering?
Even my Colt vs Triton?
I would think about it and make it a solid fix vs use sikaflex.....
__________________
David Maritz
Triton - Barberian!
  #13
Old 19-01-11, 09:18 AM
NerdBakkie's Avatar
Member
Another two questions;
1. How would your insurers react? Obviously they would have to FIND what was done, which would be pretty unlikely... but if they do go over the car with a fine tooth comb after a crash and find that something was "fixed" they might reject a claim? To get even more negative... this would really suck if you were impaled by the column too and it was SWAMBO claiming
2. If you have a 3rd party warranty provider... same thing... you have a steering issue, you claim, they send an assessor, find some homemade handiwork and VOILA they reject and you pay for everything yourself.
Eish. decisions decisions.
__________________
__________________
Aaron
  #14
Old 19-01-11, 10:15 AM
Smiles's Avatar
Smiles Smiles is offline
Member
At least you would not have to repair the steering column...
So bietjie wiskunde... help my as ek verkeerd is...
Shear strength = 0.6 x Tensile strength (for mild steel)
Tensile strength = 800MPA -grade 8.8
Thus Shear strength = 480 MPA
Shear strength = Force (Newton) / Area
Thus Force = Shear strength x Area.
If you use a 2mm bolt the area will be Pi X Diameter^2 / 4 = 3.141 mm2
Thus the Force required to shear the bolt will be 1508 Newton = 153 kg per bolt...
However for a 1mm bolt it will be 38kg per bolt.
Further, if you get a grade 4.8 bolt it would be 19kg per 1mm bolt... and 77kg per 2mm bolt.
I would say drill a new hole, thread it and put on a 1mm bolt on a side. This will be strong enough to keep the stuff from moving and still break in an accident...
If my brain did not freeze over...
__________________
Hennie
1990 Land Rover Defender V8 3.5l (want ek hou van die klank)
Land Rover Discovery 4 SDV6
Mercedes Benz GL 320 cdi ( dankie tog ek is ontslae van hom)
ORRA Call Sign B165
  #15
Old 19-01-11, 10:23 AM
SinWolf's Avatar
Member
And in an accident... What will be the force of your body on that steering ?? I would say AT LEAST 150kg ??
__________________
BFG KM2 Muds
40mm Body Lift
Lynx Bashplate
Metalian Alu Canopy
DIY Drawer system
DIY Rocksliders
  #16
Old 19-01-11, 10:24 AM
SinWolf's Avatar
Member
P.S. Dankie vir die berekeninge smiles
__________________
BFG KM2 Muds
40mm Body Lift
Lynx Bashplate
Metalian Alu Canopy
DIY Drawer system
DIY Rocksliders
  #17
Old 19-01-11, 10:57 AM
Member
Stem saam oor die 1mm boutjie en dis rerig nie baie nie. Die fors wat gebruik word om te breek vs die gom is uiteindelik die verskil.
Die groot ding oor die stuur wat breek is om jou borskas en nek te red. Maar ek vra net weer hoeveel voertuie op die mark het rerig stuur meganismes wat breek? Jy is dalk net gelukkig oor jy 'n Triton ry.
Maar die keuse is daar 1mm bout of weer net gom? Dalk sterker as wat Mitsubishi gebruik?
__________________
David Maritz
Triton - Barberian!
  #18
Old 20-01-11, 10:29 AM
NerdBakkie's Avatar
Member
SinWolf, do you want to link this thread to the newtriton.net forum? I saw on the other thread you have registered there.
Lets get the Aussies to throw some brainpower at it... hopefully they are better mechanics than they are rugby players and can give us some feedback as to whether this has been resolved over there.
From what i have already searched on their forum, a lot of them have obviously experienced the knocking and have complained about it, but no one has offered a solution as yet.
... At the very least you will look like a hero in another country
__________________
__________________
Aaron
  #19
Old 20-01-11, 10:33 AM
SinWolf's Avatar
Member
I sleep at night.... NOT during the day....
http://www.newtriton.net/phpbb/viewt...hp?f=23&t=7284
__________________
BFG KM2 Muds
40mm Body Lift
Lynx Bashplate
Metalian Alu Canopy
DIY Drawer system
DIY Rocksliders
  #20
Old 20-01-11, 10:57 AM
NerdBakkie's Avatar
Member
haha, k, guess i should have searched better
I like their idea of a simple silicon adhesive to dampen the knocking... i would assume that the "Silastic" they are talking about is their equivalent to a normal black car silicone?
It obviously wouldn't act as a serious adhesive, but could perhaps stop the annoying play and knocking...?
My concern with a sikflex/pratley solution is that if it does eventually break... as it no doubt will after constant use and force after 10,000km's... then not only are you right back at square one, but you also have a mess of solid grey gunk that you have to file off.
