logo
Go Back   4x4 Community Forum > General Category > Vehicle & Technical Chat > Toyota
4x4Community
Notices
Toyota Lead the way!
Reply
Thread Tools Display Modes
  #1
Old 29-12-10, 10:03 AM
Commander's Avatar
Commander Commander is offline
Member
Default D4D Chip
So I know this issue has been talked and talked about a lot, but I was wondering if there is any direct feedback from any one using a chip on a Hilux D4D.
Could you please give details as to what chip you are using, how long you have had it and the positive and negative effects of the chip if any.
My brother's father in law is looking at chipping his D4D and we would like some insight from folks who have done so.
Thanks!
__________________
There is no Flex like Jeep Flex!
'01 Jeep WJ Limited 4.7 V8 - 2" TerraFlex, Rough Country Shocks; 2.2 Steering damper; Quick disconnects.
  #2
Old 30-12-10, 08:30 AM
Commander's Avatar
Member
Any one?
__________________
  #3
Old 30-12-10, 08:58 AM
Bulletjie77's Avatar
Bulletjie77 Bulletjie77 is offline
Member
Hi. Go for it. Makes a huge difference. I use a Dastek chip. Been using it for a long time now, no problems.
__________________
2008 VW Caravelle 2.5TDI
2011 Toyota Hilux SRX
Rustler 300
Sprite Super Sport
  #4
Old 30-12-10, 01:10 PM
Commander's Avatar
Member
Bump!
__________________
  #5
Old 31-12-10, 04:52 PM
ScooterBike ScooterBike is offline
Member
Dastek Unichip!
140kw, 410N.m
motor just want to run...
  #6
Old 01-01-11, 06:54 AM
domanah domanah is offline
Member
Won't the improved performance reduce the life of the engine?
  #7
Old 02-01-11, 12:18 PM
Commander's Avatar
Member
So maybe I should ask if any one has had a problem after installing a chip on a d4d? Does it affect your warranty?
__________________
  #8
Old 03-01-11, 09:28 PM
Member
Nope; and maybe.
  #9
Old 03-01-11, 10:11 PM
SpeedyZX's Avatar
SpeedyZX SpeedyZX is offline
Member
Quote:
If Toyota find the plug in device consider your warranty good bye.
  #10
Old 03-01-11, 10:23 PM
Commander's Avatar
Member
Ja I would have suspected as much... Don't think any manufacturer would tolerate a chip...
__________________
  #11
Old 04-01-11, 10:19 AM
Member
thats why you unplug it before it goes for a service.
  #12
Old 05-01-11, 10:01 AM
Brent Clark's Avatar
Brent Clark Brent Clark is offline
Commercial Member: Adventure 4x4 Academy
Default Triton 2.5
Mitsubishi have an in-house chip for the Triton 2.5.
__________________
  #13
Old 05-01-11, 12:25 PM
Jengel's Avatar
Jengel Jengel is offline
Member
How much is just hearsay about the manufacturer?? Nissan installed an intercooler and Dastec chip to my 3.0 TD Hardbody. They even negotiated a discount from Dastec. At one stage when the Air temperature unit was giving funny readings, they sent it to Dastec to get it analized. For this reason I had my car always serviced at Silverton Nissan in Pretoria and had excellent service always from them. Guys, talk to your dealer and they are not against the good chips. The problem is the black market stuff that can overfuel and cause problems.
Here in Australia any service station can service a car and stamp your book and it is still honoured by the manufacturer. If you have a warrantee claim, they will lodge it for you against the manufacturer.
A chip should be installed and tuned by someone that knows what he/she does and can give you a gaurantee that the chip will not damage your engine. The better type solution also monitors the EGT and cut back when it runs close to the red line. Toyota even approves some chips like Roo systems and DP Chip here is Aus.
__________________
Toyota Hilux D4D SR5
ZS6YR/VK4JHE
  #14
Old 05-01-11, 03:17 PM
Driepie Driepie is offline
Member
Unichip also works well. The Toyota guys in the lowveld say the warranty goes out the door.
The 2.5 d4d reacts the best, iow the most gain . The engine is a low stress unit, so
an intercooler and a chip gave about 50/50. 20kw gain on the wheels. 10 from the cooler and 10 from the chip.
  #15
Old 06-01-11, 09:26 AM
Mopanie Jaap's Avatar
Mopanie Jaap Mopanie Jaap is offline
Member
I also have the dastek plug and play chip. Great torque and drivability in 4th and 5th gear! Have taken it out though because it almost dies again on starting and then recovers. Also after pull away once from a robot the car made a bang with no power and engine light coming on. Personally i thought it was a turbo or injector failure. However after restart it was fine - no problems after taking the chip out - dastek reckons it needs to be remapped.
I have to admit that i do not really miss the chip. But i guess it is a nice to have.......
__________________
Audi A3 2.0T
Hilux 2.2 4x4 d/c
Yamaha YFZ 450
  #16
Old 13-01-11, 02:57 PM
BartG BartG is offline
Member
I hate to sound negative, but chips are not good for cars, specially diesels in SA. The injectors already struggle, the gearbox on the hilux is known not to be the best and the rest of the cars parts like prop shaft are not build to handle more power. More power = more heat = more strain.
For those who do it, have fun while it lasts, I feel sorry for the person who buys it second hand and it left with a engine that worked way to hard.
  #17
Old 13-01-11, 03:11 PM
spiesfj's Avatar
spiesfj spiesfj is offline
Member
UniQchip met skakelaar geinstalleer wat jou die voordeel gee om tussen 5 voorafopgestelde stelling te kies. Bv. Ekonomies, Vallet (beperk tot 3000rpm),
Ekstra krag, "Crawl" vir die 4x4 entoesias. Nog nooit eninge probleme onderfind nie.
Ek het my Prado d4d ook nou gedoen. Die Prado is reeds by die fabriek sterker gestel op sy ECU. (MAW Toyota weet die motor kan meer krag hanteer.)
  #18
Old 14-01-11, 01:41 PM
Member
Question performance curves
Hello spiesfj, het jy dalk die Nm en kW kurwes vir die verskillende maps? Het op 'n vorige geleentheid vir SAC gevra maar hulle kon my nie help nie...
  #19
Old 14-01-11, 01:59 PM
japiedc japiedc is offline
Member
Had my chip in for 230 000km and no problems. It is a dastek chip and helped a lot for pulling my ski boat to Sodwana. Never died when working on the beach with the boat. All in all I liked it and had no problem.
  #20
Old 17-01-11, 09:46 AM
Commander's Avatar
Member
Thanks for all the inputs, it's much appreciated!
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
D4D Hilux Vego power chip Henris General (non vehicle/technical) 4x4 Discussions 2 05-12-11 12:32 PM
SAC Chip: 3.0 D4D 4x4: Fuel Consumption Improvement? macjohnw Toyota 21 14-05-11 02:50 PM
D4d: Build your own performance chip for R5! Uys The 4x4 Pub 48 11-06-10 02:11 PM
Chip for D4D - Gee raad Towatoy Toyota 2 16-04-10 02:52 PM
2.5 D4D SRX D/C 4x4 vs. 3.0 D4D D/C 4x4 NoMore1 Toyota 8 07-12-09 06:58 AM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Template-Modifications by TMS
