logo
Go Back   4x4 Community Forum > All about vehicles > Vehicle & Technical Chat - General > Ford & Mazda
4x4Community
Ford & Mazda Combined forum for Ford and Mazda
Reply
Thread Tools Display Modes
  #1
Old 23-09-10, 07:04 PM
sakk1e sakk1e is offline
Member
Unhappy 2.5 D Ford Ranger STILL overheating.
Hey guys..
I need some help please, as I am at my end with the bakkie!
I had the exact same problem as SCO had with his Ranger, I replaced a radiator and hoses and yesterday the head. Got a brand new one with a 1 year warrantee. Took it to get rebuilt with the old ones valves etc.
I got it running a few minutes ago (18:05- 23 sept 2010) Just for good measure and seeing as the head was replaced took my injectors to get overhauled, and it didnt want to start at first as I tightened the injectors too much and distorted them.
That sorted the bakkie fianlly started.
Took it for a test drive around the "block" and all was well untill I reached an incline, it started to get very hot very quick, so I pulled off immediately. Dusgusted I walked back home.
Please help
  #2
Old 23-09-10, 07:54 PM
DouglasN DouglasN is offline
Member
silly question, did you do the thermostat?
__________________
  #3
Old 23-09-10, 09:33 PM
Christo Davids's Avatar
Christo Davids Christo Davids is offline
Member
agree with Doug, sounds like thermostat issue
__________________
Christo Davids
Land Cruiser 105 4500 EFI
  #4
Old 24-09-10, 12:51 AM
Member
Thanks for the quick responses, I will get new thermostat saturday...
My friends suggested a new radiator cap??
Thing is the new radiator didnt come with a new one, but I had to get one cause old one wouldnt fit. Chances of the new radiator cap failing??
  #5
Old 24-09-10, 12:04 PM
DerikB's Avatar
DerikB DerikB is online now
Member
Both are inexpensive - I suggest if the thermostat doesn't do it - which I am sure could be the problem, just replace the cap aswell.
__________________
Derik
2011 Toyota Hilux 3.0 D-4D XtraCab 4x4
2013 Ford Figo TDCi
ORRA VHF Call Sign: B78
  #6
Old 24-09-10, 12:40 PM
Hagu13's Avatar
Hagu13 Hagu13 is offline
Member
Quote:
Umm, why doesn't your old cap fit? What radiator is/was in the bakkie? If not a stock one, are you sure it is big enough?
__________________
Rob
V8 Defender 90 pickup. Lexus, Spitronics, 33" KL71, beadlocks, +2" Terrafirma, ATB's, 3.75 CW&P, 1.21 TC.
Series IIA 88" pickup
V8 Shamrock Cobra 350
MG TF160 VVC ZandF remapped
MG TF135
BMW 330d remapped. Blandmobile econobox
Buell XB12R
  #7
Old 24-09-10, 09:59 PM
Member
Quote:
There was a Chinese radiator in the bakkie, I got it with the china radiator. I now have a proper one in, its the same size, but is original.
The cap on the china radiator is the same size as one from a Toyota conquest.
I had to get a bigger radiator cap..
  #8
Old 24-09-10, 10:02 PM
Member
Quote:
Thank you, I will be doing that tomorrow!!
Please hold thumbs!
  #9
Old 25-09-10, 02:00 PM
Hagu13's Avatar
Member
Sakkie,
I agree, change the thermostat, because it is cheap. You probably should have replaced it first and maybe saved the R10-15k I reckon you have thrown away on "faultfinding"
You need to find yourself someone who can faultfind correctly. A good old fashioned mechanic might spend 1/2 a day fiddling around finding out what is wrong before he touches his spanners, then replacing one part and solving your problem. The new breed of "mechanic" will just grab any part almost at random off the shelf, install it, invoice it, and if the problem is still there he goes back to the parts shelf. This guy will replace 1/2 of your bakkie before luck or elimination brings him around to replacing the bad part.
We can try to help out here as much as we can to guide you to the problem.
Start by describing a typical cold start to overheat cycle:
How long before temp gauge starts to move?
How long to reach middle of scale?
Does it ever stabilise there or just keep going up?
If it stabilises, can you drive around if you keep the speed down and avoid stop/start?
If it doesn't stabilise, pop the bonnet and check water pipes/radiator temperature and report.
Anything else- hard to start/misfire/smoke/etc?
__________________
Rob
MG TF135
Buell XB12R
  #10
Old 27-09-10, 12:49 PM
Member
Hey guys...
The overheating is sorted out, was the thermostat. So glad thats over, but I blew headgasket... I did something stupid when I fitted it.
In the front there is a oil duct from which the oil basically gets pumped into the head, the previous headgasket had some sealant there. So when I fitted it I also put sealant there, but I think maybe too much and as the pressure built up satruday when taking it for a test drive it blew the gasket where the sealant is.
With my luck my uncle phoned me this morning and said it can only be that, I described the noise it made etc..
So the overheating is sorted out, going to fit a new headgasket and then everything will be ok!!
Thanks for all the help! You are all a great bunch of people!!
Will update when bakkie is 100%!
  #11
Old 27-09-10, 01:45 PM
BigBear BigBear is offline
Member
Glad it was all sorted.
Which year model was the 2.5?
Around 2000/1 had inefficient Radiators fitted, which was rectified later and fitted with a more local Uprated Radiator.
__________________
2005 Ford Ranger SuperCab XLT 4000V6 Manual 5 Speed 4x4
Petri
1997 Ford Explorer XLT 4.0 L SOHC V6 Auto AWD 4x4
Pieter
2013 Audi Q5 2.0 TDi S-Tronic Quattro
Daily Drive
Reply
Tags
2.5 , diesel , ford , overheating , ranger
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Ford Ranger 2.5 Supercab vs Ford Ranger Supercab 4.0 Wenwe Ford & Mazda 10 01-09-15 07:58 AM
Ford & Mazda ratkas needed ford 2.5 and spare rim 2001 shape ford ranger Frana Ford & Mazda 11 10-11-10 07:59 AM
relocation of air filter intake on 2.5 ford ranger dees Ford & Mazda 1 26-07-10 02:32 PM
Ford Ranger 2.5 vs Nissan Hardbody 2.5 James130 Ford & Mazda 15 29-05-10 07:12 AM