__________________
__________________
Aaron
  #21
Old 20-01-11, 12:00 PM
Andre N Andre N is offline
Member
Sinwolf, gaan maak 'n draai by hobby shops, spesifiek die wat in vliegtuie spesialiseer.
Jy kry nylon boute wat gebruik word om die model vliegtuie se vlerke aan die rompe vas te maak. Word gebruik vir exactly waarvoor jy dit wil gebruik, in geval van 'n prang sheer die boute af.
  #22
Old 20-01-11, 12:07 PM
SinWolf's Avatar
Member
Thanks...
Ek ken daai boute ja.... Maar hulle is nogals dik... 5mm
Ek wil nie graag die gate op daai klein brackets so groot boor nie...
Ek sal wel kyk of ek dalk dunner nylon boute kan gry... se 3mm maks !
__________________
BFG KM2 Muds
40mm Body Lift
Lynx Bashplate
Metalian Alu Canopy
DIY Drawer system
DIY Rocksliders
  #23
Old 21-01-11, 10:47 PM
Balistic's Avatar
Balistic Balistic is offline
Member
Manne , net n gedagte. As jy nie regkom met die nylon boutjie nie
Brass boutjie en moertjie wat effens gemerk (met yster saag) is op die sheering point . Die shearing strenght van brass behoort nog laer te wees as mild steel.
  #24
Old 17-02-11, 12:45 PM
peter pan's Avatar
peter pan peter pan is offline
Member
Default Dankie!
Sinwolf, Dankie, dankie! Dit was nog die een ding wat elke nou en dan in die aande by my kom spook het. Nou is ek rustiger en sal die nodige goedjies in my toolbox gooi...Daar behoort 'n prys te wees vir hierdie soort 'speurwerk'! Wel gedaan!GroetePieter
__________________
___________
Pieter
Mitsubishi Triton 2.5 Di-D (Super Select)
  #25
Old 17-02-11, 02:24 PM
4x4 freak's Avatar
Member
Yes hy het mooi gemaak met dit!
__________________
Fortuner V6 4L
DRAGON 29 Mhz
Maxxis Bighorn
  #26
Old 18-02-11, 08:26 AM
Gentoo Gentoo is offline
Member
How about 2 or 3 small (aluminium) pop rivits; should shear quite easiliy?
  #27
Old 19-02-11, 09:33 AM
Boggom's Avatar
Boggom Boggom is offline
Member
How about sika - it's almost like silicon?
__________________
MUD - The all natural and essential beauty cream for your Jeep........
Johan
2002 WJ OVERLAND 4.7 HO
  #28
Old 09-02-12, 09:52 PM
BFANothling BFANothling is offline
Member
Default Triton stearing
Ek het nou my colum uitgesort het die gaaitjies oopgeboor gevul met steenvas en die bracket terug gesit stearing is nou baie solid en stil.
Wil net graag iets weet , as my triton afgeskakel is en jy draai die stuurwiel vinnig links en regs dan is daar so n kap geluid wat klink of dit van die rack en pinion af kom maar as jy die voertuig start en die selfde doen is dit stil, wil weet is dit normaal of is daar fout iewers op die rack en pinion
  #29
Old 03-10-12, 02:59 PM
Lusenga's Avatar
Lusenga Lusenga is offline
Member
[QUOTE=SinWolf;664370]How to fix the Triton steering column
I realize that this is now quite old. However I refuse to believe that my 100,000 Km Triton that does nothing but softroading at best would require two column replacements in that sort of mileage. So when the problem resurfaced I took another look at this.
What SinWolf described here is true, but there is also another contributor to this. The rubber shown on the picture (at the end of the metal bellows) is held in place by a very flimsy clamp. I presume this is meant to fail as part of the steering collapsing mechanism. This clamp has two parts that 'must' hook onto each other to hold the rubber bush in place. When this clamp fails and opens up enough, the steering column gives you the sensation that it has a play.
A simple action of forcing the steering to turn with no engine assistance (engine off), combined with tires significantly wider than spec will open this bush clamp. I have neither found the time nor worked out a way to clamp it back firmly. So I have the two ends of the clamp strapped together by a T15R cable strap and my steering has been quite firm with no funny feeling for the past two weeks.
ID:	168900   Click image for larger version
__________________
Jeff.
2009 Triton 2.5 Di-D Super select
- 1UZ-FE 4sp Auto!
  #30
Old 03-10-12, 03:41 PM
Nys's Avatar
Nys Nys is offline
Member
Hi Lusenga
I presume the clamp you are talking about is the one with the green markings on them??
