logo
Go Back   4x4 Community Forum > General Category > Vehicle & Technical Chat > Jeep
4x4Community
Notices
Reply
Thread Tools Display Modes
  #1
Old 24-08-10, 06:35 PM
ocean ocean is offline
Member
Default P0243 - Turbo waste gate solenoid malfunction
Under harsh acceleration or when driving hard up a long hill the engine management light comes on and it goes into limp mode with my 2004 2.7CRD Jeep grand Cherokee. It can be reset by stopping the car, restarting and driving for 2 km or so slowly but reappears under above conditions. Error code P0243 - Turbo waste gate solenoid malfunction. Dealer has replaced the air flow sensor and one or two other parts but the problem persists, they don't seem to know how to solve the problem... Help!!! I cant tow or drive or drive the jeep above granny-speed otherwise I get punished with limp mode. I need to use the jeep for a trip to the Breede canoe marathon in one week
  #2
Old 25-08-10, 12:25 PM
KobusM's Avatar
KobusM KobusM is offline
Member
Ocean, it seems that your turbo is overboosting due to the wastegate solenoid malfunction causing the linp mode scenario. Why did they replace the airflow sensor instead of the wastegate solenoid?? Its obvious whats at fault here!
  #3
Old 25-08-10, 03:27 PM
PhilFM's Avatar
PhilFM PhilFM is offline
Member
I also wanted to ask, why if the wastegate solenoid seems to be the problem did the dealer not look at this? I will take it back to them and not pay for the previous repairs and have them fix the WS
__________________
2004 Jeep G/C 2.7 CRD Overland
OlllllllO
2002 Toyota Hilux 2.7 D/C 4x4
  #4
Old 25-08-10, 07:41 PM
Member
Dealers are useless most of the time... I assume the faulty part is the electronic vacuum control valve that controls the vacuum going to the turbo waste gate servo. Part number A0005450527, I have not figured out how to test it so I may just blindly replace it and hope it solves the problem, or does anybody have a better idea??
  #5
Old 25-08-10, 07:52 PM
KobusM's Avatar
Member
I dont know abot testing it, but so far what my WJ told me is wrong , was wrong. Maybe Marsian can help here?
  #6
Old 26-08-10, 07:50 AM
FrancoisVN FrancoisVN is offline
Member
ocean, have it replaced in any case. We had it with a GTI that the dump valve tested fine outside of the vehicle but did not work when fitted.
  #7
Old 26-08-10, 08:22 AM
melvyn melvyn is offline
Member
hi there the problem you have with your jeep could be one of the following
vacuum leak
wastegate solenoide
the ecu
ecu is most unlikely but vacuum leak very likely aswell as the solenoide,pull the vacuum pipe of that feeds the solenoide and suck on it does it suck easily or does it create a vacuum if it does then you vacuum hose from the solenoide to the waste gate might be perished if not replace the solenoide. there is a test procedures for all of this. I greated my own owners manuall in the last 10 years of being involved with jeep. every fault code has a test procedure and when narrowed down gets sorted out very quickly.
kind regards
melvyn
american fanatics
  #8
Old 29-08-10, 01:18 PM
Member
Thanks will try it out
  #9
Old 22-09-10, 09:34 PM
Member
replaced the wastegate solenoid and guess what? THE PROBLEM IS STILL THERE. running out of options apart from selling the jeep...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Part catalogs & other useful info charlatan Jeep 73 03-05-13 12:17 AM
Beit Bridge Procedure Sticky? Senyetse Zimbabwe 26 20-01-13 03:22 PM
Moremi and Chobe trip report, July 2010 lvarro Botswana 11 19-07-11 02:38 PM
Botswana Trip report: Chobe, The Delat and Nxai Pans Dec 08 brennain Botswana 9 16-02-11 11:30 AM
Grand Cherokee Error code Nick47 Jeep 4 30-08-10 01:28 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Template-Modifications by TMS
