logo
Go Back   4x4 Community Forum > All about vehicles > Vehicle & Technical Chat - General > Land Rover
4x4Community
Land Rover Go Beyond! The best 4x4xfar!
Reply
Thread Tools Display Modes
  #1
Old 28-05-10, 02:48 PM
Jeanvn's Avatar
Jeanvn Jeanvn is offline
Member
Default gear box oil change on defender td5
Hi guys
I took my landi for a service today.
According to the mac she's ready for mozam without any problems
I was just wondering, I had them do the diff and gearbox oils, with the gearbox only costing 120. How often do you guys think one should change it? Every service? Or would that be too much? What would the benefits be of doing this every service?
thanks
Jean
__________________
Tjiep Softroadertjie
  #2
Old 28-05-10, 07:54 PM
Dale Dale is online now
Member
For R120 they may have used the wrong oil (I hope he did not use EP90 or some such?)... or a cheap mineral oil I would think. The R380 box in the Defender shows VAST improvements in shift quality with decent synthetic oils. I just replaced my main box and T-Case oil with Castrol BOT402 (My T-Case takes the same oil, yours won't) which is synthetic and I convinced the local Autozone down to R50 for the 500ml bottle. So at R100/l that was a R600 job but well worth it.
Most recommended box oil in SA for our conditions is the Castrol VMX for mineral and the MTF for synthetic but the MTF was replaced by the BOT402.
As to how often to replace, well, if you do lots of wet and muddy offroad work then maybe stay with the 'cheaper' oils and replace often, otherwise, get a nice synthetic for the main box. Makes shifting oh so easy... You can also get fancy synthetic oils for up to R180/l.
Your main box oil should be at least ATF Dextron 3 spec. I would check that invoice and make double sure they didn't fill with too thick an oil.
__________________
Dale
GU Patrol 3.0Di GL
Metalian Maxi in RED
  #3
Old 29-05-10, 07:36 PM
Johans Johans is offline
Member
Default Cheap oil
Hi Jean,
At R120 for oil they more than likely used something similar to cooking oil - I'll be very suspicious of whatever they put in there.
I've just had to redo my whole gearbox because I managed to "cook" it on the wasy to Moz towing a offroad caravan. - 17K later I now only run on synthetic stuff. The normal mineral oil starts cooking at about 210 degrees C. After that the oil just gives up - the rest of the gearbox follows soon after that.
I will have to go check the exact spec's of the oil in my box but the oil alone costs almost R1000. Although I have been assured that this is now good for another 30 000 k's.
If you do not have an EMS fitted that checks the oil temperature (I've had mine modified now) I would insist on a decent oil in the gearbox.
__________________
2008 Puma 110
Dual battery system,
compressor, 29Mhz GX300, Bull Bar & Winch, Drawer system, Long range fuel tank, Water tank, Gull Wing, Snorkel and a Chobe camper for Swambo
"Money isn't everything, but pay me enough and I'll buy my own form of misery" .
  #4
Old 29-05-10, 08:04 PM
Landyluvver's Avatar
Landyluvver Landyluvver is offline
Member
the Disco manual box (same as the Defender box) runs ATF in the main box with SAE 90 in the transfer case. the gearbox oil is cooled through the oil cooler. if the oil used in the gearbox is too thick, the oil will not circulate through the cooler and will run hot.
many motor mechanics especially those not familiar with the Land Rover boxes will tend to run SAE 90 which will destroy the box.
i use Dextron D2 which is a good quality and works.
if you wish to use the fully synthetic version, no harm but atthe price you paid i suspect they only topped up.
__________________
0833006099
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
4.0 5 Speed Auto box Oil Change lazado Ford & Mazda 8 29-03-10 11:18 AM
Very Dumb Question Re TD 5 Defender 110 Transfer Box Oil Plug EVH Land Rover 6 07-01-10 09:10 AM
Defender TD5 gearbox oil cooler pipe Ontdekker Land Rover 3 07-12-09 07:58 AM
Crown gear change on Diff lock Bebos Toyota 0 14-08-09 10:53 PM
Td5 Oil Pressure at start up Murphy Land Rover 13 19-02-09 08:01 PM
Template-Modifications by TMS