__________________
VW Amarok 4Motion Auto
  #31
Old 03-10-12, 03:50 PM
Lusenga's Avatar
Member
Quote:
Originally Posted by Nys View Post
Hi Lusenga
Correct. That thing is next to the angled joint and therefore must be reasonably anchored. If there is movement there you will feel it when turning the steering, especially coming in / out of parking lots as you need full locks.
__________________
Jeff.
- 1UZ-FE 4sp Auto!
  #32
Old 05-10-12, 10:38 AM
Andrew5336's Avatar
Andrew5336 Andrew5336 is offline
Member
Blast, thought maybe that was the source of my neverending woes but mine is solid.
__________________
Andrew
2007 Subaru Forester 2.5 XT Auto
  #33
Old 01-12-14, 06:12 AM
Afdak Afdak is offline
Member
Seems that nobody has had steering rattles since 2012? Or maybe the glue fix has become common place? My 2009 Triton with 105k (bought it last week) has the dreaded rattle. But it only appears on rocky trails.
Are there any new developments on the subject perhaps. I inspected the upper mountings and they seem tight still. Thanks. Gerard
  #34
Old 01-12-14, 09:15 AM
Alton's Avatar
Alton Alton is offline
Member
My 2009 has been free of the steering rattle since I got it on 106k km and it's now on 151k km BUT last Thursday the dreaded air bag light came on so I'm pretty sure todays service will reveal the need for a Clock Spring replacement
Thanks Sinwolf, I know it's an old thread but Awesome research, any rattle on my steering column will be dealt with using Sikaflex and Cable ties
Edit: maybe Mitsubishi made the steering mount so weak that it failed even before the steering column needed to collapse because they knew the clock spring(which reguarly fails as well) would have packed up by then so there was less risk of being impaled by the steering column when the airbag failed to deploy.................
__________________
Triton DC 2,5 SS 4x4
Lynx Bashplate
Powerbrake AT
Kumho KL71 265/75/16
DIY Dual Battery System
DIY Rocksliders
DIY 40mm Lift Kit
Next Project, Transfer case skid plate
  #35
Old 16-02-15, 06:37 PM
Tapie's Avatar
Tapie Tapie is offline
Member
Sal dit nie werk as jy die 2 oortjies bietjie buig nie, die een op en die ander een bietjie af ??
__________________
Francois Hamman
1992 Mitsubishi Pajero SWB 2.0 16v Turbo - Project Mitsuyota
1999 Mitsubishi Colt 3.0iV6 4x4 D/C BFGoodrich M/T 31x10.5R15
- (EX)
2007 Mitsubishi Triton 2.5DiD 4x4 D/C 265/70/16 Cooper AT3
LAS Pro 20mm Strut Spacers
2" Rear Shackles
Lynx Bash Plate
Maxxis Bighorn 32x11.5x15 on 15" ET+18 Racing Hart rims for playing(Fits like a glove)
Custom HD Rock Sliders
MAN KRIEKKE JA ....
SWAMBO - 2002 Mitsubishi Pajero iO 2.0i, BFGoodrich A/T 235/70/16 + 1" Spacers (Maar sy mag nie weet nie)
  #36
Old 16-02-15, 06:39 PM
Tapie's Avatar
Member
Of dalk die blokkies bietjie toe buig al 2 kante? Of dink jy hy sal breek/kraak?
__________________
Francois Hamman
- (EX)
2" Rear Shackles
Lynx Bash Plate
MAN KRIEKKE JA ....
  #37
Old 16-02-15, 06:42 PM
SinWolf's Avatar
Member
Mitsu has a "repair" kit available... Its a glue that you buy to glue it again...
I'm sure you'll find the part number if you google...
__________________
BFG KM2 Muds
40mm Body Lift
Lynx Bashplate
Metalian Alu Canopy
DIY Drawer system
DIY Rocksliders
  #38
Old 17-02-15, 05:29 PM
Member
Default Triton steering rattle - repair kit details
I finally managed to buy the "repair kit" from Kuilsrivier Mitsu in the Cape.
Their spares sectionn had never heard of the problem or the kit but they contacted the Workshop Foreman who had heard of the problem but never seen it. They did some research and ordered the kit for me. It consists of a 50gm bottle of glue. Labeled as a genuine part. Adhesive TB 17V and then 4401A191.
I suspect I will use very little so you know where to get some instead of spending R450.00
Note that the Paarden Island dealer had never heard of the problem and was not interested in following up.
Somerset West were happy to offer a new column.
East London (I happened to have some free time there in January) knew all about the problem but had run out of glue. They said they "drop" the column, pour glue in the right spot and wait 24 hours.
I had a look under the dash but could not get to the mounting bolts due to an electrical connector blocking the way. Could not see how to disconnect it. Will try again this week.
Any dissassembly tips will be appreciated.
  #39
Old 06-04-15, 10:30 AM
Tapie's Avatar
Member
I've checked that glued blokkies on mine and they are fine, but i feel a rattle from lower down the steering column where it goes through the firewall...see pic attached and highlighted. Is there a bearing or something sitting there?
__________________
Francois Hamman
- (EX)
2" Rear Shackles
Lynx Bash Plate
MAN KRIEKKE JA ....
  #40
Old 01-07-15, 03:15 PM
douwtjie's Avatar
douwtjie douwtjie is offline
Member
I've got a 2010 3.2D 4x4 and found also a funny noise on the steering rack, especially wen engine not running and I am turning it side to side. Almost sound like its worn. Could this maybe be the same brackets that are coming loose? Mitsubishi East Rand told me I must buy a complete steering rack. Any suggestions?
  #41
Old 01-07-15, 03:21 PM
Mr.G's Avatar
Mr.G Mr.G is offline
Member
No,the steering column is a issue over very bumpy roads..What noise does yours make?More like a squeel like ribber on metal?If so then its just the rubber casing around the column..Look in the egibe bay at the firewall where the steering comes out.Use some silicon spray and "lube" that rubber casing
__________________
2007 gen 4 pajero 3.2
Wilderness 310 trailer
Nissan np200 8v
  #42
Old 01-07-15, 10:06 PM
Tapie's Avatar
Member
Quote:
+1
__________________
Francois Hamman
- (EX)
2" Rear Shackles
Lynx Bash Plate
MAN KRIEKKE JA ....
  #43
Old 28-09-15, 08:29 PM
Tapie's Avatar
Member
Been having this noise coming from the steering column. In my case it was not the glued square blocks, nor the bracket on the clamp inside the engine bay.
Yesterday I decided to dig in and remove the column. Sorry I did not take any photos. I found some play higher up in the column where 2 square shafts fits into each other. Looks like there is a plastic type discs on either sides sitting on the insides but is very thin. I fixed it and there is no more play.
I haven't driven the vehicle as of yet. When I tested it I will give some feedback.
__________________
Francois Hamman
- (EX)
2" Rear Shackles
Lynx Bash Plate
MAN KRIEKKE JA ....
  #44
Old 29-09-15, 06:18 AM
SinWolf's Avatar
Member
Hi,
Yes... those shafts are glued with the same glue that fails on the other parts...
That square tubing inside the other square tubing, forms part of the collapsable steering coloumn... they slide into each other when the coloumn collapses in the event of an accident...
__________________
BFG KM2 Muds
40mm Body Lift
Lynx Bashplate
Metalian Alu Canopy
DIY Drawer system
DIY Rocksliders
  #45
Old 29-09-15, 06:27 AM
Tapie's Avatar
Member
Thanks Sinwolf.
That is what I thought when looking at it.
__________________
Francois Hamman
- (EX)
2" Rear Shackles
Lynx Bash Plate
MAN KRIEKKE JA ....
  #46
Old 29-09-15, 10:18 AM
Member
Kom Tapie,
Gooi daai feedback!
__________________
Nico Swart
ZS6NJS
  #47
Old 29-09-15, 06:51 PM
Tapie's Avatar
Member
Geen meer rattle nie!!
__________________
Francois Hamman
- (EX)
2" Rear Shackles
Lynx Bash Plate
MAN KRIEKKE JA ....
  #48
Old 01-10-15, 06:32 AM
SinWolf's Avatar
Member
Quote:
Originally Posted by tapie View Post
geen meer rattle nie!!
great !!!!
__________________
BFG KM2 Muds
40mm Body Lift
Lynx Bashplate
Metalian Alu Canopy
DIY Drawer system
DIY Rocksliders
  #49
Old 01-10-15, 06:18 PM
Tapie's Avatar
Member
Man I am relieved, didn't enjoy the ride so much....
Can't wait to hit a gravel road again!!
__________________
Francois Hamman
- (EX)
2" Rear Shackles
Lynx Bash Plate
MAN KRIEKKE JA ....
  #50
Old 01-10-15, 08:05 PM
Greenhorn Greenhorn is offline
Member
what did you do to fix it?
Reply
Tags
triton steering column
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Why I love my triton !!!! (Triton vs Hilux content) SinWolf Mitsubishi 112 19-12-13 03:39 PM
Triton steering system BlouVark Mitsubishi 124 25-10-13 12:53 PM
2009 Triton 2.5 4x4 import suspension steering vibration problems? macedon Mitsubishi 31 16-07-13 02:37 PM
Help - XJ Hooter is no work! InnerChild Jeep 17 28-09-10 01:58 PM
Creaking steering column - wiper ring for horn Steel-Wheels Ford & Mazda 3 22-09-09 10:52 AM
Template-Modifications by TMS
